Shake in turns
In my Z on the highway doing around 75mph, when I'm in a long curve, the steering wheel has a strong shake in it, but when I'm in a straight line it's fine. Any ideas what is causing this? Front wheels have been balanced many time because of this, and the whole front end is rebuilt with poly bushings. The only thing not rebuilt were the inner rack ties. Help this is driving me nuts!
Wheel bearings: I don't remember if I put news one in or not, I'll have to check my records on that.
Wheel balancing: One is balance on both sides, because the problem started after I had a new valve put on that wheel, so I re-balanced it. The other wheel is balanced on the inside only, but I didn't have a problem until that valve. I don't think it is the problem, because I balanced it 3 times, and it doesn't shake going straight.
Inner tie rods/tires: When i replaced the outer tie rods, cleaned, adjusted, and added new boots to the rack, the inner tie rods seemed to be solid.
The tires are new.
Guest Anonymous
Mike, I had this problem for a while and finaly ended up indexing my wheels to the hubs each time I had new tires put on the car. It seem to have solved my problem.. When I would remove a wheel and put it back on, I would have a shimmy until I marked the wheel and a wheel stud. The wheels always go back on the hub the same way. Try removing the wheel with the new valve stem and rotate it 180 degrees to the hub and see what happens. Mark
When tires are balanced on the inside only it is called a static balance. I am not an engineer, but from what I've been told static balance only works when the tire is rolling straight. As soon as you turn static balance goes out the window.
I can tell you that balancing with weights on both sides (dynamic balance) is really the right way to do it. Static balance is a joke IMO.
It is also possible that they were balanced dynamically, but one side did not need weights on the outside of the rim to be balanced.
Jon
Do you have wheel spacers? If so I would measure from the od of the spacer to the od of the hub with som calipers to see if you are not off a bit on the hub, but this would shake going straigt.
JM's theory sounds promising.
Many tires have colored dots on the sidewall which indicate mounting location. Depending on manufacturer the colored dot either lines up with the valve, or 180* from the valve, or indicates a 'high spot' on the tire. Contact the tire manufacturer to find out the dot 'coding'. I have yet to find a tire shop that knows this without me telling them how to fit the tires. They will usually just fit them any old way they want. On directional tires, where the dot ends up on the inside of the rim, have them chalk mark the opposite side of the tire to ensure correct fitment.
For Falken Tires (which I use exclusively):
The yellow dot is the lightest spot and it is suggested to mount this above the valve stem.
The red dot is the high point, recommended to be mounted at the low point of the rim if so marked or, preferably, per actual measurement.
Per a product engineer at Falken Tire, these marks are just "starting" points for the tire installer to effectively mount your tires. With some of the new balancing equipment out there, the machine can do a more accurate job matching and balancing then simply relying on these dots alone.
Otherwise my $$ are on ball joints.
Tim
