Guest V8Z Posted November 7, 2004 Share Posted November 7, 2004 Hi, I installed new door seals today and now I have slam the heck out of the door just to make it shut. I tried moving the striker around but it didn't help. and if it did help then the door gaps were off. Any help! Thanks Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted November 7, 2004 Share Posted November 7, 2004 These weren't by any chance aftermarket door seals. I had similar trouble with some aftermarket seals, and finally had to bite the bullet and get Nissan OEM seals. Even the OEM replacement seals are a little tight when first installed. Good luck Quote Link to comment Share on other sites More sharing options...
LS1240Z Posted November 8, 2004 Share Posted November 8, 2004 It's normal for you to slam it if the rubbers are new.They need to about 8 months to a year to break in.I thought the same thing till someone else told me....they were right.They broke in just fine. Quote Link to comment Share on other sites More sharing options...
Dead Roman Posted November 8, 2004 Share Posted November 8, 2004 id rather be slamming the doors then have em fit loose and rattle ! Quote Link to comment Share on other sites More sharing options...
Guest V8Z Posted November 8, 2004 Share Posted November 8, 2004 These are precision replacment part is the name brand of the seal. The rest of the seals fit very nice. Maybe I'll give it a little time an see if they break in. Thanks for the responses. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted November 8, 2004 Share Posted November 8, 2004 Door alignment is quite an art... expect to spend an hour per door getting them right! Edit: I've found the Nissan seals work quite well and allow the doors to close pretty well too. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted November 8, 2004 Share Posted November 8, 2004 We have been telling Precision that their seals are to thick and firm for years but they have never changed them. You will be slamming your doors forever! They only one's that work right are the factory seals. They aren't cheap but they work. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted November 9, 2004 Share Posted November 9, 2004 I feel I should say something about this.. I replaced the one on my passenger door with something I found at a J/Y; Renault Aliance. (sp?) I cant remember what I used for the drivers side (there was only one on the Renault), but I have to slam the heck out of it (got to find another aliance!) and I'm afraid I'll break the glass one day. The pasenger door closes almost perfect though. Just a thought on a cheaper solution.. Quote Link to comment Share on other sites More sharing options...
Guest V8Z Posted November 9, 2004 Share Posted November 9, 2004 I went and got my old seals out of the trash can and I think I will try and clean them up with some good degreaser. There not torn or broke, I just had my car repainted and the buffing compound got on everything and turned a crusty white. But man those doors close so good with the old seals. Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted November 9, 2004 Share Posted November 9, 2004 Okay, I think I have asked this once before a long time ago, but can you soak the thicker foam rubber doorstripping in something to make them more pliable? Or just do something to make them a little more flexible? !M! Quote Link to comment Share on other sites More sharing options...
Ferd/289 Posted November 11, 2004 Share Posted November 11, 2004 You can adjust the door frame around the glass of the front doors. I used aftermarket door seals. The window framing, is a seperate piece held to the door via bolts you can easily see. When I adjusted mine for the same reason, I placed 4 or 5 aluminum washers on the bolts that holds the window part of the door frame to adjust outward about 1/4 inch. You dont have to take the window out, merely crank it down into the door. Its still a little tight but I did not want any leaks. The door closes nicely with a normal slam. Ferd Quote Link to comment Share on other sites More sharing options...
Guest V8Z Posted November 11, 2004 Share Posted November 11, 2004 Now thats what I was wanting to here!!!! Thats pretty slick thinking Fred. 8) I will try this in the morning. Thanks Quote Link to comment Share on other sites More sharing options...
Owen Posted November 12, 2004 Share Posted November 12, 2004 And then there's the McMaster-Carr stuff that works just awesome. Don't know the P/N but it's here somewhere. Owen Quote Link to comment Share on other sites More sharing options...
gnosez Posted November 18, 2004 Share Posted November 18, 2004 Try spraying the seals with silicone, shut the door and leave out in the sun for several hours if possible. Repeat. The silicone shrinks the rubber but don't so this if you have any plans on taking your Z to an autobody shop real soon (silicone will contaminate the shop). Quote Link to comment Share on other sites More sharing options...
