dicksonjj Posted April 2, 2024 Share Posted April 2, 2024 New to hybridZ, new to the v8 swap. I've got a 1974 260z with original transmission, swapped l28 triple webers. Is there a kit or conversion for the oem 260z transmission to work with 'any' crate motor v8's, LS options? The plan is to swap motors and use the original transmission, if I'm able to. Appreciate any feedback and help! Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 2, 2024 Share Posted April 2, 2024 There is no swap hardware to put the Z transmission behind a V8. It wouldn't handle the torque anyway. The 260Z engine is about 158 cubic inches, compared to 350 for a SBC. The old Z transmission bearings are typically ready to fall apart besides that, not uncommon even with the stock engines. It would probably last about one pull. I haven't done it myself, but I wouldn't even try it just based on what I've learned. 2 Quote Link to comment Share on other sites More sharing options...
ShawnM Posted April 4, 2024 Share Posted April 4, 2024 I agree with NewZed on not reusing your 260z transmission but you do have another Nissan option which is what I am doing. The reasonably priced Nissan RS5R30A 5 speed found in the Z32 300ZX is used in boosted LS swapped drift cars and has proven to take serious abuse such as full throttle clutch kicking. Another bonus is it is a bit lighter and smaller than the GM 6 speed. There are many v8 swap transmission adapters our there, I'm installing the LOJ Kits piece. The other option would be to use the older Z31 Nissan 300z transmission which has the same strength but different gear ratios. Here are the different transmissions with their gear ratios. I benchmarked the Corvette Z06 GM 6 speed when deciding to go with the Z32. The final drive ratios are very close (although done with one less gear in the 5 speed obviously). RS5R30A: Z32: 1st 3.214 2nd 1.925 3rd 1.302 4th 1.000 5th 0.752 rev 3.369 FS5R30A: Z31/ 1987: 1st 3.324 2nd 2.077 3rd 1.360 4th 1.000 5th 0.760 rev 3.382 Z31/ 1988-89: 1st 3.324 2nd 2.077 3rd 1.360 4th 1.000 5th 0.711 rev 3.382 Quote Link to comment Share on other sites More sharing options...
idahoskiguy Posted June 11, 2024 Share Posted June 11, 2024 My 260Z swap was with a 1998 LS1 & T56 transmission using CX Racing mounts and long tube stainless steel exhaust. It went together great. Quote Link to comment Share on other sites More sharing options...
luigi Posted June 13, 2024 Share Posted June 13, 2024 A brand new Nissan CD009 was sub $3,000.00 last I checked. And they shift very nice. Quote Link to comment Share on other sites More sharing options...
