Guest sooley Posted March 11, 2003 Share Posted March 11, 2003 I'm at the stage of looking for an aftermarket ECU. Im currently looking at the Haltech E11. Its the new model in the range and seems to be the bomb in the Haltech range. Problem is, its $2500 AUS and thats up in the Apexi power FC and Motech price range. So what are you guys using on your cars? Quote Link to comment Share on other sites More sharing options...
BRAD D Posted March 11, 2003 Share Posted March 11, 2003 Me and stony bolth have RB26's and bolth run SDS. http://www.sdsefi.com Quote Link to comment Share on other sites More sharing options...
stony Posted March 12, 2003 Share Posted March 12, 2003 sds is the cheapest easiest to tune with that send its almost too simple. no datalogging;< very easy to tune on a dyno Quote Link to comment Share on other sites More sharing options...
j260z Posted March 29, 2003 Share Posted March 29, 2003 i was just down talking to ross at SDS the other day. that system looks like the easiest most adjustable system going. hopefully in a few months i'll pick one up. Quote Link to comment Share on other sites More sharing options...
RB30-ZED Posted March 30, 2003 Share Posted March 30, 2003 I run my RB30DE with Kalmaker, i think its still around $1000au. Take a look at there page, http://www.kalmaker.com.au Steven Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 30, 2003 Share Posted March 30, 2003 sds if ya want success! Quote Link to comment Share on other sites More sharing options...
Guest empracing Posted March 31, 2003 Share Posted March 31, 2003 i'de go haltec everytime well next time anyway if you know what i mean Quote Link to comment Share on other sites More sharing options...
Guest MistaFosta Posted April 1, 2003 Share Posted April 1, 2003 Couple of questions bout the SDS. How is the Drivability with it? Is it pretty easy to tune the fuel and ignition maps corresponding to boost? Anyone done any dyno runs with it? Curious how much it pulls.. Quote Link to comment Share on other sites More sharing options...
stony Posted April 1, 2003 Share Posted April 1, 2003 i tuned mine on a dyno. took about 3 hours and got 382 rwhp from a rb26 with the same junkyard plugs and 15 psi on pump gas (92 oct) when the weather is nice i drive mine to work everyday no problems getting about 20-25 mpg Quote Link to comment Share on other sites More sharing options...
Guest zline Posted April 1, 2003 Share Posted April 1, 2003 Quote Couple of questions bout the SDS. How is the Drivability with it? Is it pretty easy to tune the fuel and ignition maps corresponding to boost? Anyone done any dyno runs with it? Curious how much it pulls.. driveability isnt a function of your ECU, all your ECU does is tell your motor when to give fuel and spark at what points over the rev range etc., your cars drivability is a function of how built and what parts you're running, an SDS with a stock map on a stock engine will drive like a stock car...a SDS mapped for a T3/T4 with a 60-1 wheel 600 cc injectors and all the other goodies would be a lot less streetable. - dan Quote Link to comment Share on other sites More sharing options...
Guest MistaFosta Posted April 1, 2003 Share Posted April 1, 2003 \ said: Quote Couple of questions bout the SDS. your cars drivability is a function of how built and what parts you're running' date=' an SDS with a stock map on a stock engine will drive like a stock car...a SDS mapped for a T3/T4 with a 60-1 wheel 600 cc injectors and all the other goodies would be a lot less streetable. - dan[/quote'] Unfortunetly, there are some inferior ECUs that will cause driveability issues. They wont map correctly for the boost ramp, or dislike cruising. From what you guys say, its a good system though, so I will probably use it over haltek... Quote Link to comment Share on other sites More sharing options...
z ya Posted April 1, 2003 Share Posted April 1, 2003 Foster, You going the turbo route instead of your current v8?? Quote Link to comment Share on other sites More sharing options...
Guest zline Posted April 1, 2003 Share Posted April 1, 2003 \ said: Quote Quote Couple of questions bout the SDS. your cars drivability is a function of how built and what parts you're running' date=' an SDS with a stock map on a stock engine will drive like a stock car...a SDS mapped for a T3/T4 with a 60-1 wheel 600 cc injectors and all the other goodies would be a lot less streetable. - dan[/quote'] Unfortunetly, there are some inferior ECUs that will cause driveability issues. They wont map correctly for the boost ramp, or dislike cruising. From what you guys say, its a good system though, so I will probably use it over haltek... i should have made myself more clear on that post, if you spend the cash to put a RB in a Z and have access to a wealth of information ie HybridZ, all the less than desireable products have been filtered. only the best for the best....and the best is the group that hangs around on this community. Quote Link to comment Share on other sites More sharing options...
Guest MistaFosta Posted April 1, 2003 Share Posted April 1, 2003 Yup, thats why I asked you guys... Quote Link to comment Share on other sites More sharing options...
j260z Posted April 2, 2003 Share Posted April 2, 2003 the SDS guys are top notch. they used to run a full service shop and run their own 240z race car ( with a 1.8l turbo toyota engine). they also stuck the same engine with water injection into my friends tr7 about 10 years ago awesome car. they decided to drop the shop and just work on building the SDS systems as that was what they were interested in. Quote Link to comment Share on other sites More sharing options...
JustChou Posted April 5, 2003 Share Posted April 5, 2003 stony said: sds is the cheapest easiest to tune with that send its almost too simple. no datalogging;< very easy to tune on a dyno Which system do you use, Stony? Quote Link to comment Share on other sites More sharing options...
stony Posted April 5, 2003 Share Posted April 5, 2003 SDS ;> Quote Link to comment Share on other sites More sharing options...
JustChou Posted April 5, 2003 Share Posted April 5, 2003 stony said: SDS ;> My bad...I meant which trim level, which model? Quote Link to comment Share on other sites More sharing options...
stony Posted April 5, 2003 Share Posted April 5, 2003 SDS EM-4 Quote Link to comment Share on other sites More sharing options...
Guest sooley Posted April 6, 2003 Share Posted April 6, 2003 Wow, thanks for all the info guys I guess what I am doing is looking for an ECU that will be able run the RB30DET set up that Ill be running. The Car will be used for track mainly and some road use. I'm looking for it to also control boost, so what would I do there. The other problem is, where the heck do I get an SDS system from in Australia. I don't know if they sell them here. I haven't heard of them before??? Anyone got a web address for them son I can check them out. Thanks all Sooley Quote Link to comment Share on other sites More sharing options...
