JaysZ Posted June 6, 2006 Share Posted June 6, 2006 To fit 40mm Mikuni PHH carbs. I need 6 horns. If its cheaper than what MSA sells it for, i'm interested Quote Link to comment Share on other sites More sharing options...
Zhadman Posted June 7, 2006 Share Posted June 7, 2006 What does MSA sell them for? Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 7, 2006 Author Share Posted June 7, 2006 What does MSA sell them for? $41.95 each (i need 6) plus shipping! http://www.thezstore.com/store/merchant.mvc?Screen=PROD&Product_Code=11-3013-M&Category_Code=PFFC07 Quote Link to comment Share on other sites More sharing options...
Zhadman Posted June 7, 2006 Share Posted June 7, 2006 Hmmm.... designing one is no problem. Chances are, though, that it would be much more expensive (than $252.00) to have 6 of them machined and polished. Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted June 7, 2006 Share Posted June 7, 2006 I do have a lathe but I am too dumb to figure out how to cut the flared opening. Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 8, 2006 Share Posted June 8, 2006 Whilst browsing the plumbing aisle at Casa de Pot I saw bell-shaped pipes. They are chromed brass, and made me think of a Hilborn injection setup poking up through the hood of a fuelie Corvette. 40mm is roughly 1.5" and drain pipes come in 1.25" (bathrooms) and 1.5" (kitchens). Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted June 8, 2006 Share Posted June 8, 2006 Check these stacks out: There really nice for a NA engine. I've used them before. http://www.tperformance.com/street_rod_store/5200/40mm_idf_weber_stacks/ Regards, Justin Quote Link to comment Share on other sites More sharing options...
Guest xtrmgt Posted June 8, 2006 Share Posted June 8, 2006 To fit 40mm Mikuni PHH carbs. I need 6 horns. If its cheaper than what MSA sells it for, i'm interested do you have some dimensions for them? I can model them up and get a quote from a friend. can't guarantee they would be cheaper but it's worth a shot Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted June 8, 2006 Share Posted June 8, 2006 Try these guys: http://www.velocity-of-sound.com/commerce/search/index.php3?merchant_id=2107&keywords=&search_type=ANY&custom_store_category=8&by_category=+++GO%21++ They look interesting, especially if I were making my own. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 9, 2006 Author Share Posted June 9, 2006 sorry for the poor quality.. this probably isn't the most accurate of measures but hopefully this works. JustinOlson and 74_5.0L_Z both those sites are pretty sweet. i think i might order some horns of appropriate length (any suggestions?) and design some flanges (or a one piece flange for them all) using emachineshop and weld it all together. thanks keep the ideas coming! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 9, 2006 Share Posted June 9, 2006 How long do you need them? I got a plate of aluminum and had a machinist mill the correct hole for my 44 Mikunis. He then used a carbide 3/8" router bit to machine the air horn. If I had it to do over again I would drill out the threaded hole in the carb and put the cap screws on the back side of the carb and have them thread into the airhorn that way it would be smoother. Quote Link to comment Share on other sites More sharing options...
veritech-z Posted June 9, 2006 Share Posted June 9, 2006 Jon, that plate is really cool! My buddy at work bought some of those velocity of sound stacks, and they were really nice when they came in. He built himself a crazy manifold using them on his 330whp saturn SL2... This picture is after he cut them to siamese the stacks, I couldn't find one of a before picture...if anyone is interested, here is the link to www.turbosaturns.net where he shows his whole buildup: http://www.turbosaturns.net/forum/viewtopic.php?t=27966&highlight=velocity+stacks Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 9, 2006 Share Posted June 9, 2006 I bet that was fun to weld... Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 9, 2006 Author Share Posted June 9, 2006 nice very nice. is there a benefit to having them siamesed? in my case my horns are spaced far enough not to do that, but it could be done if there is a benefit to it. Quote Link to comment Share on other sites More sharing options...
veritech-z Posted June 9, 2006 Share Posted June 9, 2006 Well, in his case, the advantage to having them siamesed is that it was the only way they would mount up to his stock intake runners. He hacked his old plenum off, and made a new one out of 4 inch tube. personally I felt that the new plenum need to be a bit bigger, because once he slid that plate in, there wasn't much actual volume left over. If you follow that link, he has pictures of the whole setup and you can see what I'm talking about. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted June 9, 2006 Share Posted June 9, 2006 Go to ebay and put in weber velocity, there is a lot of stacks in there that could be modified with a different base plate that would work. It all matters how much time you want to put in to save some $$$$$$$$$$$$$$$$! Quote Link to comment Share on other sites More sharing options...
Guest mg53 Posted June 13, 2006 Share Posted June 13, 2006 I have some chrome air horns for these carbs if you are still looking for them Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 13, 2006 Author Share Posted June 13, 2006 I have some chrome air horns for these carbs if you are still looking for them how much do you want for them? please PM me the details thanks Quote Link to comment Share on other sites More sharing options...
Guest mg53 Posted June 14, 2006 Share Posted June 14, 2006 details, They are off of a set of carbs (mikuni phh) I installed on a car years ago that did not use the velocity stacks so I removed them and they have been sitting in my garage for about 15 years. they are chrome. If you want a picture I will dig them out and take a picture for you . They only problem is I cant do it until next week. I will let them go cheap. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 14, 2006 Author Share Posted June 14, 2006 sounds good, consider them sold =) Quote Link to comment Share on other sites More sharing options...
