rudypoochris Posted August 13, 2005 Share Posted August 13, 2005 What type of steel should motormounts be made out of (the number) thanks! I am inquiring this so that i can have a machine shop make them. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted August 13, 2005 Share Posted August 13, 2005 It all depends on what design you are building. I would use A36 carbon steel for a starting point. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted August 13, 2005 Author Share Posted August 13, 2005 Well i was thinking to CAD them out and send them into a machine shop to be done, there isn't a generic steel that people usually use for this kind of stuff? Also the thickness should be... 1/4" (minimum)?? Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted August 14, 2005 Share Posted August 14, 2005 generic 1/4 inch flat bar steel stock.. what type of mounts require high grade steel, CAD design and a machinist. My JTR mounts were made from generic flat bar stock right off the steel rack and hand cut with a Rigid metal cutting bandsaw Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted August 14, 2005 Share Posted August 14, 2005 REgular mild steel plate will do - If JTR style, go with the thickness they use. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted August 14, 2005 Author Share Posted August 14, 2005 Ya okay sounds good, im doing this for a ford 302 though so i think im going to look how the jtr mounts hoo up to the datsun cross member and then start from there. thanks guys Quote Link to comment Share on other sites More sharing options...
hat1324 Posted August 14, 2005 Share Posted August 14, 2005 ford mounts will be a bit werd though, the chevys use a differnt mountng style.. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 14, 2005 Share Posted August 14, 2005 .250" think steel for engine mounts? How big is your engine? Guys, there isn't ANYTHING on the car that would need 1/4" steel plate. Design a mount using a box shape (look at the stock mounts on the 240Z crossmember) and .095" wall 1020 would be fine. If you went with 4130 CroMo you can make the mounts out of .083". If you're building an engine plate, use 6061T651 aluminum in .250" thickness and drill a bunch of lightening holes. We aren't modifying a Peterbuilt truck! Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 14, 2005 Share Posted August 14, 2005 Or just cut up some angle iron off an old bedframe. Mild steel is all that is needed. Quote Link to comment Share on other sites More sharing options...
skipzoomie Posted August 14, 2005 Share Posted August 14, 2005 11 gauge sheet (.120 thick) is more than enough. You should find more than you will ever need at the scrap yard. Plenty cheap, too. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted August 14, 2005 Author Share Posted August 14, 2005 Thanks for the numbers john just what i needed and thanks others for the scrap yard idea i didn't think about that. But I don't think I will be going that route, im going to use emachineshop.com you guys should check it out. What you do is CAD out what you need using their software and then their robots cut it up for you and in a little time the piece arrives at your door. Does anyone else think this is a good idea? Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted August 15, 2005 Share Posted August 15, 2005 Quote .250" think steel for engine mounts? How big is your engine? Guys' date=' there isn't ANYTHING on the car that would need 1/4" steel plate. Design a mount using a box shape (look at the stock mounts on the 240Z crossmember) and .095" wall 1020 would be fine. If you went with 4130 CroMo you can make the mounts out of .083". If you're building an engine plate, use 6061T651 aluminum in .250" thickness and drill a bunch of lightening holes. We aren't modifying a Peterbuilt truck![/quote'] I would have to agree if the engine mount was directly over the frame mount, but if it is a JTR type mount that is cantelevered, it will have some flex. In my experiance anything that flexes will eventually fail. I will go with 1/4 in. and never worry about it. My 2 cts. worth. John D. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 15, 2005 Share Posted August 15, 2005 JTR makes the tried and true set back plates out of aluminum https://shell7.tdl.com/~jags/Pages/Parts_DAT200.html Not 1/4 steel and I have never heard of anyone saying the JTR pieces failed. Hard to believe your web based cad parts will be any cheaper or quicker than ordering the JTR pieces. And the salvage yards near me sells scrap for 25 cents a pound. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted August 15, 2005 Author Share Posted August 15, 2005 JTR is for chevy isnt it? Quote Link to comment Share on other sites More sharing options...
auxilary Posted August 16, 2005 Share Posted August 16, 2005 is this for a 5.0? check your PM Quote Link to comment Share on other sites More sharing options...
