Guest Your Car is Slow Posted March 28, 2003 Share Posted March 28, 2003 So umm...which bolts actually hold the head to the block? The 4 down the middle under the cam? or the ones along the drivers side of the head? or all of the above? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted March 28, 2003 Share Posted March 28, 2003 14 hex head bolts. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted March 28, 2003 Share Posted March 28, 2003 don't forget the 2 little 10mm bolts in the front of the head Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted March 28, 2003 Share Posted March 28, 2003 yer freakin kiddin me right? Every goddam one of those holds the head on???????? lakjdlfkjasdkfj Time to bust out the impact :/ Quote Link to comment Share on other sites More sharing options...
Mudge Posted March 28, 2003 Share Posted March 28, 2003 Your serious? How would the cylinders seal with 4 bolts dude, that would work for one cylinder, not 6. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 28, 2003 Share Posted March 28, 2003 yer freakin kiddin me right? Every goddam one of those holds the head on???????? lakjdlfkjasdkfj Time to bust out the impact :/ They shouldn't be tight enough to require an impact to remove. They only have a 10mm socket head, torqued to 60 or 70 ft-lbs... I've removed them with a 3/8" socket wrench. Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted March 28, 2003 Share Posted March 28, 2003 It was the sheer amount of them that called for the use of the air rachet...Im quite lazy Quote Link to comment Share on other sites More sharing options...
Hybrid240z Posted March 28, 2003 Share Posted March 28, 2003 Don't forget that there is a procedure to remove head bolts or else the head might warp. The procedure is in any maitenance manual such as Haynes and Chilton. Marcos Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted March 28, 2003 Share Posted March 28, 2003 Ill have to go look it up then..thanks! I hadnt finished making my allen socket yet...so I never did remove anything. Them thick allen wrenches sure are a pain to cut through :/ Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 28, 2003 Share Posted March 28, 2003 Ill have to go look it up then..thanks! I hadnt finished making my allen socket yet...so I never did remove anything. Them thick allen wrenches sure are a pain to cut through :/ One word: HOTSAW! Quote Link to comment Share on other sites More sharing options...
johnc Posted March 28, 2003 Share Posted March 28, 2003 So, are we taking bets on how many of the head bolts snap when the trigger is pulled on the impact gun? I say 8 and will put up $5. Quote Link to comment Share on other sites More sharing options...
260ZRED Posted March 28, 2003 Share Posted March 28, 2003 I don't know how you would remove them with a 3/8, because I remember how I had to use a pipe a couple feet long just to begin turning those bolts! anyhow, good luck, and yeah, read the manual, it will tell you the order. Quote Link to comment Share on other sites More sharing options...
Mudge Posted March 28, 2003 Share Posted March 28, 2003 I agree with John, not a good idea. Plus with the long friggin L6 head, it wouldn't be good for it regardless. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 28, 2003 Share Posted March 28, 2003 I don't know how you would remove them with a 3/8, because I remember how I had to use a pipe a couple feet long just to begin turning those bolts! anyhow, good luck, and yeah, read the manual, it will tell you the order. Considering the torque, and the length of the wrench, I can apply 60-70 pounds to the handle...but not if the bolts are corroded. But I've dis-assembled 4 L28 engines to date and never had a problem with head bolts. Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted March 28, 2003 Share Posted March 28, 2003 Bolts are fine...I didnt actually intend to use an impact gun...that was a bit of sarcasm....an air rachet however will indeed get used. Quote Link to comment Share on other sites More sharing options...
72zcar Posted March 29, 2003 Share Posted March 29, 2003 dont forget to support the chain and jam the tensioner... or you will Quote Link to comment Share on other sites More sharing options...
