Draw Through Turbo project for my 2.9 Stroker L series
A to Z
12-16-2024 Turbo Project Update.  I was able to go ahead and use a pressure setup and set my Water/Methanol switch to 3 psi for when to start spraying the mix.  I also took the piece of exhaust I needed to tie back in to the exhaust system with a flange and got it welded.  Now I have to install and mark where to clock the other flange and get it welded.  I already have the gaskets, so After the second flange, a coat of high heat paint and install and exhaust is done. :)
12-17-2024 Turbo Project Update: I managed to get my exhaust piece welded today and then I painted it with VHT 2000-degree flat black paint. Then I unboxed my new Carburetor, a Mikuni HSR 45 that has been modded by John at v-performance to work on my turbocharged setup. I also got the bottom gauge cluster mounted in my dash center panel. because of a few scratches, I will have to mask off everything, wipe it down and give the backing plate a couple coats of black wrinkle paint. Pics follow:
12-21-2024 TURBO PROJECT UPDATE:  So I changed the plan.  I bought a used generator and a handheld arc welder and will attempt to weld in the panels to fix the strut tower area.  I used 16 ga. steel, which yes, is thick, and that means it is hard to massage and bend around.  I took some measurements and cut out the first piece, then had to find places to put it while I beat on it with a ball peen hammer.  then it was just back and forth trying up there, then more work, back and forth.  I got it almost where I wanted it, but I found that, it seems to work much better for me to screw and bolt it in, to "pull" it up tight in some spots and then use my cheater pipe, a long, big screwdriver and the hammer and keep forming it where I wanted it.  The pic below shows the 2 pieces of 16 gauge in the strut tower area, then I had some real thin sheet metal that I used to cover up the turbo behind the shock tower.  It is also tek screwed on, at least for now.  It took a bit more fabbing, but I was able to get the carburetor on and pulled out into the open spot.  Unfortunately, the big K&N filter won't be used.  If you want it/need it, let me know.  I took two close up where you can see the new sheet metal from inside the engine compartment.  This, of course, will be all cleaned up and painted when done.  Being a REAL beginner with the welder, I am having a real hard time with it....I will have to watch more videos to get it to work better.  I am set at 20 amps, the lowest setting, and the rod likes to stick when I try to start welding.  Irritating, but as I have found with everything else on this car.....I end up having to do EVERYTHING myself.  Pics follow, cheers! :)
Edited by A to Z
Jesus Is Lord
12-28-2024 TURBO PROJECT UPDATE.  Well, I got the work all done in the wheel well and painted up, and then I got a bunch more done.  The hole for the knock sensor I drilled out and tapped, but the bolt I have is too short, so another trip to the store.  I got the throttle cable all in, and the 3/8 fuel line.  On the exhaust, I wrapped the area over the steering bushing, and the area next to the brake master cylinder.  It needs just a bit more work, but then it will be set.  My pipe piece to tie the exhaust in is still a bit off....I think I will limp it over to the shop and let him fix it this time.  My velocity stack arrived, but somehow the wires got crossed, it doesn't fit over the throat but is the same size....no worries a piece of 2" hose and 2 clamps and that will be done.  Getting closer.  Pics follow.
Edited by A to Z
Jesus is the Living Son of God
I tested the wastegate as well, with the spring I added, My boost crack pressure (psi boost amount when the waste first cracks open at all) is 5.0-5.5 psi....and gate is fully open at 18 psi. It is about 90-90% open at 15 psi, but just that little more pressure forces it all the way open. Since I shift at 4500-5500, it will interesting to see what boost I am getting at that shift point. I am thinking 7-8 psi. Again, it's just a fun toy. Boost switch for water methanol kicks on at 3 psi..... Should get 20-30 horsepower more at WOT with this, with the water/methanol and all. Doesn't really matter, it's just a cruiser. 250 at the crank is my guess, 200 at the rear wheel.
01-04-2025 TURBO PROJECT UPDATE. I got the J&S Safeguard knock sensor and timing retard installed in the car, and got the gauges in. VERY cold, and no heat in the garage. Not much fun. Pics:
Posted (edited)
There has been some concern on my turbo build concerning turbo heat and my brake master cylinder being right next to it. I am using a turbo blanket AND a blanket over the master cylinder. From what I am seeing it will work. Here is a test a guy did when just the use of the turbo blanket lowered the turbine temperature from 750 degrees to 176 degrees! That is a 574 degree temperature drop! Watch this! AND keep in mind I will have 2 layers, turbine and the blanket over the master cylinder. So, good to go! We move forward.
Edited by A to Z
01-11-2025 Turbo Project Update:  I managed to get the throttle cable attached to the gas pedal today.  It took a bit of playing around.  It was so hard getting up there under the dash, I ended up having to just mark where I wanted the throttle cable cut, and then taking everything out and assembling it off the car and then re-installing.  To make sure I had the cable in the correct location, I used tie wraps to hold the carb all the way open and then held the gas pedal floored and then marked where to cut the cable.  In installing the cable, I additionally put a layer to duct tape over it to keep the circular clip from falling off., and with the washer on the engine compartment side, I had to cut a channel so I could then slip it in place, turn it so the notch faced down and then tightened it up.  Worked perfect.  I then went to the other side of the engine compartment and finished getting my knock sensor mounted and with a bit of red loctite on the threads, once dried it will be permanent and should work well. I then pulled all wires back and tie wrapped them where needed so everything looks clean and tidy.  I then straightened out the last of a small wiring bit in the secondary fuse panel, finished wiring back uo the UEGO A/F sensor wiring,  and pulled the Ambient Air antenna out through the hole and the interior work is done.  I then wired in the J&S Safeguard knock sensor.  II decided to up-size the turbo oil drain, and my larger hose arrived, now to get the fittings and work on that next time.  It doesn't seem like much, but I got a lot of the work required done today.  It was 41 degrees in the garage, so good thing I bundled up.  Getting much closer to project completion.  Pics: :)
Edited by A to Z
Jesus Is Lord
01-17-2025 Turbo Project Update: I decided to jump on the jobs I have been putting off and get them over with. I re-bled all my brakes using my Motive power bleeder. Then I reinstalled all my wheels, dropped the rear back to the ground, and jacked up my engine under the oil pan again, to see if I could get any extra room to work around my brake master cylinder. Maybe 1/16 more, so I will make it work. I also drained my 20W50 oil and switched to a full synthetic 5W30 because of the Turbo. I think it is the way to go, being full synthetic, it will handle higher temps better and it flows faster. I added a bottle to Risilone ZDDP additive to make sure everything is well lubricated. I also managed to finally get my intake on the car. Before coming in, I jacked the nose of the car way up on jackstands, so later I can install the turbo drain hose. Every step forward counts I guess.
Edited by A to Z
Jesus Is Lord
02-01-2025 TURBO PROJECT UPDATE:  Another step(s) forward.  I managed to get the oil drain line installed.  Of course, I ran into problems, this time being the steering rod was right smack in the way. :(.  By using parts I had and some thread sealer I picked up at Lowes, I managed to get it in.  In the picture, you can see a clamp at the oil pan area.  That is squeezing the hose open, as no matter what I did it wanted to pinch a bit.  It worked!!  I also used a piece of aluminum with zip ties to cover the drain hose where it touched the steering rod.  This will protect the hose.  After all of this, I got my outside air temp probe mounted....it is in the passenger wheel well.  I then began the process of grinding down screws and sanding to prep the inner wheel well area behind the turbo for paint  I got it feathered out and then blew the area off.  Next time, God willing, I will wipe the area down, mask and paint.  After that I have to re-run some water methanol lines and install all of the heat blankets, etc. I have for the brake master cylinder.  Other than a trip to the muffler shop to tie the exhaust in, the project will be done (finally, feels like it is taking forever).  Cheers!    :)    Pics:
02-05-2025 TURBO PROJECT UPDATE:  I set about getting things masked off and then painted the areas that needed it on the inner fender.  Once the paint is hardened, I can wet sand and polish it, and some will need touch up painting, typical stuff.  I was then able to install all the heatshield I had to protect the brake system and fluid.  I then replaced the 2 water/methanol supply lines that had damage on them and then filled the Water/Meth tank about half full of windshield washer fluid (30% methanol).  Good progress!  it is almost complete. :)  Pics:
02-11-2025 TURBO PROJECT UPDATE. It is below freezing out, but I had to try some starting fluid.....It fired up! so cold, it will only run on starting fluid....but it tells many things........all 6 cylinders firing and my J&S Safeguard works! No oil leaks, oil pressure up. no air leaks. pumping the gas to keep it running let it rev just a tad and I could hear the turbo whistle! The carb doesn't have a choke, but I have one on order. But I have a sense of relief as it works, no pinging so far. So clear skies ahead!
02-15-2025 TURBO PROJECT UPDATE:  I installed a choke on the carburetor, did some work to hold the throttle cable into the firewall fitting, and then finished out the insulation for the turbine (hot side) of the turbo, the exhaust (downpipe) and the brake master cylinder cover,  the cover for the brake master cylinder is tight enough it holds it in place against the corner of the turbo.  I opened the flap and folded it back, and then started cutting strips from the lyrufexon blanket which has a heat rating of 2600F and really is just a trimmable ceramic blanket.  By cutting it into strips, I was able to use a small bar and pry the master cylinder gently and tuck the strips in there to give even more insulation.  After that I cut thin strips and put them against the side of the master cylinder facing the exhaust, then the flap just folds over and holds it all there right in place.  Then I just found a nice way to tie it closed and then do a little trimming and painting to make it look ok.  Pics follow! Cheers! :)
Edited by A to Z
02-20-2025 TURBO PROJECT UPDATE:  So, when it is about 7 degrees outside and you have some small things to get done, you do it inside I guess.  Carb issues.  Brand New carb, but some small issues have arisen that I have to address.  the pilot jet and main jet appear to be plugged, as the engine only runs if you pump the gas, as the accelerator pump is squiring fuel with every pump, and it won't idle.  So a small piece of wire and some carb cleaner spray should be able to handle that.    Secondly, the float bowl overflow tube is leaking gas.  So, I will shortly go out and remove the carb, remove the float and clean it out so the float will turn off without any debris keeping it from shutting off, AND there is the possibility  that I am pushing a tad too much fuel pressure at it.  I went ahead and ordered a pressure regulator and gauge on amazon, and a 20 micron fuel filter I will install right before the fuel goes into the carb.  from what I understand, this motorcycle carb likes 2.5 to 3 psi of fuel pressure.  This should do the trick. At any rate I got the threads all seal taped up and have it ready for install.  Pics to follow.  Cheers!
02-22-2025 TURBO PROJECT UPDATE:  Well I managed to get the pressure regulator and gauge on.  I then fiddled with the carb a bit and got it started.  The carb just needs work that I can't do.  I don't have the hand dexterity anymore to deal with little parts.  So, It is going back to V-Performance to go through it and make some changes....the pilot screw, which is normally 2 turns out, is 1/2 of 1 turn out to get it to start without starting fluid, so there will have to be some adjustments made.  I tried to work on the carb, but I was just screwing it up, so out it goes.  Pics attached. :)
