Pic of my new MSA Type 3 Airdam
COZY Z COLE
Guest 74_350_Z
wussup larry
this is Joe from Sears.
looks nice man, are you getting the whole car painted or just the dam?
haha cus I need to paint mine badly... just wondering whos doin your paint
After fitting the new airdam on my 75 280Z these are my observations:
QUALITY. Gel-coat is of of good quality as is the airdam its self.
High grade fiberglass and mat but was not impressed with the grill installation. I would rather of had a removable option of the grill and the molding could have been done more cleanly.
Driving lights are real cool with a dual lighting system-halo ring light that operates as a driving light or turn signal.
FINAL FIT. On the top lip. on the end of both sides,you have to trim the final 4 or 5 inches to fit to the front of the wheel well. The 2 back tabs in the picture on mine needed 3 holes drilled in each for bolt attachment to the car. I removed the mounting bracket on the lights, used 2 brackets for each using their screw holes on the outside of the airdam light holders.
Guest ON3GO
you had to remove 4 to 5 inchs off both sides!!! did i read that right?
even if you had to remove 5 inchs of anything on that i would be pissed!
mike
No, I'm not mad because this is the 3rd airdam I've mounted and everyone needed to have some trimming done because after 25 plus years no car is even side to side especially high proformance ones. The 4 to 5 inches doesn't mean into the airdam but trim to fit length wise to the body. This was certainly no surprise to me. Very little work was needed for final fit and I'm happy!! :D
LARRY
