280zx turbo hp rating
Wide260z
What kind of power the bottom end can take depends more on the machining, assembly, and how its run then on the basic design and metallurgy. With forged pistons, custom rods (Carillo), dry sump, custom crankshaft, and other mods the Electramotive guys ran 600+ horsepower in race trim and around 700 hp in qualifying trim.
Now, don't just list your mods and expect us to be able to give you a sensible answer. You'll have to do some testing to come up with a reasonable limit based on the quality of your machinist, how well the parts are assembled, and how you use the engine (ie: road racing is much harder on an engine then drag racing and drag racing is harder on an engine then street driving.)
The stock bottom end is very strong. For a street/strip car the stock components will take almost anything you can throw at it.
A buddy of mine is still running a bone stock never touched F54 bottom end (225K KM) on his turbo 240z and it runs 12.6@114.
My 260z was freshened up (new rings and bearings but all other components stock original nissan 220K KM) and it runs 11.78 @ 115.
Both cars are street driven often and dead reliable. The most important thing to make it last is proper A/F ratio and ignition timing. Without these even the best forged pistons will fail. Spend your money on good fuel and ignition systems and turbo components and the stock bottom end will work fine untill you are making huge HP.
You will be scattering drivetrain peices way before engine components!!
  • 3 weeks later...
Ive seen stock et ringlands take 350hp without issues, and also seen flattop piston ringlands blow themselves off the piston at 300rwhp and too far advanced timing. I believe most forged piston designs have the ringland issue addressed. I myself believe that the L28et is indestructible 300hp and below with a stock block and good efi.
No doubt that 300whp and below the motor is damned hard to break.... but it's just SO easy to make 300whp on the damned thing it's hard NOT to break it. :lol:
Speaking from expierence here.
