Guest coolmesser Posted July 27, 2005 Share Posted July 27, 2005 So now I have this "Mr. Goodwrench" 350 sitting in front of me. Before I take it to the mechine shop I am wondering what headers others have used with the 350 (or 383 I guess as well) that cleared using the JTR mounts in my '78 280. tried the search and kept finding other engines discussed. any direction would be helpful. you guys rock. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted July 27, 2005 Share Posted July 27, 2005 S&S full length, you can get them from JTR or straight from S&S, cheaper from S&S. Quote Link to comment Share on other sites More sharing options...
wheelman Posted July 27, 2005 Share Posted July 27, 2005 Headman tight tubes. I have an iron head LT1 but the basic engine is still the same so they will fit yours. The only problem I've had is a burned plug wire caused by the LT1 routing and the close fit of the headers to the block. Wheelman Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted July 27, 2005 Share Posted July 27, 2005 While we are on this subject, Has any one used headers designed for a sbc into a 55-57 chevy. They look a lot like the .........Bugger, who makes them.......The ones Mike Kelly sold a while back. Help Mike! Any way the ones mike has and a few others have were designed for a sbc into something like a 32 ford. Ones for the 55-57 chevy looked bloody similar and there are a few co's that make long tube headers for that aplication. Might be worth a look. Douglas Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted July 27, 2005 Share Posted July 27, 2005 A set of $60 block huggers off of E-bay. (only certain Ebay headers work right) I'm a cheap bastard, but, they fit great! Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted July 28, 2005 Share Posted July 28, 2005 Beware of the cheapo ebay headers. I too went this rout and to my dismay found out that they will not fit my Z. On the passenger side it hits the portion of the radious arm housing that is below the frame rail and on the driver's side it will not clear the steering shaft. I have a set of Sandersons on the way from JTR. I hope this works. I will keep you posted. Quote Link to comment Share on other sites More sharing options...
Guest coolmesser Posted July 28, 2005 Share Posted July 28, 2005 thx for the replies. I am pretty sure I will get the sanderson's also. found out I was gonna hafta get a new starter also. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted July 29, 2005 Share Posted July 29, 2005 We use Hooker headers, made for the chevy v8 for the Datsun Z, I am not sure about the mmounts you are talking about. I just used motor plates. Everything fit pretty good. I also added a rear motor plate as well, this plate fits between the engine block and bell housing. Quote So now I have this "Mr. Goodwrench" 350 sitting in front of me. Before I take it to the mechine shop I am wondering what headers others have used with the 350 (or 383 I guess as well) that cleared using the JTR mounts in my '78 280. tried the search and kept finding other engines discussed. any direction would be helpful. you guys rock. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted July 29, 2005 Share Posted July 29, 2005 Sanderson's arrived last night. I test fit the driver's side and it looks like it will be fine without any contact with the Steering shaft. Have not looked at the passenger side yet but I am sure it will be fine. These headers are a lot tighter than my made in Taiwan "bock hugger type" ebay header were. They bend back towards the engine block whereas the others did not. I will update later on and try to post a pic after I bolt them on the Z. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted July 29, 2005 Share Posted July 29, 2005 Hey coolmesser, welcom to the board! Good to see another Oklahomboy on the site.... I forgot what brand I have, picked them up at a garage sale, but they match the exahust port shape on the heads and have no clearance problems. Quote Link to comment Share on other sites More sharing options...
Guest coolmesser Posted July 29, 2005 Share Posted July 29, 2005 ty bill. and here I thought I owned every old Z in Oklahoma. Quote Link to comment Share on other sites More sharing options...
jack46 Posted July 30, 2005 Share Posted July 30, 2005 Are any of those headers >1 5/8"? Quote Link to comment Share on other sites More sharing options...
nullbound Posted July 30, 2005 Share Posted July 30, 2005 Quote Are any of those headers >1 5/8"? the S&S headers are 1 3/4". Quote Link to comment Share on other sites More sharing options...
The Rototiller Posted July 30, 2005 Share Posted July 30, 2005 Quote Sanderson's arrived last night. I test fit the driver's side and it looks like it will be fine without any contact with the Steering shaft. Have not looked at the passenger side yet but I am sure it will be fine. These headers are a lot tighter than my made in Taiwan "bock hugger type" ebay header were. They bend back towards the engine block whereas the others did not. I will update later on and try to post a pic after I bolt them on the Z. what was the part # on the sanderson headers that fit with the JTR kit.....? and someone mentioned "S&S" headers, are those the same as sandersons? Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted July 30, 2005 Share Posted July 30, 2005 Quote -------------------------------------------------------------------------------- Beware of the cheapo ebay headers. I too went this rout and to my dismay found out that they will not fit my Z. On the passenger side it hits the portion of the radious arm housing that is below the frame rail and on the driver's side it will not clear the steering shaft. I have a set of Sandersons on the way from JTR. I hope this works. I will keep you posted. There are two types of headers generally sold on Ebay. There are the kind that you got...like these (they won't work): http://cgi.ebay.com/ebaymotors/CHEVY-SB-HUGGER-HEADERS-265-283-305-307-327-350-BLACK_W0QQcmdZViewItemQQcategoryZ33631QQitemZ7988999853QQrdZ1 and then there is the other kind, which fit perfectly fine (I am running these on my Hybrid Z): http://cgi.ebay.com/ebaymotors/SB-CHEVY-HEAVY-DUTY-STREET-ROD-HUGGER-HEADERS-SBC_W0QQcmdZViewItemQQcategoryZ34203QQitemZ4564305350QQrdZ1 Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted July 30, 2005 Share Posted July 30, 2005 I went with the El Cheapo block huggers off ebay...guess what? I should have ordered the tight tucks. Big difference. No headaches either. Anyone want a set of chrome block huggers never used? Be great for street rods, not Z cars. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted July 30, 2005 Share Posted July 30, 2005 Sandersons fit great. You may be right Awd92, those do look like the crappy ones I bought over a year ago and are now stuck with. The part number for the Sandersons through JTR (you can see them on their web site by the way) is DAT-402C. That is for the 1 5/8 primary ceramic coated headers that I bought. Nice fit and good looks to boot. I am also using the MSA mounts so they work with that set up as well as the JTR set up. Quote Link to comment Share on other sites More sharing options...
jack46 Posted July 30, 2005 Share Posted July 30, 2005 What is a part number and address for >1 5/8" headers? I tried and can't seem to get their site to open. I have 1 5/8" and they are fine for lower hp but restrictive at higher hp Thanks Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted July 30, 2005 Share Posted July 30, 2005 Quote Sandersons fit great. You may be right Awd92' date=' those do look like the crappy ones I bought over a year ago and are now stuck with. The part number for the Sandersons through JTR (you can see them on their web site by the way) is DAT-402C. That is for the 1 5/8 primary ceramic coated headers that I bought. Nice fit and good looks to boot. I am also using the MSA mounts so they work with that set up as well as the JTR set up.[/quote'] If it makes you feel any better...I have the same set in my garage. I made the same mistake as you did That's why I'm always quick to point out which headers will work and which headers won't...in case anybody uses the search function they'll know. Quote Link to comment Share on other sites More sharing options...
nullbound Posted July 30, 2005 Share Posted July 30, 2005 Quote What is a part number and address for >1 5/8" headers? I tried and can't seem to get their site to open. I have 1 5/8" and they are fine for lower hp but restrictive at higher hp Thanks http://www.ssheaders.com these are not the same as the sandersons. part number 5205 fits our cars, whether using the hooker/scarab, jtr, or msa kit. Quote Link to comment Share on other sites More sharing options...
