Stealth-Z Posted February 27, 2005 Share Posted February 27, 2005 Here are some photos of different mounts I have come across. The mounts on the left were made by Brad D. The ones on the right were made by Castlemaine Rod Shop in Australia. There part number is EM81 3 Litre Turbo RB30 To Datsun 260Z http://www.rodshop.com.au/mounts.htm I have not noticed any difference between the RB series block mounting points. The RB20 and RB30 blocks I have both line up the same. From the photos you can see the Castlemaine mounts position the motor about an inch lower. Brad D was selling mounts at one time for $100.00US. The Castlemaine versions are around $150 Australian. I purchased them from a guy that mistakenly bought them for his Skyline. Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted September 7, 2006 Author Share Posted September 7, 2006 Instead of creating a new thread, might as well use this one I created a while ago. My RB30 is still in the machine shop being balanced. So I got tired of not being able to do anything with the mount situation. Below are photos of the Castlemaine Rod Shops motor mounts using a RB20 block mated to the RB25 trans. The transmission shifter location is right on target. Still need to fabricate some new "Ears" using the original Z trans mount. I had to cut out the original factory setup. Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted September 7, 2006 Share Posted September 7, 2006 Off topic, but who's doing your engine work? Quote Link to comment Share on other sites More sharing options...
turbo_fb Posted September 7, 2006 Share Posted September 7, 2006 I see the engine is tilting slightly to the right. Is that standard? Anyone tryed to tilt it to the left to get more room for turbo or anything? Great pics btwn. Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted September 7, 2006 Author Share Posted September 7, 2006 Off topic, but who's doing your engine work? Cascar Machine Shop. http://www.cascarmachine.com/ They are on 47th Ave. I see the engine is tilting slightly to the right. Is that standard? Anyone tryed to tilt it to the left to get more room for turbo or anything? The RB motors sit at a tilt just like the L series do. As for tilting more to the left, I remember reading a thread a while back about putting some spacers in to do it. Quote Link to comment Share on other sites More sharing options...
Z24O Posted September 8, 2006 Share Posted September 8, 2006 hi guys a friend of mine fabricated a set of mounts for me 4 years ago....before the aussie mounts were available he originally used the 240/260 rubber mounts but said that the weight/hp of the rb30et was too much for the datsun rubber blocks,as well as the fact that they don't have a failsafe steel locking system incorporated in them he ended up using the donor engines ones which are the aussie vl commodore my friend has an engineering background and the mounts he made have worked well......anyone had problems with failure of the rubber mounts with the castlemaine kit might as well know before you use them cheers paul WA Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted September 15, 2006 Share Posted September 15, 2006 Hi Paul, are you suggesting I should use the VL Commodore mounts rather than standard 240Z ones with the Castlemaine brackets? regards Mike Quote Link to comment Share on other sites More sharing options...
Z24O Posted September 18, 2006 Share Posted September 18, 2006 Hi Paul' date=' are you suggesting I should use the VL Commodore mounts rather than standard 240Z ones with the Castlemaine brackets? regards Mike[/quote'] g'day mike it's a while since my conversion was done,have a look at the commodore mounts compared to the stock Z mount....if they look interchangeable i'd go with the commodore one as it is designed to handle the rb turbo's torque failing that have a look at my car when you get time regards paul ps i drove my silver Z round to your place last saturday arvo,you were obviously out Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted September 18, 2006 Share Posted September 18, 2006 g'day mikeit's a while since my conversion was done' date='have a look at the commodore mounts compared to the stock Z mount....if they look interchangeable i'd go with the commodore one as it is designed to handle the rb turbo's torque failing that have a look at my car when you get time regards paul ps i drove my silver Z round to your place last saturday arvo,you were obviously out[/quote'] thanks Paul, will do regards Mike Quote Link to comment Share on other sites More sharing options...
DJACEY Posted March 12, 2007 Share Posted March 12, 2007 Following on from the previous posts. I'm looking for mounts to install an RB25DET into a 240Z and have seen three possible options - sets supplied by Shouri Motorsport, Arizona Z and McKinney Motorsports. Not too sure which one to go for - is one better than the other two or is there another one I haven't seen which is better still ? I notice that McKinney also supply the transmission mount which would make installation easier I guess. Your feedback would be appreciated as I want to order them soon. Thanks. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted March 12, 2007 Share Posted March 12, 2007 Following on from the previous posts. I'm looking for mounts to install an RB25DET into a 240Z and have seen three possible options - sets supplied by Shouri Motorsport, Arizona Z and McKinney Motorsports. Not too sure which one to go for - is one better than the other two or is there another one I haven't seen which is better still ? I notice that McKinney also supply the transmission mount which would make installation easier I guess. Your feedback would be appreciated as I want to order them soon. Thanks. look for ricky wong or 240z master "Q". this guys have excellent products and for way better price. Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted March 12, 2007 Share Posted March 12, 2007 I just recieved a set of Rick Wongs mounts today that I bought from a fellow Hybrid Z'er. They are beautiful. Theyre milled from a solid block of aluminum so theres no welds to fail. Do some searching, you'll find a link to Ricks co. Quote Link to comment Share on other sites More sharing options...
Thanh Posted March 13, 2007 Share Posted March 13, 2007 Couldn't find the link for the RW mounts. help? Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted March 13, 2007 Share Posted March 13, 2007 I'll see if I can find is contact info for you, and pm it to you. In my opinion these are the best mounts you can get. granted I've yet to actually by my engine. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted March 14, 2007 Share Posted March 14, 2007 I would sale my RW motor mount and used supra insolator for $280.00 plus S&H... anybody? Quote Link to comment Share on other sites More sharing options...
Careless Posted March 14, 2007 Share Posted March 14, 2007 question... why are the mounts pictured in the first post both using a plate steel fabricated part, as well as a bar stock fabricated part. why not both of one, or both of the other? any reason? or are they actually paired vertically rather than horizontally.? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 14, 2007 Share Posted March 14, 2007 The left (upper and lower) are from one maker, and the right (upper and lower) are from another.... question... why are the mounts pictured in the first post both using a plate steel fabricated part, as well as a bar stock fabricated part. why not both of one, or both of the other? any reason? or are they actually paired vertically rather than horizontally.? Quote Link to comment Share on other sites More sharing options...
Careless Posted March 14, 2007 Share Posted March 14, 2007 ahhh ok. LoL. forgive me, i just woke up =( so tired. but i can't stop thinkin about my z Quote Link to comment Share on other sites More sharing options...
Thanh Posted March 14, 2007 Share Posted March 14, 2007 ahhh ok.LoL. forgive me, i just woke up =( so tired. but i can't stop thinkin about my z It was the crust in the eye that threw you off Quote Link to comment Share on other sites More sharing options...
Careless Posted March 21, 2007 Share Posted March 21, 2007 It was the crust in the eye that threw you off are you implying that the tears i cry when i think about my z are drying away and leaving residue in my eye Quote Link to comment Share on other sites More sharing options...
