heavy85 Posted July 13, 2005 Share Posted July 13, 2005 I noticed a little slop between the drivers side companion flange and stub axle of my 240. I could rock the companion flange back and forth slightly when the wheel was locked which I think is the primary contributor to my rear end clunk. So I took the companion flange off and the slines look OK but I still think they are a little too loose and obviously the axle nut was not very tight (although being peened it was hard to get off ... but nothing a 3 ft cheeter bar couldn't handle). There is a thin copper washer that goes between the companion flange and the inner wheel bearing. This washer (shim maybe?) does not show up in the Haynes manual so I'm wondering if it's suppose to be there and maybe that is why the nut loosened up and as a result the splines are getting a little worn? Anyone know why that copper washer is in there? I'm thinking of just tightening it back down and calling it good until winter but probably should replace them at some point since the splines aren't tight anymore. Thanks Cameron Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 13, 2005 Share Posted July 13, 2005 You want to use the washer, as they are on some but not other stubs. I can't explain why some have them and some don't, but it is that way on my 74. One side had it and the other did not... Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 13, 2005 Share Posted July 13, 2005 Read zcarnut's post #10 on this thread: http://forums.hybridz.org/showthread.php?t=101811 Quote Link to comment Share on other sites More sharing options...
blueovalz Posted July 13, 2005 Share Posted July 13, 2005 It's hard to imagine the CF being loose being it compresses the inner races for the wheel bearings. But I'd go ahead and tighten it down all the way, and drive the car, testing for bearing noise. Quote Link to comment Share on other sites More sharing options...
Dave Posted July 13, 2005 Share Posted July 13, 2005 I found the same copper washer and loose axle flange on my 71 240Z. I pulled both flanges to remove the copper washers and and just put it all back together less the washers using new nuts and the 280Z torque specs "180 to 240 ft-lbs" Its been a couple years since I did it and everything is tight and working well. Quote Link to comment Share on other sites More sharing options...
heavy85 Posted July 14, 2005 Author Share Posted July 14, 2005 Thanks for the info. I'll have to buy a couple of nuts and go from there jmortensen - you must be a master searcher as I cant seem to find what I'm looking for when I search. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 14, 2005 Share Posted July 14, 2005 No, I just remembered learning what they were for, and who told me. Quote Link to comment Share on other sites More sharing options...
