Sean 83ZXT Posted September 16, 2005 Share Posted September 16, 2005 Doesn't it look all cozy tucked in there? Hopefully I can get her dialed in soon and let her stretch her legs soon. Quote Link to comment Share on other sites More sharing options...
260ZRED Posted September 16, 2005 Share Posted September 16, 2005 Looks nice! Are you going to use that stock ZXT intake? I've had a lot of problems with so many "plugs" that you gotta use for all the unneeded crap. I always had a vacuum leak somewhere in there, then finally switched to a n42 intake, which fixed all the problems. What turbo you running? Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted September 16, 2005 Author Share Posted September 16, 2005 I'll be using it for now. I haven't had any problems so far, but in the future I'll go with a custom intake like the one from Lonewolf or a TWM setup. Quote Link to comment Share on other sites More sharing options...
Confused Posted September 17, 2005 Share Posted September 17, 2005 What turbo is that? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 17, 2005 Share Posted September 17, 2005 Sweet...also interested in knowing what turbo that is and interesting how you have it clocked. Yasin Quote Link to comment Share on other sites More sharing options...
Guest HBZ81 Posted September 17, 2005 Share Posted September 17, 2005 looks slick, posts some numbers when you get them! Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted September 17, 2005 Share Posted September 17, 2005 Looks like it belongs there...nice! Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 17, 2005 Share Posted September 17, 2005 What's the specs? How much boost are you going to run? On a side note. Your ZX in your pics gallery is probably the nicest I've seen. Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted September 18, 2005 Author Share Posted September 18, 2005 The turbo is a T3/T4 60-1 Ptrim. If I remember correctly there were only 20 or so made. It uses a prototype lotus housing from what I'm told. I know a few other members have this turbo so they may be able to provide more detailed specs. The turbo was re-clocked because it didn't look like we could fit the intercooler piping next to the shock tower. Clifton - I think the pic you're referring to is of the ABR 280ZX in Japan. If you saw pic of my primered and beatup hunk of junk you'd realize the engine bay is the nicest thing on it. I'll try to get some more pics up when I get it back from the shop. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 18, 2005 Share Posted September 18, 2005 isnt the piping to close to the exhaust manifold? but that does look real nice and seems like its gonna scream!! mike Quote Link to comment Share on other sites More sharing options...
240hoke Posted September 18, 2005 Share Posted September 18, 2005 Awesome! that turbo loooks sick. I too agree with mike that I/C pipe is little too close to the exhaust manifold, might also look at some shielding for the master cylinder brake booster area.. if you havent already maybe i cant see it. -Austin Quote Link to comment Share on other sites More sharing options...
oinojo Posted September 18, 2005 Share Posted September 18, 2005 wow that is awesome...could you post how you got the external wastegate on there? looks like you had some kind of adapter... Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted September 18, 2005 Author Share Posted September 18, 2005 It's close but the pic make it look closer than the piping actually is. I may have the turbo re-clocked a bit to point the outlet down. I'll talk to the shop on Monday. As far as the wastegate the shop made an adapter with two T-3 flanges and some tubing. Quote Link to comment Share on other sites More sharing options...
violacleff Posted September 18, 2005 Share Posted September 18, 2005 hmm will a t3 turbine be sufficient to get you into the 11's? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 18, 2005 Share Posted September 18, 2005 well Thumper on here was close to the 11's and was on stock T3.. so its very doable with that monster. mike Quote Link to comment Share on other sites More sharing options...
Confused Posted September 18, 2005 Share Posted September 18, 2005 hmm will a t3 turbine be sufficient to get you into the 11's? Yes, it will. Similar turbos (Meaning same or somewhat different), are 500+HP capable. Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 18, 2005 Share Posted September 18, 2005 Yes, it will. Similar turbos (Meaning same or somewhat different), are 500+HP capable. Not with a standard T3 wheel. Maybe stg 5. Sean that housing looks pretty big for a T3. You said P trim to, which is a T4 turbine wheel. What's the a/r on the hotside? Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted September 18, 2005 Author Share Posted September 18, 2005 My notes say it's a .65 A/R. Quote Link to comment Share on other sites More sharing options...
