How to read a Haynes manual
auxilary
Haynes: Rotate counter-clockwise.
Translation: Clamp with vice-grips then beat repeatedly with hammer
counter-clockwise.
Haynes: This is a snug fit.
Translation: Clamp with vice-grips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with vice-grips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now
you are looking at scary photos of the inside of a gearbox.
Haynes: Pry off
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a can of WD40 (giant economy size).
Haynes: Retain tiny spring...
Translation: PINGGGG - "Where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers
to dig out the socket part (and maybe a piece of glass or two).
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your
forehead are throbbing then clamp with vice-grips then beat repeatedly
with hammer.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned.
Haynes: One Difficulty rating.
Translation: An infant could do this... so how did you manage to **** it
up?
Haynes: Two Difficulty rating.
Translation: Now you may think that you can do this because two is a
low, teensy weensy number... but you also thought the wiring diagram was
a map of the Tokyo underground (in fact that would have been more use to
you).
Haynes: Three Difficulty rating.
Translation: Make sure you won't need your car for a couple of days.
Haynes: Four Difficulty rating.
Translation: You're not seriously considering this are you?
Haynes: Five Difficulty rating.
Translation: OK - but don't ever carry your loved ones in it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw
it at the garage wall, then find some vice-grips and a hammer...
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are
Looking at, then declare in a loud knowing voice to your wife "Yep, as I
thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer deep abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much
harder. Once that sinking pit of your stomach feeling has subsided, you
can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Pry away plastic locating pegs...
Translation: Snap off...
Haynes: Using a pin punch...
Haynes: Everyday toolkit
Translation: AAA Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother.
Alternatively, clamp with vice-grips then beat repeatedly with hammer.
Nice translations: to to funny.
I found myself reliving emotions that were suppressed from past repairs (denial is not a pretty thing-oh the horror!).
What I hate about the Haynes (any other incomplete manual) is when they make a reference to a component in their diagnostic sections...yet the component being referenced isnt defined anywhere in said manual :x
Blasted Cursed Manuals :twisted:
I've discovered that retribution may be found by throwing the incomplete manual up in the air & shooting it w/a shotgun :D
Kevin,
(Yea,Still an Inliner)
I burned my last haynes manual....
Watching those useless pages curl in the flames was a nearly religious experience.
stick to the full service manual... or wing it and hope to god you have a good memory.
heh...
"may require gentle tapping"
Translation:
try tapping said part gently, then proceed to beat the hell out of it until said part is barely recognizable, then try a sledgehammer... once the handle on sledgehammer is broken, switch to a sawzall and torch. 6 hours after gentle tapping has commenced, consider buying a new car.
(that's what i went through trying to remove a spindle pin...)
I had heard that the Haynes was better than the Chiltons manual, I wonder if the people that said that ever saw a Haynes... In my experience to date, my Haynes for the 240 is not like my Chiltons are for my other cars that I've had before, who knows.
Here is another one to add to it Haynes: A puller is not required.
Translation: Try to pull the part off (hahahaha). Use a half a can of WD-40 and bang on it with a hammer. When that doesn't work, bang on it with a bigger hammer. When that doesn't work, go into town and buy a puller. Keith
Guest silverbullet
I have heard similar things and I can't figure what people are talking about, I HATE :cuss: Haynes manuals (the shotgun destruction method sounds good).
For the smaller manuals I always prefered Clymer. They "used to" offer more details.
When i get stumped I go to the library at Northwestern College in Lima Oh. They have a full set of Mitchell service and diagnostic manuals, with vacume and wiring diagrams and nearly everything else for every car made in the last 45yrs.
