bump steer spacer
Guest ON3GO
hey guys.. i have the MSA bumpsteer spacers for my Z.
now i only have them for the front, do i need them for the rear too?
and sense they go below the struts it raises them up abit, now do i still need the bump stop?
mike
bumpsteer spacers stop your steering wheel from truning when your car is lowered and you hit bumps, so no you dont need them in the rear because you dont have 4 wheel steering :-D
And yes you will still need your bump stops.
Did you get the CCW's yet? :shock:
bumpsteer spacers stop your steering wheel from truning when your car is lowered and you hit bumps' date=' so no you dont need them in the rear because you dont have 4 wheel steering :-D
Did you get the CCW's yet? :shock:[/quote']
If they were really bump steer spacers, that is what they would do, but they actually don't reduce bump steer at all - they correct your camber curve. To correct for bumpsteer you have to change the pivot point on your crossmember.
This page should answer all your questions:
http://www.reactionresearch.com/suspension.htm
Guest BigWhyteDude
you know ive read about it on here, and in the JTR manual but i still dont fully comprehend what bump steer is. Can someone clearify this issue for me. I feal dumb because i have read the JTR manual like 3 times already. :oops:
Don't assume that because 3/4" up and 1/2" out works for someone else's car that it will work for yours. Chances are they never checked it either.
If you want to check bump steer you need a gauge. If you don't want to buy a gauge you can use 2 dial indicators and make your own mount. I fixed my bumpsteer by drilling a hole directly above the stock hole as high as I could on the crossmember, then cutting a slot between the two holes.
I then used a gauge and kept raising the pivot until I got it done. My pivot moved approx 1/2" up. I didn't move out, because I am using adj control arms and figured that I could lengthen the control arm instead.
Bump steer is something that has to be measured and changed precisely. I hate seeing people drill the hole x amount up and x amount out. You'll probably make it better, but it won't be right.
BTW I've had my setup on the track and auto-xing many times in the last 6 years with slicks and never had a problem with the control arms moving. If you can slot a rear 510 or ZX crossmember, you can slot a front one too.
Jon
