Guest Ground Rat Posted April 26, 2005 Share Posted April 26, 2005 Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted April 26, 2005 Share Posted April 26, 2005 Ouch!! Hope you get it running soon!! Are the roller rockers a good "bang for the buck" mod? Quote Link to comment Share on other sites More sharing options...
Guest Ground Rat Posted April 26, 2005 Share Posted April 26, 2005 Ouch!! Hope you get it running soon!! Are the roller rockers a good "bang for the buck" mod? I would say yes, although they were already on the engine when I bought it. I'm looking for a stroker kit now. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 26, 2005 Share Posted April 26, 2005 Did you hydraulic that cylinder? Quote Link to comment Share on other sites More sharing options...
Guest Ground Rat Posted April 26, 2005 Share Posted April 26, 2005 Yeah man, the car sat in the rain for a month when I went TDY. I thought it had been covered the whole time so I tried to start it when I got back. Bad idea. Quote Link to comment Share on other sites More sharing options...
Cruez Posted April 26, 2005 Share Posted April 26, 2005 I hydrolocked a 396 in a '68 Camaro a few years ago,. The hood was cut for the two Holleys and the high rise intake to clear, but I didn't have a scoop yet...........It took only 1 thunderstorm. I think you would only make that mistake once in a lifetime. You learn the hard way. Quote Link to comment Share on other sites More sharing options...
ZHeadV8 Posted April 27, 2005 Share Posted April 27, 2005 I have never ever heard of "hydrolocked" in the Uk - are you telling me that if it rains the water gets into the bores ? If so how the f*** does it do that ??????? The only way I can see is either down the plug thread or through the fuel system ? Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted April 27, 2005 Share Posted April 27, 2005 A couple of valves will always be open, if water gets in the induction it will find the open cylinder, water doesnt compress much Quote Link to comment Share on other sites More sharing options...
Guest Ground Rat Posted April 27, 2005 Share Posted April 27, 2005 A couple of valves will always be open' date=' if water gets in the inductionit will find the open cylinder, water doesnt compress much[/quote'] Werd. It doesn't compress at all, lol. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted April 29, 2005 Share Posted April 29, 2005 Yep, no hood with a open element filter that draws through the top of the motor will let water in I'm sure. What a pity. Time for a 383! Good luck with the repairs. Davy Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted April 29, 2005 Share Posted April 29, 2005 A stuck float with an electric fuel pump will do the same thing. Seen it done. Wierdly enough also with a 396 camaro Quote Link to comment Share on other sites More sharing options...
Guest Ground Rat Posted May 10, 2005 Share Posted May 10, 2005 Time for a 383! Good luck with the repairs.Davy Thanks, I'm building a 388 stroker right now. Quote Link to comment Share on other sites More sharing options...
