peej410 Posted April 1, 2006 Share Posted April 1, 2006 Im building up a 260z from a customer and the gland nuts that came in the tokico strut box are the wrong size, the old ones i almost had to destroy to get out (despite lots of PB blaster and a little heat) so far i cant find any source, i did find some threads that said people got them from auto zone but those also didnt fit right, does anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted April 2, 2006 Share Posted April 2, 2006 260's differ in suspension depending on the build date. The early chasis were a continuation of the '73 240's. The frame and suspension pieces are all similar to the 240. The later 260's were the start of the 280 re-design, I think the 280 stuff is a bit larger in size. So you could have in advertantly bought early parts and needed late or vice vera. Take the serial number off your chassis and do some web searching to see if you have an early or late. I have some somewhere but I doubt I have 4. I can check if you'd like. Also, you might looking at returning the struts you've got for the correct size and you should get the glad nuts you need. Good luck, took me a while to figure out all the 260 subdleties (sp?). Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 2, 2006 Share Posted April 2, 2006 I'm thinking that Tokico struts are going to require Tokico gland nuts. The struts vary in dimension, so I'd really doubt that a Nissan gland nut would fit a Tokico strut properly. I think the thing to do is contact them directly and see if they can send you a couple nuts. Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 2, 2006 Author Share Posted April 2, 2006 well my customer ordered the parts from ross at modern motorsports and the part numbers are correct (i already verified) i had this happen with my car too but i didnt need new ones they came apart easily. if the struts were wrong they wouldnt fit in the tubes... ill try and call them monday and see where i get... thanks guys Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 2, 2006 Share Posted April 2, 2006 I have some gland nuts laying around. What is the size you need? Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 2, 2006 Author Share Posted April 2, 2006 the early smaller ones. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 2, 2006 Share Posted April 2, 2006 Not sure which ones those are, but here's the gland nuts I have. They have a 1 1/8" hole. Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 2, 2006 Author Share Posted April 2, 2006 could you measure the outside of the thread with a caliper or ruler and ill go do the same Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 2, 2006 Share Posted April 2, 2006 It's 1 7/8" dia. Quote Link to comment Share on other sites More sharing options...
Miles Posted April 2, 2006 Share Posted April 2, 2006 I had the exact same thing happen. Had the correct p/n for my 72 240z rear struts, but the gland nut was too large. Contact Tokico and they will send you a new gland nut. Tokico no. 1-800-548-2549 Also note: the shoulder depth inside of the gland nut differs for different manufactures and vehicle types. Try to get a Tokico galnd nut or your strut may rattle. Miles Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 2, 2006 Author Share Posted April 2, 2006 hrm i probably should order them from tokico, if not then ill get them from you Mat73GNZ Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted April 4, 2006 Share Posted April 4, 2006 I called tokico and they gave me 2. {free} Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 4, 2006 Author Share Posted April 4, 2006 ill be calling them sometime today thanks everyone! Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 5, 2006 Author Share Posted April 5, 2006 tokico is under new ownership and they no longer can just write up a form and send out the parts, paperwork has to be filed from the original purchaser, ie their distributor, and it could take weeks!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted April 5, 2006 Share Posted April 5, 2006 hmm... I just got mine like last week... when i called i asked for the sales person. I told him i needed them, and i explained the whole strut sectioning thing... i was expecting to pay but he said it was free... maybe he got fired... Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 6, 2006 Author Share Posted April 6, 2006 well i talked to raymond, he said they used to be able to do that but they cant anymore and now theres a whole paper trail that has to be utilized because they are restructuring the company. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted May 1, 2006 Share Posted May 1, 2006 did you end up getting what you needed? I ran across all 4 of my stock ones. You could possibly have the centers machined larger if needed to accomidate the strut shafts and get some spacers to esure a tight seat. Quote Link to comment Share on other sites More sharing options...
peej410 Posted May 1, 2006 Author Share Posted May 1, 2006 yes matt sent me his set, they worked flawlessly thanks though Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted May 3, 2006 Share Posted May 3, 2006 I need a rear gland nut for KYB struts,.. Any advice (Other than contacting KYB which is not getting me anywhere) Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted May 3, 2006 Share Posted May 3, 2006 do you know what size the hole needs to be? Quote Link to comment Share on other sites More sharing options...
