Lotus7 Posted November 7, 2005 Share Posted November 7, 2005 I was able to install my Engine (Rb26) and also positioned my Rb25 transmission. Took me two days plus the fabrication of the tranny support. Thanks God, that thing is done before colds comes. The stock clutch slave cylinder from my 77 Z is different mount and it will not bolt to the RB25 tranny. Any other clutch slave cylinder that I can use that is available here in the U.S. ? Is the 300zxTT clutch slave cylinder will work? Thanks Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted November 7, 2005 Share Posted November 7, 2005 My transmission was fortunate to already have one on it. You SHOULD be able to use the Z32 N/A Slave but don't quote me on that. Also I think Nismo makes one. Quote Link to comment Share on other sites More sharing options...
Lotus7 Posted November 7, 2005 Author Share Posted November 7, 2005 My transmission was fortunate to already have one on it. You SHOULD be able to use the Z32 N/A Slave but don't quote me on that. Also I think Nismo makes one. I called advance auto, I asked the clutch slave for z32. He said the shape is "L" shape and it has 2" on center bolt pattern. I have to measure my Rb25 if this will fit. The "L" shape is promising. Also, someone in the other forums thinks that Infiniti I30 VQ30DE engine "might" also fit. http://www.autopartsfair.com/infiniti-engine_parts/more-clutch.html Scroll down below until you see the clutch slave cylinder. what do you think? Quote Link to comment Share on other sites More sharing options...
AKWIKZ Posted November 7, 2005 Share Posted November 7, 2005 I have one of those VG30 front drive slaves. I have not fully mocked it up yet. It does look promising, but from first glance having them side by side, it is not a perfect match. I will most likely bite the bullett and order a Nismo one still. They are around $180 I think. Quote Link to comment Share on other sites More sharing options...
J Taylor Posted November 7, 2005 Share Posted November 7, 2005 I am pretty sure the rb slave is unique. I went to an auto parts store and pulled out several different ones and none would fit. There was talk about some honda slave maybe fitting with some work but nothing for sure. I had one come on my tranny when I bought and have been using it. JT Quote Link to comment Share on other sites More sharing options...
Lotus7 Posted November 7, 2005 Author Share Posted November 7, 2005 I am pretty sure the rb slave is unique. I went to an auto parts store and pulled out several different ones and none would fit. There was talk about some honda slave maybe fitting with some work but nothing for sure. I had one come on my tranny when I bought and have been using it. JT Did you look at the link I posted? http://www.autopartsfair.com/infini...ore-clutch.html The clutch slave is for Infiniti I30 and really look promising too. I will go to autozone and measure the bolt holes. Somewhere along the line we have to find the cross reference to save us some money. By the way, I also installed my rear diff (R200) with QUAIFE. If anyone need a QUAIFE let me know, maybe I can help buying. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted November 7, 2005 Share Posted November 7, 2005 how much was the quaife Quote Link to comment Share on other sites More sharing options...
Lotus7 Posted November 7, 2005 Author Share Posted November 7, 2005 how much was the quaife I think I paid somewhere in $900. I have an account in QUAIFE. If you will organize a "buy", then I will use my account to help you guys. I think the full price for R200 for Z) is something like $1,200. It's been awhile and don't remember. By the way, the measurement of the clutch slave cylinder of RB25 bolt pattern is 1 1/4 inches side by side ( on center). Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted November 8, 2005 Share Posted November 8, 2005 I know it is an L Shaped pattern for sure... You should call Venus Auto, they are notorious for having random parts laying around. I was able to get a couple of pieces from them that they took out of a motor for me. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 8, 2005 Share Posted November 8, 2005 Here is a pic of the slave you need.... Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 8, 2005 Share Posted November 8, 2005 This is the 93 Honda Accord slave that is close, but I belive the guy trying to make this work had probs with the rod throw not being correct, and it not engaging the T/O. I think it could be made to work with a little "more smarts"... Quote Link to comment Share on other sites More sharing options...
Lotus7 Posted November 8, 2005 Author Share Posted November 8, 2005 This is the 93 Honda Accord slave that is close' date=' but I belive the guy trying to make this work had probs with the rod throw not being correct, and it not engaging the T/O. I think it could be made to work with a little "more smarts"... [img']http://album.hybridz.org/uploads/8113/93_Accord_RB25_slave_cyl.jpg[/img] Thanks SOILEAU---->yes I think I can make it to work. If the rod is short, perhaps I can replace it with a bit longer say 1/2 inch more. Did the guy said a "short throw"? Did he mentioned how much short? Also, your car pictures showed you are also using Electromotive. I am also using electromotive but don't have any initial map to tweak. Do you think its possible you can share your map? This is a great help regardless, really appreciate...million thanks Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2005 Share Posted November 8, 2005 Thanks SOILEAU---->yes I think I can make it to work. I will try my best. Did the guy said a "short throw"? Also' date=' your car pictures showed you are also using Electromotive. I am also using electromotive but don't have any initial map to tweak. Do you think its possible you can share your map? This is a great help regardless, really appreciate...million thanks[/quote'] Get a hold of matt ( motorworx) jhe is in japan and can get you a slave pretty quick. BTW once you have a slave the 300z slave rebuild kit will work. i used it to rebuild mine a while back Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted November 11, 2005 Share Posted November 11, 2005 That's from my RB25 Quote Link to comment Share on other sites More sharing options...
