Guest ON3GO Posted June 8, 2003 Share Posted June 8, 2003 hey guys. last night started my car, and no headlights.. every other light works but no headlights. so today i looked at the fuses, and etc and cant figure it out. any ideas? would both bulbs just go like that at the same time? mike Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 9, 2003 Share Posted June 9, 2003 check the switch. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 12, 2003 Share Posted June 12, 2003 well i check the switch but im not sure what to look for. it stinks cuz i cant use my car at night at all. so what sould i look for, and how would i go about testing to see whats wrong and not..... Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 13, 2003 Share Posted June 13, 2003 ? anybody..... i wanna try getting it working tonight. Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 13, 2003 Share Posted June 13, 2003 its a soldered lead on the switch, check its voltage when the switch turns on and off, also check the fuse if you havent already, sometimes that solder just falls off, and if you put it back on and solder it up its ok. junkyards are full of the late switches, and the wiring is identical on the older switches. or just use a dummy lite and see if it lites up when you turn the light switch on. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 13, 2003 Share Posted June 13, 2003 ahh ok... now i checked all the fuses. now a few days ago all my lights went out, so i replaced the fuse and all was go, now all my lights work but the headlights. ill check the switch with what you said and i hope that fix's the problem. Thanks Quote Link to comment Share on other sites More sharing options...
Cruez Posted June 13, 2003 Share Posted June 13, 2003 If not the switch check the fuse links... I can't remember which one and what it does exactly but one of them powers the lights.... Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 13, 2003 Share Posted June 13, 2003 if its a link, its the one thats really soft. Quote Link to comment Share on other sites More sharing options...
spotfitz Posted June 13, 2003 Share Posted June 13, 2003 Being I have went through this situation very recently, for the running lights check the hazard switch. All running lights go through there. If it is the headlights, check for any tarnishing of the connection in the switch(use scotch-brite or fine sand paper to clean connection). I would Highly recommend relays for the headlights as it has resolved any and all problems with my headlights. Pete has an excellent write-up on the relay conversion. Check his site. Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted August 14, 2003 Share Posted August 14, 2003 I had no headlights and cleaned off the contacts for the Fusible links both sets it was the back fusible links that was the culprit for me Quote Link to comment Share on other sites More sharing options...
Cruez Posted August 14, 2003 Share Posted August 14, 2003 As soon as I get my maxi fuse dist block, I am getting rid of the fusible links.... They are a PITA Quote Link to comment Share on other sites More sharing options...
Guest DaneL24 Posted August 24, 2003 Share Posted August 24, 2003 The headlights in my '71 240 went out recently...and it was because the headlight switch shorted out. When the lights stopped working, I could hear something sparking and smoke was pouring out of the steering column. I pulled off the plastic steering column covers and when I flipped the switch I could see it sparking, and it melted a big mark on the inside of the plastic cover. Needless to say...I'm just replacing the switch assembly. Easy to remove and put back together fortunately. Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 7, 2003 Share Posted September 7, 2003 Unplug one of your head light conectors in front of the radiator and unplug the concter at the steering wheel and check for continuity. Check fro voltage at the plug and continuity between the red/black at the front plug and switch plug, the low beam is red/black, green + . I just went through this last night, checked everything and the found 2 headlights with no low beams. So it is possible to loose 2 at once. Quote Link to comment Share on other sites More sharing options...
