What did you get, the Pro Touring kit?
I do like how the Apex suspension looks and I heard a lot of good things about them. I also picked up some parts for myself to try out. Modified S30 Z’s are rare in Europe and once with anything more the coilovers even more so I’ve never seen the Apex suspension myself. I will eventually move down the new Retro Mod line as I want to keep the stock drivetrain and R200 diff but for now I just got some nice upgrades that give me the adjustability I need.
- Front fender brace
- Frame rails
- Rear strut brace
- Front control arms
- Steering knuckles
- Front crossmember
- Upper steering rack clamps
- Rear control arms
  • Like 1
- Frame rails
- Rear strut brace
- Steering knuckles
- Front crossmember
- Rear control arms
Good list, I went with the track Attack kit And a 370Z diff (R200). I went with the Bull Dog Frame rails as they can go over the existing frame rails. They are still in the box though, I’ll install those after I install the rear suspension.
Wow, great progress!  I love the cantilever design on the rear suspension.  A few guys here have previously designed their own custom cantilevers; but AE is the only vendor that I'm aware of that has ever "mass produced" a system like this.  Really interested to hear your feedback on how the whole TA package works once installed.
Is that the final resting place for the fuel cell?  If so, are you going to have a way to isolate it from the rest of the driver's compartment?
  • Thanks 1
Thanks. That’s the fuel cell that came with the car, it’s too big (20 gal) and I don’t like it mounted on top of hatch floor. Going to explore Black Friday deals, thinking of going with an ATL because of the bladder and other safety features and I’ll recess it down as far as I can, hopefully it’ll sit flush. Trying to decide if I should go with 10 gal or 12 gal, 12 gal is a little cheaper for whatever reason. I should burn approx 5 gal a session at Sebring, the track I’ll frequent most.
  • Like 1
I did a 14 gallon radium cell in mine because i plan on possibly running e85 and we have some 30-35 minute sessions with some clubs. I have it raised like an inch and a half out of the floor to make the bottom height where I was visually happy. My cell is advertised at 11.7" tall so if the ATL 10 or 12 is shorter then flush with the floor should be perfect.
  • Like 2
Decided to go with the ATL 12 gallon, just ordered it. It’s 10”. Will need to build a frame for it, should be good little project to practice some more welding.
  • Like 1
I have the ATL 12 gallon cell in mine.  I also use the ATL Black Box sump with pump.  The fuel return dumps into the top of the Black Box.  I can use pretty much every drop of fuel in the cell without fear of starvation.
My cell is below the rear deck and offset to the right for weight distribution reasons.
You can just see the bottom of the cell in this picture:
Edited by 74_5.0L_Z
  • Like 1
  • Thanks 1
6 hours ago, 74_5.0L_Z said:
So is the fuel tank recessed below, and that is an access panel for filling? I’ll look into the black box as I’ll be running a fuel return as well. Hadn’t thought of offsetting the tank for balance, thanks.
Edited by FastFloridian
