David K Posted May 24, 2003 Share Posted May 24, 2003 Garret GT28R t3/t4 with a 62 trim compressor (.60 A/R) and a 76 trim turbine (.86). I would like to see a turbo expert compare the potato to the stock L28 t3, on an L28 block. thanks Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted May 24, 2003 Share Posted May 24, 2003 guess u readed the SCC 240sx/silvia project . sounds like the turbo is pretty badass... mike Quote Link to comment Share on other sites More sharing options...
David K Posted May 24, 2003 Author Share Posted May 24, 2003 Yeah thats exactly where i got it from. I posted on the private SE-r list where Mike Kojima and Rob Cadle prowl. Ill get a nice long response by morning. Sounds like a monster turbo. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 24, 2003 Share Posted May 24, 2003 Its not big enough for a Z car. Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted May 24, 2003 Share Posted May 24, 2003 whats the exhaust wheel? Quote Link to comment Share on other sites More sharing options...
David K Posted May 24, 2003 Author Share Posted May 24, 2003 Its not big enough for a Z car. Care to explain? Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted May 24, 2003 Share Posted May 24, 2003 A 76 trim turbine???? Who thinks of this stuff.... Is it a N,O, P, Q what the fu.. . Its a T3 stage II III V? People always try to re-envent the wheel. Quote Link to comment Share on other sites More sharing options...
David K Posted May 25, 2003 Author Share Posted May 25, 2003 A 76 trim turbine???? Who thinks of this stuff.... Is it a N,O, P, Q what the fu.. . Its a T3 stage II III V? People always try to re-envent the wheel. Alex, the guys who created this turbo know what they were doing. No need to get all tissy about it. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted May 25, 2003 Share Posted May 25, 2003 76 trim is Stage V I think. I have no idea 62 trim is I would go with T04S with BB, and forget about it Quote Link to comment Share on other sites More sharing options...
Guest DaneL24 Posted May 25, 2003 Share Posted May 25, 2003 Doesn't the Silvia use the SR20DET engine (2.0 liter four cylinder)? If so, the turbo from the 2.0 liter engine won't allow a very broad efficiency range on a 2.8 liter engine. CFM is a determining factor in turbo efficiency, and since a 2.8 liter engine will use the same CFM as a 2.0 liter engine at a lower RPM...turbo efficiency will begin to drop off at a lower RPM on a 2.8 liter engine than a 2.0 liter engine. This is assuming that the turbo was matched well for the 2.0 engine. You would need to see a compressor map to really know. I think thats what Lockjaw meant by the turbo not being big enough for a zcar. You could always intercool it to reduce the negative affects of low turbo efficiency (heat), but efficiency would still begin to drop off at a lower RPM. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted May 25, 2003 Share Posted May 25, 2003 The cfm between the two is not much different @ redline because redline is higher on SR20 than L28. The turbo probably spools about 1000rpm higher rpm on SR20 but if you can shift the engine around 8K rpm it'll all make up for it. Just a thought. It well be a dog trying to spool Stage V wheel on a 2.0L. BB will help some. wait, 76mm = 3 inch. It must be bigger than Stage V Quote Link to comment Share on other sites More sharing options...
yo2001 Posted May 25, 2003 Share Posted May 25, 2003 Never mind, I just looked up GT series 76 trim. 53.8mm major with 47mm exducer. not even close to be stage V (71mm/61.95mm). No that's not big enough. 62trim would flow but not with that turbine wheel. IMO HKS GT3040 runs 50 trim and 84 trim and supports 500HP. FYI Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 25, 2003 Share Posted May 25, 2003 Its not big enough for a Z car. Care to explain? Yes, go back and read the article, its not a t3/t4. Second you guys need to get an understanding of what trim is. It is simply a ratio of the inducer to the exducer. Nothing more. Thats all I feel like typing. Quote Link to comment Share on other sites More sharing options...
David K Posted May 25, 2003 Author Share Posted May 25, 2003 Thats all I feel like typing. Well thanks. The reason i argue is because im trying to get to know about turbos. Your reply helps me none. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 25, 2003 Share Posted May 25, 2003 What do you want to know then, specifically? The turbo is designed for a 2.0 liter engine, and putting it on a 2.8 is not going to be a wise move. Here's an example. Take my turbo, which has a stage V turbine. On a 2.0 liter DSM engine, you will be lucky to have full boost by 4500 rpms, and this would be described as a "laggy" turbo, ie not for street use. I talked to a guy from Team Nabr that has one. Well on my 2.8 liter engine, I have full boost by 3200 and it is anything but 'laggy". There is math and science and just a touch of voodoo that goes into turbo selection. Just because a mag says it is a great turbo, doesn't mean it is. You have to know what it flows, where it flows most efficiently, and where your engines flow falls into that data. Without that, you are guessing. If you want to know a good turbo to run, ask the people on the board with some fast times what they use/recommend. Also if you don't have it, Corky Bells book, Maximum Boost would be a good starting point for learning what you need to know. Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted May 27, 2003 Share Posted May 27, 2003 Oh believe me I'm not Tissy about anything people say or claim. But I doubt that anyone has created anything that hasn't been done or proven by Garrett. But if your calling a stage V wheel a 76 trim just trying to make a product sound different, its just stupid. I guess people just want to justify pricing a turbo double what it should cost. Enjoy the ride. Alex C Quote Link to comment Share on other sites More sharing options...
David K Posted May 27, 2003 Author Share Posted May 27, 2003 But I doubt that anyone has created anything that hasn't been done or proven by Garrett. The turbo in question, and the guys who created it, work at garrett. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 28, 2003 Share Posted May 28, 2003 Its still to small. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 28, 2003 Share Posted May 28, 2003 Its still to small. :malebitchslap: Hehehe Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 28, 2003 Share Posted May 28, 2003 My parents live in Windsor. Quote Link to comment Share on other sites More sharing options...
