EvilC Posted September 21, 2006 Share Posted September 21, 2006 Found this car and was thinking about picking it up... here is what the seller has told me in his own words: The color is flat black out of a spray can right now. The previous owner had the car in tan primer after doing the body work, so I sanded it down and sprayed the black over it. The wheels are the late '80s 300zx wheels. All the miscellaneous trim pieces, bumpers, bumper supports, badges, gauges, etc etc etc are in my basement and go with the car. There's also a master set of poly bushings for the car that I have which you can take. Some more stuff about the car...it has a bigger than stock radiator and a Ford Taurus electric fan, which is a popular hot rod fan because it moves a ton of air. The car runs around 180-185 and a flick of the fan switch brings it down if you're sitting still. I have an autometer tach in the car for the V8, and just set up an autometer coolant gauge as a reference. The hood is pinned down now, but I have all the stock latches and whatnot. The motor has a holley 650 carb, vac secondaries single squirter, hei distributor, block hugger headers. You can see the fuel cell in the back of the car, all the carpeting was replaced and is new, the seats have no rips, the dash has the usual crack in the middle but other than that is in nice shape. The pics of the body show pretty well how straight the body is, all the fenders are rust free and straight as well. Ok pics: http://img335.imageshack.us/my.php?image=z12oh.jpg http://img335.imageshack.us/my.php?image=z23no.jpg http://img335.imageshack.us/my.php?image=z32ke.jpg http://img335.imageshack.us/my.php?image=z46to.jpg He sent me a few more and explain to me the tranny was shifting rough and it may just be the cable is too long? What do you guys think....I am thinking I can get home down to $1800...worth my time? Thanks Clive Quote Link to comment Share on other sites More sharing options...
Twoeightnine Posted September 21, 2006 Share Posted September 21, 2006 From what I have seen, I would say hell yes. Whats with the "cable" statement? What cable? Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 21, 2006 Author Share Posted September 21, 2006 From what I have seen' date=' I would say hell yes.Whats with the "cable" statement? What cable?[/quote'] Please excuse my ignorance because I am learning here.... What cable would control the way the transmission shifts? Or cause it to shift hard? He said the "one" that is on the car right now is to long and with a shorter one, it should fix the problem. He says the car is driveable and he has put some miles on it. If I was to buy it, he would drive it to NYC, The Bronx which is 45 mins from him. That is still 5 hours from me at school but may be worth the drive.. Anyone wanna give a quick recap on how the tranny...and cables that are apart if the system works....take it easy on me! LoL Thanks guys Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 21, 2006 Share Posted September 21, 2006 I would assume it's a kickdown cable that he's talking about. When you drive an auto car that doesn't have an electric transmission controller and you step on it, you can actually feel with the last little bit of gas pedal a little click. This is because there is a cable from the throttle down to the side of the trans, and when you stomp on it it manually downshifts the trans. When I worked for Volvo we changed a lot of those on 240s and 740s IIRC. With a broken cable you'd stomp the gas and the thing would go to 3rd gear or 1:1, but would go down to 2nd gear to accelerate. Made the car a real slug. Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 21, 2006 Author Share Posted September 21, 2006 Would this destroy the tranny on a long drive? 5 hours? Expensive to replace? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 21, 2006 Share Posted September 21, 2006 In the Volvos it didn't cause any harm other than the car was a slug off the line (as if a 240 with a working kickdown cable could be called anything better). Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted September 21, 2006 Share Posted September 21, 2006 Unless it has an overdrive tranny, then it's the TV cable. It has to be adjusted right or you'll kill the tranny. http://www.tvmadeez.com/article/index.php Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 21, 2006 Share Posted September 21, 2006 if you don't buy that you should be shot. what a killer deal!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 21, 2006 Share Posted September 21, 2006 Well that's a bit different than what I was thinking! Sorry for the bad info. Quote Link to comment Share on other sites More sharing options...
Darrel Posted September 21, 2006 Share Posted September 21, 2006 wheels are from a 84-85 300zx non turbo. 4 lug. You know what mull's car was like no rust etc,, mainly because they replaced it all with fiberglass. Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 21, 2006 Author Share Posted September 21, 2006 Well that's a bit different than what I was thinking! Sorry for the bad info. Hey it is ok, honestly I really do not need the car because I am working on my ls1 swap but I was thinking this one is almost all together..hey why not?! lol Mike I think you are right on the money, and I will post more pics today when I see what the frame rails look like and such. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted September 22, 2006 Share Posted September 22, 2006 Hey it is ok, honestly I really do not need the car because I am working on my ls1 swap but I was thinking this one is almost all together..hey why not?! lol Mike I think you are right on the money, and I will post more pics today when I see what the frame rails look like and such. Are you planning on using the body instead of the one you have as a donor for the LS1 and selling yours? Unless you can afford to buy it and also have enough money to finish your current project, I would say pass on it. The $2000 will go a long way towards getting your LS1 project on the road. I once made the mistake of spending money that was earmarked for one of my projects on another "good Deal" that I didn't need. It set me way back on my project and I ended up selling the "good deal" for the same money I paid for it about 6 months later. Not such a good deal. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 22, 2006 Share Posted September 22, 2006 well if that z is running 3/4 as good as it should with that motor. its a GOOD DEAL. just needs teh nawzzz Quote Link to comment Share on other sites More sharing options...
flames_187 Posted September 22, 2006 Share Posted September 22, 2006 if i see that car on campus ima kick it on the driver side door so you can see it ALL THE TIME!...jk Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 22, 2006 Author Share Posted September 22, 2006 if i see that car on campus ima kick it on the driver side door so you can see it ALL THE TIME!...jk If you do that imma drive your car into the stream and watch it rust! lol Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 22, 2006 Author Share Posted September 22, 2006 Are you planning on using the body instead of the one you have as a donor for the LS1 and selling yours? Unless you can afford to buy it and also have enough money to finish your current project, I would say pass on it. The $2000 will go a long way towards getting your LS1 project on the road. I once made the mistake of spending money that was earmarked for one of my projects on another "good Deal" that I didn't need. It set me way back on my project and I ended up selling the "good deal" for the same money I paid for it about 6 months later. Not such a good deal. Well I am selling my Bmw and I am going to need a daily driver........I am still going to finish the Z by spring and sell this one when the time comes if I get it. I just think that car is just very clean for the price....also I have owned my Z for almost 2 yrs and neva drove it....I want to drive one already lol Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 22, 2006 Author Share Posted September 22, 2006 I do not know how to post pics......I tried ova n ova. Anyone wanna post for me, I'll fwd them the pics of the car. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 22, 2006 Share Posted September 22, 2006 email the pics to jaxz31@gmail.com. i'll host and post them happily. but if you want. go register an account at http://www.photobucket.com. upload the pictures there and copy paste the pics' urls here. Quote Link to comment Share on other sites More sharing options...
280Zone Posted September 22, 2006 Share Posted September 22, 2006 That is a great deal for the fun you will get from it. Like Mike said, it is probably an overdrive transmission, and the TV cable adjustment is very important. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 22, 2006 Share Posted September 22, 2006 email the pics to jaxz31@gmail.com. i'll host and post them happily. but if you want. go register an account at http://www.photobucket.com. upload the pictures there and copy paste the pics' urls here. Maybe I'm missing something but you no longer have to host a picture, you can upload from your computer to our photo gallery. I've seen this hosting problem mentioned in several threads and I'm amazed why people are not uploading right from their computer.. LARRY Quote Link to comment Share on other sites More sharing options...
