Guest backyrd_mechanic Posted May 18, 2006 Share Posted May 18, 2006 dose anyone know where i can get patch pannels of maybe the floor boards and around the upper part of the rear tail lights where the hatch meets? the car is a 73 240z Quote Link to comment Share on other sites More sharing options...
kcelectronics Posted May 18, 2006 Share Posted May 18, 2006 I think you will have to make your own! check out Mulls Restoration here:- http://forums.hybridz.org/showthread.php?t=106731 Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted May 18, 2006 Share Posted May 18, 2006 www.datsunzparts.com has floorpans. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 18, 2006 Share Posted May 18, 2006 MSA sells a hatch repair panel: http://www.thezstore.com/store/merchant.mvc?Screen=PROD&Product_Code=30-7291&Category_Code=SBC1 Quote Link to comment Share on other sites More sharing options...
Guest backyrd_mechanic Posted May 18, 2006 Share Posted May 18, 2006 awsome guys thanks a ton didnt look forward to making the floorpan. Quote Link to comment Share on other sites More sharing options...
nullbound Posted May 25, 2006 Share Posted May 25, 2006 Quote MSA sells a hatch repair panel:http://www.thezstore.com/store/merchant.mvc?Screen=PROD&Product_Code=30-7291&Category_Code=SBC1 This part is a little cheaper through courtesy nissan: http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=999M1-S30ZR Quote Link to comment Share on other sites More sharing options...
Some-Guy Posted May 26, 2006 Share Posted May 26, 2006 its goona cost me like 1500$ in patch panels damn.......... Quote Link to comment Share on other sites More sharing options...
buZy Posted May 26, 2006 Share Posted May 26, 2006 1500! Make your own. Go for it! You have to cut n weld anyways. Less expensive and the amount of extra work is very minimal. Maybe even less as you dont have fit a formed part into your cars particular shape. Cut out only the metal you need to is another advantage. Create cardboard templates of desired size and the rest is history. Quote Link to comment Share on other sites More sharing options...
Z0wner Posted May 27, 2006 Share Posted May 27, 2006 What guages of metal is the Z composed of? What would be a good replacement for body panels? etc. etc. Thanks, Z0wner Quote Link to comment Share on other sites More sharing options...
JaysZ Posted May 28, 2006 Share Posted May 28, 2006 id say 26 gauge is good Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted May 28, 2006 Share Posted May 28, 2006 26 is a tad thin IMHO. I would use 20 ga for exterior body panels and 18-16 for floor pans.Stock pans are thinner but they have stiffening ribbs pressed into them to add rigidity. If your tranny is out of the car when you do the pans, bolt the tranny carrier back onto the car to hold the tunnel opening at the stock dimension. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted May 29, 2006 Share Posted May 29, 2006 yeah i forgot to clarify what i was using the 26 for, its very thin but i'm using it for my firewall. i think roost is on the money for all else though Quote Link to comment Share on other sites More sharing options...
