Guest 73Turbo240z Posted May 15, 2005 Share Posted May 15, 2005 Alright, we just assembled the L28 today, we've rotated the entire assembly and checked to make sure it doesn't interfere anywhere, and it doesn't. We were going to put the dizzy on to set it where it needs to be for proper ignition timing, we installed the timing degree plate on the right hand (driverside) of the crank pulley, then rotated it to 0 degrees, that doesn't put piston 1 at TDC though (piston closest to water pump), so we then instead rotated the cam markings untill they were aligned @ TDC on #1, which now places the crank pulley way off to the left of the timing mark of 0... so we dunno if we placed the placard for timing degree's in the wrong spot, or if we dicked up the order of operations or what... photos are attached if anyone has a guess as to what we did wrong, as i said before, we did the chain to the proceadure in the FSM, dimples on crank and cam pulleys to the 2 lighter/unique links in the timing chain, and we've rotated it fully a number of times and verified that the valves do not hit the pistons, it's just this last little issue that's holding us up... ideas welcome... Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted May 15, 2005 Share Posted May 15, 2005 up... anyone? Quote Link to comment Share on other sites More sharing options...
Thumper Posted May 15, 2005 Share Posted May 15, 2005 I believe the timing plate goes on the passenger side. Also I think 73Turbo240z is trying to use a l24 timing plate on a l28 engine. I think the mounting holes are different but can not confirm this, can anyone? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted May 15, 2005 Share Posted May 15, 2005 All my timing plates have been on the passenger side of the motor. Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted May 15, 2005 Share Posted May 15, 2005 hmmm... someone mind digging up a photo of there L28 crank pulley area w/ the timing plate mounted? perhaps i'm just being blind cause we didn't see a workable mounting solution on the passenger side, but then again we might have been using the L24 plate.. either way a pic should resolve this easily. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 15, 2005 Share Posted May 15, 2005 L24 has a pointer and the L28 has a thing that looks like a sawblade with a bunch of teeth and also has number stamped on it. This is because the L28 has a single mark on the crank pulley and the L24 has a bunch of marks on the pulley. At least that is the way it works with NA engines. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted May 16, 2005 Share Posted May 16, 2005 Take a look at one of my pages on my site. http://www.angelfire.com/space/nismo1turbo/indexenginebuildup.html Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted May 16, 2005 Share Posted May 16, 2005 As previously mentioned the 280 Z will have the saw tooth marker plate mounted on the passenger side with two bolts to the aluminum timing chain cover...The two required different sized bolts for the timing maker are seperated in distance by about two inches...and the outer timing marker larger bolt is also utilized as a timing chain cover bolt..... ............................with the two bright links of the timing chain on the corresponding cam and crankshaft at TDC the notch in the cam sprocket should show a witness line on the cam tower. All the Z's and L 20 B engines were always timed from the passenger side and the older ones as Mr. Mortenson explained have the single pointer mounted to the timing chain cover with the crankshaft pulley notched for timing marks.And as Thumper opines: "you may have the 240 pointer on the wrong side of the 280 timing chain cover" Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted May 20, 2005 Share Posted May 20, 2005 alright, i took photos of where the plate was, as you can see it is the "saw" faced plate, i also shot photos of the other side, w/ the plate detached, so you can see what i have to work with, nothing lines up... click the thumbnails for larger res images... as i had it, clearly not working another view of how i had it... photo of the work area, anyone care to shoot a photo of there L28's timing mark up close so i can see for myself? the one angelfire link didn't have any closeups i could use. Quote Link to comment Share on other sites More sharing options...
Guest DoTheDrew888 Posted May 20, 2005 Share Posted May 20, 2005 Well, it looks like you have the wrong little plate. On mine the plate is larger and bolts to the hole closest to your thumb and the hole close to you index finger in the last picture. Obviously the hole on the bottom of the plate is bigger than the hole on the top of the plate because the bolt is larger on the bottom. I would suggest going to a scrap yard and pulling a plate off of a 280ZX. Quote Link to comment Share on other sites More sharing options...
Wagz Posted May 20, 2005 Share Posted May 20, 2005 Here's a shot of mine. Unfortunately, I just put the radiator back in a few nights ago and couldn't get a better angle. It does look like your pointer is reversed from what I have. The problem with my car is that it's been bastardized. 260 chassis, 280 motor and 240 intake/carbs. So, I can't say for sure where my pointer came from. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted May 20, 2005 Share Posted May 20, 2005 Your second pictures shows that your marker is directly above the correct mounting holes ...the smaller hole closer to water pump and the larger hole connecting the timing chain cover to block... about 2 inches appart Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted May 21, 2005 Share Posted May 21, 2005 well it just got more complicated, i found the other timing plate, except it too... doesn't line up with the holes, i'll have some photos of it tommorow... this is getting quite frustrating. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted May 22, 2005 Share Posted May 22, 2005 Wag Z has the right marker.. If you cannot find one.. contact me with private message and your addtess. I wiil send you one off a 1977 Z Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 22, 2005 Share Posted May 22, 2005 I scavenge TURBO indicators wherever I can get them. They are degreed to 30. When I set up the engine, and am in the process of verifying TDC with the indicator on the piston top, I have ALWAYS aligned the marker I bolted onto the engine and a mark I MADE by filing into the pulley. Sometimes the mark from the factory is close, other times not. Expecially on Chevy's and used pulleys meaning the elastomer is going out. In either case, you can verify TDC with the head on through #1 spark plug hole, and mark YOUR pulley according to wherever your timing marker SHOULD BE. Even with the old 240 style "Pin Marker" with a dial in advance timing light, you can still set whatever timing (initial or total) that you want using this method. In some cases I have made a pointer out of welding rod and a piece of sheetmetal. It doesn't matter what indicator you use, it matters that the mark on the pulley is CORRECTLY ALIGNED. Quote Link to comment Share on other sites More sharing options...
