The Rototiller Posted November 3, 2005 Share Posted November 3, 2005 can someone post some pics or details on how to fabricate a throttle linkage. motor is a 350 chevy with an edelbrock carb. i also have all the stock 240z hardware. i would like to use the steel braided lokar cables. please help thanks Quote Link to comment Share on other sites More sharing options...
Mikelly Posted November 3, 2005 Share Posted November 3, 2005 I don't have any pics. But what I can tell you is the LOKAR cable was what I used. I took the gas pedal assembly out of the car, drilled a hole at the top of the arm, and used the pinned attachment from the cable to connect to the gas pedal arm. Then I routed the cable through the firewall and to the intake. It is very simple to do. Unfortunately, right now the car is in pieces and the cable and pedal assembly are in boxes somewhere... Couldn't lay hands on them if you paid me! It really is a simple mod though. Unbolt the gas pedal assembly and look at it on a bench and you'll see what I mean! Mike Quote Link to comment Share on other sites More sharing options...
danc Posted November 3, 2005 Share Posted November 3, 2005 Did mine the same way using the Lokar braded cable,, Works fine.... Quote Link to comment Share on other sites More sharing options...
The Rototiller Posted November 3, 2005 Author Share Posted November 3, 2005 did you guys use the 24" or 36" cable Quote Link to comment Share on other sites More sharing options...
Mikelly Posted November 3, 2005 Share Posted November 3, 2005 24inch. Mike Quote Link to comment Share on other sites More sharing options...
sjhafa Posted November 6, 2005 Share Posted November 6, 2005 Good timing, I just finished mine about an hour ago, I removed the pedal assembly from the car and cut off the last inch where the ball was. I then welded a rectangle piece on the end with a hole big enough to fit the Monte Carlo cable through, also you need to cut a hack saw's width from the outer edge to the new hole to slide the cable through. I then mounted it back in the car and hooked it up to the cable. The arm needed a slight bend put into it to bring the pedal back to normal position. Worked very well and cost nothing. Just scrap lying around. a little bit of grinding and wire wheel and walla one more small thing off my list. Quote Link to comment Share on other sites More sharing options...
BARACU Posted November 6, 2005 Share Posted November 6, 2005 Here's a link to a pic of how I did it with a Lokar cable, bracket . I used the original bell crank off the accelerator pedal. http://www.pbase.com/baracu/image/18617643/large AL Quote Link to comment Share on other sites More sharing options...
DavyZ Posted November 6, 2005 Share Posted November 6, 2005 Quote Here's a link to a pic of how I did it with a Lokar cable' date=' bracket . I used the original bell crank off the accelerator pedal. http://www.pbase.com/baracu/image/18617643/large AL[/quote'] Nice car, Al. You did a very clean JTR V8 conversion, and the detailing on the car (everywhere) is stunning. Nice work. Davy Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted November 6, 2005 Share Posted November 6, 2005 You can buy the Spectre cable from Autozone/Checker/PepBoys that works perfectly fine and is only like $24. Quote Link to comment Share on other sites More sharing options...
BARACU Posted November 7, 2005 Share Posted November 7, 2005 Quote Nice car' date=' Al. You did a very clean JTR V8 conversion, and the detailing on the car (everywhere) is stunning. Nice work. Davy[/quote'] Thanks, Davy. the car was fun to build. I love the expression I see on some people's faces when they can't find any wires (hehe). I'm building a 76 280Z RoadZter now, with the L28 engine and SU carbs. The challenge is to make the engine compartment look better than the V8 and still hide everything.It should be finished in a few months, I'll post some pics when it's done. AL Quote Link to comment Share on other sites More sharing options...
The Rototiller Posted November 7, 2005 Author Share Posted November 7, 2005 Al i was totally blown away when i looked at the pics of your Z. best engine compartment i have seen so far.... Quote Link to comment Share on other sites More sharing options...
spdsk8r Posted November 7, 2005 Share Posted November 7, 2005 On the first two S30 swaps that I did, I just replaced the gas pedal with one from a mid or late 70's Camaro, and used the camaro cable. The Camaro pedal ends up being in the same location/distance from floor as the stock Datsun pedal. It just required three new holes in the firewall to install. This might be a simple option for you. Quote Link to comment Share on other sites More sharing options...
