Looks like I'm going External...
After some discussions with Pete's engine builder I have decided to go external balancing on the rebuild of my 383 stroker... Looks like I'll need to get another harmonic balancer (External), a flywheel setup for a Tremec or Richmond tranny, and start assembling. Other than rings and main bolts, and cam bearings, I'm pretty much ready to put this thing back together... Oh, I forgot the new oil pump pickup!
Mike
Mike, not trying to be nosey or anything, but why the decision to go external vs internal? Cost? It will be interesting to see how you solve the possible issues with the harmonic balancer in trying to get a reasonably priced one that's the correct size. Arg more money...
Davy
Actually I sold a 6.25 inch HJC unit on this site a while back. I've seen several in Jegs and Summit that aren't larger than 7.5 inches that sell in the $220-300+ Range...
Davy, Pete's builder claims that the amount of weight used in balancing the assembly actually puts undue stress on the crank at the #2 and #4 caps and can actually do more harm than good in a 383 application. He swears that externally balancing a 400 Crank is the only way he would go.
He was also VERY happy to take money out of his pocket to tell me that, and then gave me an address where I could send the parts to if I still insisted on doing it. Guy seems to know what he is tlaking about... Referenced some technical manuals to double check him with.
Mike :D
Wow, that was something I had not heard of before, but I don't doubt it at all first glance. The fact that he steered you away from putting more money in his pocket would make you trust him. Good thing.
Davy
I think some more detail is needed here. The guy that was saying this told me the same thing. I believe it's mostly an issue with cheap imported cast 3.75" stroke cranks, as the strength is already questionable due to material and casting quality, as well as the size of the throws, etc.
No doubt a purpose built internal balance 3.75" stroke forging would be fine, or maybe even an external balance one that was balanced internally later. Better material and process, better dimesions, etc.
Exactly... Guess I didn't make that clear...However, with the abundance of Stroker cranks out there being of the CAST and Nodular type, and most being made by SCAT (Like Mine) you really have to build to the limits or get a good crank... The crank I'd like to get is $800... So it depends... I know a lot of guys out there running 383s externally balanced and doing just fine.
Mike
I have heard no negatives about internally balancing the external crank, but it does make sense. It is also expensive. If you operated at high engine speeds (6500+) for extended periods of time (road racing, Bonneville, Nascar) I'd so go internal, but I think your choice to stay externally balanced doesn't do any harm as that is the way the crank was designed. The real fix is to buy an internally balanced crank to begin with, but then it is no longer a "cheap" way to get more cubes, but an expensive rotating assembly that will require and expensive set of rods and expensive block, etc. I think Fluidamper has a 6.25 external dampener for $300?
Hey,FYI, I bought the Summit 6.6 external balancer.$224.50,and it's a pretty decent unit.(tested to 18000 rpm) The strange part is that it is the same as the internal balancer,with a weight bolted to the inside.The instructions say to just remove the weight if you want to change it to internal.Maybe they're all like that,this is all new to me. cheers.gif
When I sent my Scat 9000 6" 3.75, internal balance to the engine balancer, it came back with a small counterweight at the rear. Designed to run a regular internal balancer. (should have kept my original fluidamper, Mike, as I bought another!) but apperently even the "internal" Scats, and other brands often need touching up with a counterweight. Why change an externally balanced crank to internal, unless you're trying to fool someone looking under the hood that it's a 350? I chose the 9000 for the issues of recip weight, flywheels, balancers ect. I personally don't know the limitations of the 9000 series for sustained racing abuse, but from what the Scat rep said, it can handle a lot of hp, and make for a durable street motor.
John
Looks like the Crank I was biddingon isn't prefered to be internally balanced with the parts I have. Guy was nice enough to not hammer me for the bid retraction. He also runs an engine assembly house and offered me another crank, and to have me ship out my rods and pistons and balancer and he'll balance everything for me on an eagle 4340 forged crank, and the total cost would be less than $800 for everything, purchase of the crank and balancing...
Gonna call him today and sort it all out, but just read their feedback and they have VERY good comments!
Mike
Mike
