Input Needed on turbo 4 barrel
Cjarloz
Ok this is my first post here but here goes.
I am in the process of converting my 71 240z into a turbo L28 83' z with dished pistons. Heres the curve ball im not going fuel injected :roll: . I am using a holley 4 barrel 600 doublepump and im pressurizing the 4 barrel via a turbonetics intake plenum connected to a frod probe intercooler and a stock T3 turbo. I also have an R200 3.54 rear end. Can anyone help me understand what kind of hp gains i will have compared to a fuel injected turbo at 7 or 8 psi. Aswell what kind of power gains
Any help or input will be greatly appreciated thx.
Carlos :D
also wouldn't a 600cfm carb be ok? Some people told me that my settup w/ a sc with a 390cfm would be way to small.
Lets see, a 600 cfm carb on a 350 hp 5.7L Chevy is about right. That feeds a motor that is twice as big as yours. Funny, Chevy guys always talk about over-carbing their motors, and bigger is not always better, even with forced induction. Perhaps some of the experts can chime in.
Just looking at what you have, a 390 cfm Holley would be more then enough from what I have read.
Davy
well, at 15psi, the 2.8L is roughly 5.6 litres at 6500 rpm, so the 600cfm might be just about right.
That, and the fact that my old draw-through system would run 12.27 to 12.40 at about 17psi and it used a vacuum actuated holley 650....
When dealing with N/A applications, a Z will also effeectively use a 650 as we had one for a few passes at ElMirage, until we went to Webers which have a flow potential of 1100cfm, which is "way too much" anynway.
Theory goes out the window when racing is involved. Results are results.
Don't get hung on theory.
I have seen a 750 holley run great on a 58 VW bug with a 1600 cc engine with a draw through at 14 psi (11.9's at 120). So i'm sure a 650 will work with a 2.8.
To figure hp gains from a turbo do the following equation.
(14.7 + boost)/14.7 = "hp multiplier"
Then use the "hp multiplier" on the hp of the engine WITHOUT a turbo and the new hp is estimated.
For example: a L28 with 10 psi of boost.
(14.7 + 10)/14.7 = 1.68
Stock hp at the wheels is 135 hp.
135 hp x 1.68 = 227 hp (at 10 psi of boost)
The T3 is going to feed the IC and the intercooler is going to feed the Holley from the top via a turbonetics air plenum. Additionally, we are going to have a Mallory boost sensitive fuel regulator with a return line to the gas tank as well as a Mallory electric fuel pump capable of handling even FI if we wanted to go that way. We are also planning to keep the boost under control with a manual boost adjustment controller and the HKS blow off valve. There will be a gauge to keep track of the exhaust gas temperature.
Additionally, we are installing the L28et oil cooler and 2.5" to 3" downpipe and exhaust system. Next will be a stand alone electronic ignition with capability to retard timing based on boost. A NOS plate under the holley for an additional 50 - 75 extra HP (No turbo Lag hopefully). It is just not happening all at once.
Will keep things tamed around 7-10 ponds of boost until we go through the learning curve. The mecahnical 600 holley may give us the control we need to keep things in line on low boost condition.
My guess is that a two barrel holley at 300-500 cfm should be quite similar to the mechanical 4 barrel (double pumper) under higher boost conditions.
No, because the whole carb is pressurized. However, the fuel pressure needs to be increased as the boost is increased.
The fuel pressure should be 5 to 7 psi greater than the pressure the carb "feels". So at 0 boost, the pressure should be 5 to 7 psi and at 8 psi of boost the fuel pressure should be 13 to 15 psi.
The outer edge of the fuel lines need to be sealed to pressure box.
There are a number of mods needed due to the fact that we are not enclosing the entire carb. The Holley manual has a chapter on the mods needed to pressurize the carb from the top. The yahoo blow-through-carb user group also has plenty of information on the mods needed. Basically you need to eliminate the power valve (it is a back fire problem any way on older carbs) and re-jet 2 - 3 size up to compensate the power valve loss. You also need to change fuel floats to non-collapsible type, and seal vents of the fuel bowls. You also need a boost reference line to seal the throttle shafts and that is done from the bottom of the carb via a small spacer drilled in the proper place to align with the shafts.
The carb full enclosure is a big project ($ + many technical requirements) due to the number of items that need to be able to interact with the carb (fuel lines, linkage, other hoses) additionally the space requirements are a problem on the L6 and under the hood space. We are still going to have some clearance problems so we are probably going to open the hood area above the Turbonetics intake plenum and add some kind of a scoop or bubble (like Mitsubishi Eclipse hoods) just to make sure we have no issues there. The installation should look pretty clean. By the way the intake manifold is the old Bob Sharp racing 4-barrel manifold. Similar to the one that Arizona Z car sells I believe.
