HOW TO VISUALLY DETERMINE IF YOU HAVE AN R200?
CAN IT BE DONE?? I have noticed that some diffs out of late 280z's (76-78) do not have
the 6 bolts holding in a seal or bearing
where you plug in the stub axles?
My 77 does NOT have the bolts and i was under the inpression that it had the r200,
but the 78 that i just got HAS the bolts in the diff case... what is the deal and or difference???
Myron..
Only the R180 have the bolts holding the
seal retainer. If there are no bolts around
the side axles it is a R200. It is very easy
to tell on any Z just look at the side of
the diff from the front of the rear tire.
Somebody has swapped the R200 for a R180
in your 78.
Dave...
