Speaking of 18's....pic of 350z wheels on my z
Thanks for the compliments. The wheels are 18x8 with a 30 offset all around. The wheels I normally run are 18x8 +20 in back and +40 in front with a small spacer. I was really suprised at how well these 350z wheels fit. Looks almost like they were made for the 280z. My friend is trying to get a set of the 18" Volk wheels from a 350z to see how they look as well. If I can get my hande on some of the G35 wheels I would like to try them too.
The brakes on my car are the normal z31 disc/toyota caliper in front and it has conquest discs in the rear.
JT
Kenny
go to http://www.modern-motorsports.com/catalog/product_info.php?cPath=32&products_id=46
You will have to have your rear hubs drilled. Unless you are thinking that that Jtayler has hubs with the same width all the way around' date=' in that case I don't know but I would like too.[/quote']
Yeah, I have seen the modern motorsports redrilled rears, I was just curious if there was another way :cheers:
Guest iskone
There is no other way I know of, maybe you could put the whole rear of a 300zxtt or a q45. Keep in mind that I said "that I know of"
I've thought about that but I didn't get any where on my search.
Guest iskone
JT Did you take your Z for a test drive?
How was it if you did? I don't know what size wheels you usally have so if you could tell me that would be great.
Thanks
