cheftrd Posted January 28, 2006 Share Posted January 28, 2006 This is a fuzzy shot of the pickup. The "bell" is the original RB26 pickup. You can also see the factory windage trays. Front of the pan with SDS hall sensor and mount. Right side of pan. Left side of pan. I didn't take pictures of the baffeling. There's also a trap-door I installed to keep oil in the back of the pan on deceleration. All of the bolt holes line up and the factory windage trays fit with no problem. You NEED those windage trays if you are going to turn this engine. They won't fit with the RB20 steel pan. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 28, 2006 Share Posted January 28, 2006 Looks great Matt. This is the first pick up I've seen modded for the 26 pan so far.... great job!! Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted January 28, 2006 Share Posted January 28, 2006 Thagard has 1 "g" I see you made a slight mod to the front of the pan. Did your mounts move the engine too far forward or was this used in a different car? The pan design was mocked using Wong's cnc mounts. It looks like without the mod it would have been close. I am glad to see it has worked out for you. BTW, I sent you an e-mail the other day. Also, I would like to discuss a GT replacement for the stock turbochargers with you. It will save a lot of money over the HKS route. Nice work! Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted January 28, 2006 Share Posted January 28, 2006 That is one long pick up! Would it be a good idea to put in some kind of support brace on the tube? Maybe a piece of flat stock welded to the tube, and then bolted on the engine useing one of the windage tray bolts. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 28, 2006 Share Posted January 28, 2006 Would it be a good idea to put in some kind of support brace on the tube? Maybe a piece of flat stock welded to the tube' date=' and then bolted on the engine useing one of the windage tray bolts.[/quote'] If you look closely, you'll see he used the oem portion of the factory pick up's brace to hold everything in place. Its the boomarang looking thingie.... Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted January 28, 2006 Share Posted January 28, 2006 If you look closely, you'll see he used the oem portion of the factory pick up's brace to hold everything in place. Its the boomarang looking thingie.... I see it now. That'll teach me not to use my glasses. What type of tubing should I use to fab this up for my swap? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted January 28, 2006 Share Posted January 28, 2006 Wow....sexxxxy....show off! Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted February 4, 2006 Share Posted February 4, 2006 Thagard has 1 "g" Did you fab up the pick up tube for this also? Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted February 4, 2006 Share Posted February 4, 2006 This is a fuzzy shot of the pickup. The "bell" is the original RB26 pickup. You can also see the factory windage trays. Thanks for the photo of the pickup. I will post as well as that wont be too far off for me. I will be using the standard steel rear bowl sump as listed on the site. Will there be some problem with the windage trays from mu RB26 - is that what you are saying? Quote Link to comment Share on other sites More sharing options...
cheftrd Posted February 5, 2006 Author Share Posted February 5, 2006 If you use the factory Z31 steel oil pan, the windage trays will not fit. Maybe the rear one will. but the front one deffinately won't. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted February 6, 2006 Share Posted February 6, 2006 If you use the factory Z31 steel oil pan, the windage trays will not fit. Maybe the rear one will. but the front one deffinately won't. What have others done about this as everyone recommends using this sump? Without the windage tray will the oil splash round everywhere? Have others made an alternate tray? Quote Link to comment Share on other sites More sharing options...
strokerzedd Posted January 23, 2008 Share Posted January 23, 2008 This is an old thread so I'm not sure if anyone visits still. I'm ready to begin welding up my aluminum oil pan based on the top lip of the stock RB26 oil pan. I've got several questions. Why do all of the custom pans jut out where the oil pickup mounts but come back in to the back of the pan, instead of continuing to the back with a wider profile? Is it a matter of more space for the exhaust? What is the oil capacity of the Thagard Speedshop pan? Quote Link to comment Share on other sites More sharing options...
Careless Posted January 23, 2008 Share Posted January 23, 2008 I think I'm going to use the RB26 pan as well if I can for the RB30. I gotta check it out, but I want to use the top lip because the pan itself is pretty damn stout. Should hold the bottom together that little bit more =) Also, question for RIPSNZ: Do you guys flat-grind the main girdles on the RB30's to fit the windage trays like the RB26 girdles have? (those round cuts at the fastener head) Quote Link to comment Share on other sites More sharing options...
