76 280z microsquirt project
darom
Better use some RTV or buy the expensive gasket they recommend . The flange is warped probably like mine . I used a machinist straight edge and there was .020 drop off on the end . I bought the 75$ gasket but some red RTV would probably l
work also .
my car makes all kinds of whistles and gear noises .
yes, same problem it seems with these intakes. I used a thin layer of Permatex Ultra Copper, the leak is stopped, i checked with my smoke leak detector.
I fixed my timing table (more conservative numbers), re-calculated my Bosch 0280155968 injectors flow at 36 psi (without vacuum it is at 43 psi), and re-generated my VE table using the built-in TS calculator.
43.5 PSI (3 BAR) 430 cc / min = 41 lb / h
Calculation:
old/original fuel pressure = 43.5
New Fuel Pressure = 36
Size of Fuel Injector in lb/hr = 41
New flow/Size of Fuel Injector = 37.298 lb/hr or 392.01 cc/min
The IAC is disabled, the valve opening is plugged. I can't re-check the idle startup with engine cold at the moment, but when warmed-up, I can't get the RPMs lower than 1.5-2k. The only air leak is at the throttle body with the blade which is barely open (if I close it more, the car dies). The engine's vacuum is at 15-16 at the 1500 rpm. My valve cover vents the gases via a small filter. The PCV valve is connected and operational.
If someone has time to review my tune with a datalog and tune for any issues, I'd appreciate it.
Should I proceed with turning my IAC on at this point? Or I need to test the cold startup before going with the IAC enabled?
Thanks.
PS With the throttle blade barely open, the car is making a loud annoying whistling noise. With IAC installed, the blade will be completely closed and this nonsense should stop, I hope.
CurrentTune.msq 2024-10-27-no-IAC-VE-inj-changed-calculated-flow-7.mlg
I found out that the IAC plug in my throttle body is actually leaking air, possibly causing this RPM increase. I sent an email to Pro Tunerz asking if this is intentional or if their plug should be sealing the opening 100 percent.
Protunerz got back to me and suggested dremeling the edges off in the throttle body.
First I tested it while pointing my air compressor's nozzle at it and it made the annoying noise. Removed the throttle body and took sharp edges of openings with a dremel tool:
It passed the air compressor test. After installing it, the noise is gone 80 percent, there is still some noise when the throttle blade opens up.
Hi guys,
What should be my idle fuel pressure? I have been running a FPR set at 43 psi without vacuum attached, which translates to 35-36 psi at idle (440cc fuel injectors).
Is this an ok FP for operating these injectors?
I finally got my idle sorted out with the Open Loop mode. The IAC is a sob, makes annoying noises, and I don't trust it that it stays in the set position 100 percent (I set mine in Always On). The idle would occasionally dip accompanied with the IAC noise. I'd try getting another unit to test.
Thanks!
2024-11-12-good-idle.msq
Looked at your tune briefly . Might try increasing step size for better reliability . Mine only stays stable if power is always on like yours .
Not sure I see anything that would cause a sync issue
Thanks, Steve! I will put 4-5 min steps instead. I noticed that every day (here in WI, we were at 45-50F for the past 3 days), my engine startup/warmup bevaves differently. I had to fiddle with the VE table/timing to get a stable idle. It might explain this if my IAC is not predictable and can't keep its position.
I have been doing some reading and it seems that 5v vref switch to a 12v feed for the HALL sensor most of time doesn't resolve a sync issue. I have an osilloscope and would try logging the HALL sensor's output.
Would you recommend switching over to the closed loop idle mode or stay with the open loop? I have no a/c, the radiator fan is not electric.
Just bought an n42 intake manifold that came with the micro squirt module, injectors, wiring, throttle body, fuel rail w/regulator, etc.
I’m only using the manifold and do t need anything else. Would anyone be interested in buying all the other stuff for cheap - $100 for all?
I have photos if needed.
Thanks,
‘71 240zxt
Thanks,
‘71 240zxt
Yeah - I would
sfinnerty1018@gmail.com
Maybe a pull up resistor at the CAS might help . My truck gave me fits and I ended up putting a pull up resistor at the CAS - even though the board had one - it fixed my issue .
my buddy even put an oscilloscope to it and said the signal was fuzzy . The pull up resistor was a Hail Mary
The shield is grounded at the microsquirt's sensor ground location. I might try the 12v feed to the HALL sensor. I recorded two logs while doing a warm-up enrichment autotune tonight. The 1st one picked up only 2 sync losses, the 2nd - 11. I'd admit I was committing the burn to ECU commands which I noticed causing some of the sync losses. But not all 11 of them though. I also don't see any sync loss 'consequences' on my engine running.
2024-11-22_16.45.52.mlg 2024-11-22_16.53.40.mlg 2024-11-22-adjusted-ASE-taper.msq
I swapped the HALL sensor's 5 vrf with a 12v feed.
This time all the sync losses are of my doing. For ex., adjusting the AE or WUE tables and exiting the windows, causes the ECU/engine stumble (almost like burning the changes), which generates "a reason 2" sync loss.
It might be a psychological effect on me, but the car seems to idle smoother with a 12v feed to the HALL sensor. I managed to lower the idle by putting 14.x timing degrees.
Thanks to everyone who helped with my issues!
Should I enable the Closed Loop idle now? I don't mind keeping the Open Loop, I am just looking for any benefits of CL vs OL.
2024-11-23_15.22.20.mlg 2024-11-23-before-VE-smoothing-out.msq
