joe3z1988 Posted December 15, 2004 Share Posted December 15, 2004 What problems do you for see if I turboed a N/A 88 300zx. The car has the following mods 1. Port and polished heads 2. Cams (Lift(In/Ex): .435/.435. Duration(In/Ex): 280/280) 3. 2.5 exhaust Not only the problems that I may encounter, I also need to know what parts (besides the turbo and low compression pistons (which I am not going to use) I need to keep this thing safe and running. Quote Link to comment Share on other sites More sharing options...
stinky Posted December 16, 2004 Share Posted December 16, 2004 Do some thorough searching on z31.com. There is a lot of information contained there including a writeup on the conversion. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted December 18, 2004 Share Posted December 18, 2004 Are you planning on custom making exhaust manifolds? In the stock setup the turbo is mounted in the same place as the n/a engine mount. So if you want to use the stock turbo exhaust manifold then you'll have to move the engine mount. It would probably be easier to get your hands on a complete turbo donor car and take everthing. (including the crossmember) Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 18, 2004 Share Posted December 18, 2004 Not only the problems that I may encounter' date=' I also need to know what parts (besides the turbo and low compression pistons (which I am not going to use) I need to keep this thing safe and running.[/quote'] Safe and running would be using turbo pistons, atleast if they are the same as L motors the turbo piustons have thicker ring lands and are more forgiving to detonation. You will need a way to increase fuel and retard timing under boost. HKS or SDS AIC and MSD boost retard would be the easiest. Do you know the overlap on your cams. "Big" N/A cams with alot of overlap can performance. More exhaust pressure than intake pressure. Quote Link to comment Share on other sites More sharing options...
BunnySlippers Posted November 2, 2009 Share Posted November 2, 2009 Parts needed from a turbo car: Driver side exhaust manifold, turbo, O2 housing elbow, down pipe, engine crossmember, driver side engine mount bracket(the part that bolts to the block), intake piping, ECU, injectors, oil pan(or cut a hole and weld on a fitting for turbo oil return line), turbo oil feed and return lines, and that should be about it. I'm getting ready to do this same thing on my 88. Going to turbo the 9:1 pistons. Porting and polishing the heads now. Quote Link to comment Share on other sites More sharing options...
softopz Posted November 8, 2009 Share Posted November 8, 2009 WOW even the engine cross member is different? Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 12, 2009 Share Posted November 12, 2009 theres an enitre z31 turbo car here in killeen, tx. its a far drive but it might be better to have the whole car. odometer has 149K on it. and the motor doesnt look too bad. i was there today... Quote Link to comment Share on other sites More sharing options...
hoov100 Posted November 12, 2009 Share Posted November 12, 2009 for a general N/A-T swap, crossmember, driverside motor mount, driverside exhaust manifold, intake piping, ECU, injectors, turbo, down pipe, exhaust, boost gauge. I havent seen a VG30 blow up a bottom end from boost yet. Quote Link to comment Share on other sites More sharing options...
