awd92gsx Posted September 7, 2004 Share Posted September 7, 2004 Ok, I searched through the forums, but, couldn't find the answer...or maybe I just didn't see it correctly... Will the JTR 350 kit work for the LS1? Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted September 8, 2004 Share Posted September 8, 2004 The answer is NO!! SBC and LS1 mounting are completely different! Nothing on the 2 are interchangeable. There is always John's or..... P.M. MAS280 and or JTRMIKE. I believe they are working on mounts. GOOD LUCK JOEY Quote Link to comment Share on other sites More sharing options...
Guest plainswolf Posted September 8, 2004 Share Posted September 8, 2004 That is an interesting point. I've long known that the mounts and mount locations are different on an LS1. But perusing through a few magazines, I think it was Car Craft or Chevy High Performance... hell might have even been HotRod, that mentions an LS1 motorMount adapter that allows an LS1 to use the old style SBC mounts. Might be worth investigating. I know in the .PDF catalog from http://www.hotrodlane.cc/ there is also an adapter plate for an LS1 that makes it possible to swap the engine into most older types of cars that origionally came with a 1st.Gen. SBC. It looked like a rectangular plate that bolts to the side of the LS1 block that allows the engine to be mounted from the front of the block using the older style sbc mount.. Whether something like that would work with the JTR kit I would have no clue. But something like that might be about the closest thing to it.. Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted September 8, 2004 Share Posted September 8, 2004 Hey Plainswolf, Funny you bring up this topic.... When I first bought my LS1 set up. The guy who sold me my motor offered to sell me adpter plates to use older style mounts. I contacted JTR (Mike Knell). He blew me off saying "I'm a dreamer!!" Thanks Mike! :malebitchslap: Just kidding Mike! John at John's Cars kept on telling me I didn't need adapter plates. John was right and that's the route I went..... To answer the question... I'm not sure if anybody has used adapter plates to mount the LS1 into a Z JOEY Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted September 8, 2004 Share Posted September 8, 2004 JTR is working on the LS1 type of motor mounts. It may be a couple of months before they are in production. One thing to note is that the 4.8, 5.3 and 6.0 truck engines are based on the LS1, and according to a reliable source (MAS280), an LS1 intake manifold can be installed on the truck engines, which will provide enough hood clearance so that they can fit in a Z car. A 5.3 truck engine puts out more power than a Camaro LT1 engine, and the 5.3 truck engines are less costly than the LS1 engines. The truck engines have aluminum heads, and they appear to weigh less than a Camaro LT1 engine. A 6.0 engine from an Escalade is rated at the same horsepower as an LS1, but weighs about 70 lbs more due to the iron block. Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted September 8, 2004 Author Share Posted September 8, 2004 Quote John at John's Cars kept on telling me I didn't need adapter plates. John was right and that's the route I went I'm not sure if I understand that correctly... Are you saying that you didn't need adapter plates to use the JTR kit? [edit] In either case, it looks like I'll probably be going the older style 350 route. I found an old friend that has an older El Camino. He's selling me the entire car for $500 and I've already got the JTR kit. Thanks for the replies guys. Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted September 9, 2004 Share Posted September 9, 2004 Hey AWD92QSX, JTR and John's cars are two different companys. JTR said they should have mounts ready in the next couple of months. Johns is what I used. 77 280z, no adapter plates, pretty much all bolt in. I love the car and have no complaints. The look,power and drivability of the LS1 is hard to compair to. JOEY Quote Link to comment Share on other sites More sharing options...
Guest plainswolf Posted September 9, 2004 Share Posted September 9, 2004 WOW! I simply had no idea that JTR was working on an LS1 swap(been working far too much overtime lately). And it will be fascinating to say the least to see what they come up with! Guess it will be time soon to happily update my "hybridZ Bible" I had also merely wondered if an LS1 with the traditional block mount adapters (wich allow the old style sbc mounts to be used in the old mount location on an LS1 engine) would work with the JTR mounts, but looks like that is a non-issue now with a growing number of swap kits out there! I can only thank the LS1-Z swap pioneers for giving the rest of us such encouragement on this. I think I'll wait awhile now to see what JTR comes up with before doing anything. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted September 9, 2004 Share Posted September 9, 2004 Quote WOW! I simply had no idea that JTR was working on an LS1 swap(been working far too much overtime lately). And it will be fascinating to say the least to see what they come up with! Guess it will be time soon to happily update my "hybridZ Bible" I had also merely wondered if an LS1 with the traditional block mount adapters (wich allow the old style sbc mounts to be used in the old mount location on an LS1 engine) would work with the JTR mounts' date=' but looks like that is a non-issue now with a growing number of swap kits out there! I can only thank the LS1-Z swap pioneers for giving the rest of us such encouragement on this. I think I'll wait awhile now to see what JTR comes up with before doing anything.[/quote'] The mounts the JTR are going to make are the ones that MAS280 designed. They are going to produce them with MAS280's permission. Quote Link to comment Share on other sites More sharing options...
lilj Posted September 24, 2004 Share Posted September 24, 2004 where can johns mounts be had? and would they work in a zx? -jon Quote Link to comment Share on other sites More sharing options...
Guest DiZeased_240 Posted September 24, 2004 Share Posted September 24, 2004 Here is the link. http://www.brokenkitty.com/zcar/zcar.htm Unfortunately for the zx owners, the kit will not work. Quote Link to comment Share on other sites More sharing options...
titanium Posted February 13, 2006 Share Posted February 13, 2006 Sorry to Rez such an old thread but can you just use LS1 Adaptors on JTR mounts to make this work? Quote Link to comment Share on other sites More sharing options...
flicktitty Posted February 17, 2006 Share Posted February 17, 2006 any word on anyone making mounts for LS1's yet? Quote Link to comment Share on other sites More sharing options...
Custom Posted March 24, 2006 Share Posted March 24, 2006 Quote JTR is working on the LS1 type of motor mounts.It may be a couple of months before they are in production Does JTR have LS1 mounts? tried searching but found contradicting answers. Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 24, 2006 Share Posted March 24, 2006 Both JTR (Jags that run) and Johns Cars (www.brokenkitty.com) make mounts for LS1 engine conversions in S30's. They do not make them for the other models. If you want them for an S130, Z31 or Z32 contact John at Johns Cars (214) 426-4100 and talk him into it. I know he has S130 & Z31 rollers on his lot to do just that if the demand is there. Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 24, 2006 Share Posted March 24, 2006 Quote Both JTR (Jags that run) and Johns Cars (www.brokenkitty.com[/url']) make mounts for LS1 engine conversions in S30's. They do not make them for the other models. If you want them for an S130, Z31 or Z32 contact John at Johns Cars (214) 426-4100 and talk him into it. I know he has S130 & Z31 rollers on his lot to do just that if the demand is there. JTR has mounts for LS1 engines in an S30? They must have come out recently...there's no mention of it on their web site (unless I'm missing it)? Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 24, 2006 Share Posted March 24, 2006 Maybe I'm on drugs again? I know they have headers that work with the LS1 in S30's so maybe I was just assuming? I really thought I'd read somewhere that they had them. Oh well - JCI does and they are good units. Mine have held up for 3 years and over 20,000 miles now with no problems. Quote Link to comment Share on other sites More sharing options...
