ZT-R Posted May 26, 2006 Share Posted May 26, 2006 does anyone have the r33 skyline chassis dimensions? Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 27, 2006 Share Posted May 27, 2006 Sorry it is a little jumbled, cut and paste...Hopefully this is what you wanted. bodyworkType2+2 FHC Designer Number of doors2 dimensions & weights Wheelbase2720 mm107.1 in Trackfront1486 mm58.5 in rear1490 mm58.7 inLength4675 mm184.1 in Width1780 mm70.1 in Height1360 mm53.5 in Length: wheelbase ratio1.72 Ground clearance145 mm5.7 in Kerb weight1530 kg3373 lb Weight distribution (Front)Fuel capacity65 litres14.3 UK Gal17.2 aerodynamics Drag coefficient Frontal AreaCx engineCodeRB26DETT Manufacturer NissanTypeS-6 DOHC 24 valves total 4 valves per cylinder Main bearings Construction Bore × stroke86.00mm × 73.70mm 3.39 in × 2.9 in Bore/Stroke ratio1.17 Displacement2569 cc (156.77 cu in) Unitary capacity428.17 cc/ cylinderCompression ratio8.50:1 Fuel system EFiAspirationTurboCompressor typeIntercoolerY Catalytic ConverterY Max. output (DIN)279.8 PS (276.0 bhp) (205.8 kW)@6800 rpm Max. torque (DIN)368.0 Nm (271 lbft) (37.5 kgm) @4400 rpm Maximum rpm CoolantWater Specific output107.4 bhp/litre1.76 bhp/cu in Specific torque143.25 Nm/ performanceNote:A value of -1 means that the car cannot attain that speed. 0-50mph (80 km/h) 0-60mph5.00s 0-100km/h 0-100mph13.00s 80-120km/h (50-70mph) in top 0-Quarter-mile13.70s @ 102.00 mph 0-Kilometre24.70s @ 211.00 km/h Top speed249 km/h (155 mph) Fuel Consumption CO2 Emissions Power-to-weight180.39 bhp/tonchassis Engine location FrontEngine alignment LongitudinalSteeringrack & pinion PASTurns lock-to-lock Turning circle11.40 m SuspensionFrontI.MultiLi.CS. RearI.MultiLi.CS. Wheels F/R9.0JJ x 17/9.0JJ x 17 Tyres F245/45 R 17Tyres R245/45 R 17 Brakes F/RVeDi/VeDi-S-ABSBrake ∅ F/R324/300 mm Braked area Transmission5MDriveAWD Top gear ratio0.75 Final drive ratio4.11 generalNumber madeModel CodeBNCR33 Model Family Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 28, 2006 Author Share Posted May 28, 2006 any more detailed ones? Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 28, 2006 Share Posted May 28, 2006 what exactly do you need? Do you need engineering specs? I'll look for some more, in the meantime. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 1, 2006 Author Share Posted June 1, 2006 the dimmensions like they have in the sticky in the chassis forum for the 240z would be prime.... but manily the engine compartment dimmensions Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted June 5, 2006 Share Posted June 5, 2006 I have a magazine with practically every dimension there is....if I can find the damn thing.... Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted June 5, 2006 Share Posted June 5, 2006 Does this do it for you? I have the 32 and 34 dimensions as well if you need them.... Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 5, 2006 Author Share Posted June 5, 2006 you are the tits!! do u have the r32 and r34? thanks Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted June 6, 2006 Share Posted June 6, 2006 It's about time I contributed something useful.... I'll upload the R32 and R34 when I get home from work tonight. Is the one posted big enough? Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted June 6, 2006 Share Posted June 6, 2006 Rather than eat bandwidth I'll just post the URL's here. That way you can download high res pics and actually use them http://i64.photobucket.com/albums/h191/hakosukajd/R34dim.jpg http://i64.photobucket.com/albums/h191/hakosukajd/R32dim.jpg Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 6, 2006 Author Share Posted June 6, 2006 sweet, thanks Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted June 6, 2006 Share Posted June 6, 2006 Can this be stickied? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 6, 2006 Author Share Posted June 6, 2006 do u have the same figures for the engine bay of the 240,260,or 280z...the ones in the other forum dont have that many measurments for what i need. thanks Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted June 6, 2006 Share Posted June 6, 2006 do u have the same figures for the engine bay of the 240' date='260,or 280z...the ones in the other forum dont have that many measurments for what i need.thanks[/quote'] That one will be a bit harder....I'll check through all my "Nostalgic Hero" magazines and see if I see it anywhere.... Quote Link to comment Share on other sites More sharing options...
ZT-R Posted June 7, 2006 Author Share Posted June 7, 2006 ok, thanks, hey i apriciate all this thank alot Quote Link to comment Share on other sites More sharing options...
mull Posted June 7, 2006 Share Posted June 7, 2006 I love you HakosukaJD - thank's a million for the pics! : ) Quote Link to comment Share on other sites More sharing options...
stony Posted February 9, 2007 Share Posted February 9, 2007 Does this do it for you? I have the 32 and 34 dimensions as well if you need them.... Yes please post teh pics of the other 2 > Quote Link to comment Share on other sites More sharing options...
stony Posted October 16, 2012 Share Posted October 16, 2012 the dimmensions like they have in the sticky in the chassis forum for the 240z would be prime.... but manily the engine compartment dimmensions ZTR where is this thread you mentioned? i cant find it. im comparing some measurements to see what can stay and what would have to go if i built a front clip to mount the GTR front suspension. Quote Link to comment Share on other sites More sharing options...
japanparts999 Posted March 14, 2016 Share Posted March 14, 2016 what would you like to know I have one here in so.cal if you want to measure it or get some weights for you ? Quote Link to comment Share on other sites More sharing options...
Ozero Posted June 21, 2021 Share Posted June 21, 2021 I'm looking for chassis dimensions for 98 r33 gtst. Need to get the frame checked for safety certificate. Can anyo e out there help 🙂 Quote Link to comment Share on other sites More sharing options...
