OlderThanMe Posted May 17, 2006 Author Share Posted May 17, 2006 SUs, header straight back through a 2.5 tube to a turbo muffler, some sorta cam, "other interior engine work" is what the PO said, umm...not much else...individual air cleaners...no emissions...it is too loud...not fun for the highway. It kept up with a z32 n/a that was modded. beat a fairly new corvette last year...guy couldn't drive. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 17, 2006 Author Share Posted May 17, 2006 I have decided to go all out mad max with my Z...it is going to be gnarly dude... Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted May 17, 2006 Share Posted May 17, 2006 that looks like the same air dam i have. quick question does those flaps, above the turn signals, go over the headlight buckets like that or under Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 17, 2006 Author Share Posted May 17, 2006 look at the pictures...they go over... Quote Link to comment Share on other sites More sharing options...
olie05 Posted May 17, 2006 Share Posted May 17, 2006 well, if you look at everyone elses, they go under. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 17, 2006 Author Share Posted May 17, 2006 hmm...maybe mine is mounted wrong...I have seen others mounted like this Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted May 17, 2006 Share Posted May 17, 2006 i looked to see how sr240z had it and i thought it looked better tucked under, but if you like it that way keep it =) http://www.sr240z.com/srpictures/19.jpg Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 19, 2006 Author Share Posted May 19, 2006 okay...I took the Z for it's first drive now that it is fully together. No squeaks or rattles. Just a few tire clearance problems with the air-dam. time to cut it off... I think it is supposed to be under so I switched it out. Quote Link to comment Share on other sites More sharing options...
olie05 Posted May 19, 2006 Share Posted May 19, 2006 cool, how bout some pics? Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 19, 2006 Author Share Posted May 19, 2006 ok I'll go take some...I am leaving early tomorrow for ZdayZ and I am camping out so no internet until Sunday night. It really looks good with the lower stance than in the "beauty" photos. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 23, 2006 Author Share Posted May 23, 2006 I started sanding my carbs the other day. Just did 400 grit wetsanding on one carb. I need to pick up some higher grit paper to finish polishing and some of that Mothers aluminium polish. I am going to start removing all the unnessary wiring and I plan on pulling the motor and tranny to clean everything up. I may even start a turbo setup with a junkyard block. Depends how much I work this summer. I may just build the N/A motor with tripple webbers and who knows what else...I may go crazy and build a turbo motor with a holset... Quote Link to comment Share on other sites More sharing options...
nienberg.11 Posted May 23, 2006 Share Posted May 23, 2006 Is this sanding for looks or are you polishing the inside of the carbs for smoother airflow? Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 24, 2006 Author Share Posted May 24, 2006 well the outside just looks horrible so until I can rip the carbs off it is just for asthetics...for now. If I decide to go with a turbo motor I will probably either sell off this motor, carbs, header etc... Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 24, 2006 Author Share Posted May 24, 2006 in all these photos I am moving at about 4000-6000 rpm in 2nd gear...20-40mph? in the 3rd one the tires are squealing just a tad. It had rained earlier so I was not doing anything crazy...I also have the rear sway bar out... Quote Link to comment Share on other sites More sharing options...
mikeatrpi Posted May 25, 2006 Share Posted May 25, 2006 I enjoyed reading this. Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 29, 2006 Author Share Posted May 29, 2006 your welcome and thanks for reading my thread! Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 1, 2006 Author Share Posted June 1, 2006 should be making an update tonight. I have my last finals for my composition and rehtoric, interpersonal relations, and my last welding course on this coming Thursday. Once that is done then I will be working on my Z a lot more. I want to improve some areodynamics stuff this summer so that should not be too hard. Maybe drop in that 82-83 BW 5 speed tranny. Maybe a Dakota Digital guage cluster as well. Quote Link to comment Share on other sites More sharing options...
phantaz Posted June 2, 2006 Share Posted June 2, 2006 the more more look at your car the more i like the red black contrast... i think you should definatly keep that theme... its different. luv the log btw.. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 4, 2006 Author Share Posted June 4, 2006 thanks Phantaz! the red/black is going to be easy since the interior is already that and so is the motor...I didn't even think about that when I was getting the red paint. I have finals this week so I will be busy. I did get the dash mounted in the car but it is not right...the curve is not curved enough...DUH...so Now I am going to do something creative to fix it...definitely not making another one...I still need to make the switch board and console...that stuff should be easy. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 5, 2006 Author Share Posted June 5, 2006 I have am making a template for a splitter/body pan...I don't know if I have enough aluminium to do it in one piece but I may be able to do it in two pieces. The cardboard stiffens up the polyurethane air dam a lot so I am going to go ahead and cut out the aluminium. I will really post some pictures later tonight... oh yeah...the wiring harness is now out...redoing it all for a new central plate with everything layed out very neat. Quote Link to comment Share on other sites More sharing options...
