zspeed280 Posted September 28, 2006 Share Posted September 28, 2006 this isnt z related but i figured you guys were the ones to come to heres the scoop: Ive talked my step dad into dropping a junkyard turbo kit on his 3.9 dakota 2002. i was curious what turbo would be a good turbo to go? it will be off of an older car 300zx, turbo II , eclipse, volvo..which turbo would be good for mild lag? hes not looking for a lot of horsepower just maybe up to 50 gain with low boost Dont want to mess with the ecu, or fuel right yet We work at a welding shops so material and fab help is no problem. im tryin to start the build for him at just over 500 dollars. thanks guys David Quote Link to comment Share on other sites More sharing options...
mamba_888 Posted September 28, 2006 Share Posted September 28, 2006 The stock t3 on our 280zxt should be a good start although I've long since been educated by this site that this is an internal wastegate turbo. There are ways to convert this to an external as done by 240hoke. Here is his thread that has taught me a lot. http://forums.hybridz.org/showthread.php?t=108785 The t3 should be small enough to spool up mildly. Quote Link to comment Share on other sites More sharing options...
zspeed280 Posted September 28, 2006 Author Share Posted September 28, 2006 what are the advantages/disadvantages to an internal/external wastegate? I understand turbo flow but i still have a lot to learn about turbos. Quote Link to comment Share on other sites More sharing options...
mamba_888 Posted September 28, 2006 Share Posted September 28, 2006 you can have a lot more control external wastegate psi's. Internal wastegates, your almost stuck with factory settings although a lot of users here @ hybrid has successfully tweaked their internal wg's. Search if you want to know how they did it. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted September 28, 2006 Share Posted September 28, 2006 You can also source T3s from, Turbo Mustangs, Turbo Merker, Thunderbird Turbocoupes, and some of the later Chrysler 2.2L turbos. Just know that the chrysler turbos use a different turbine inlet flange, but they are still T3 turbos. I'm sure there's a few more but those are the ones off the top of my head. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 4, 2006 Share Posted October 4, 2006 Not sure what you mean by a junkyard turbo kit. Your focus seems to be on the turbo and that is the easy part. You need exhaust manifolds and a crossover pipe, a downpipe and exhaust and none of those can be got from a junkyard. If you add an I/C, you will need custom plumbing. You will also need upgraded injectors and possibly mods to your engine management or an aftermarket like megasquirt. Quote Link to comment Share on other sites More sharing options...
nismopick Posted October 4, 2006 Share Posted October 4, 2006 you can have a lot more control external wastegate psi's. Internal wastegates, your almost stuck with factory settings although a lot of users here @ hybrid has successfully tweaked their internal wg's. Search if you want to know how they did it. That's not really the reason. Ever heard of a BOOST CONTROLLER? External wastegates are usually larger than internal, and can flow more exhaust. Quote Link to comment Share on other sites More sharing options...
warrenp Posted October 4, 2006 Share Posted October 4, 2006 an holset hx30 would prolly do the job. i think it's abit bigger then a t3 but not by much if it is Quote Link to comment Share on other sites More sharing options...
zspeed280 Posted October 10, 2006 Author Share Posted October 10, 2006 i know about the manifolds and all that good stuff..i can fabricate that stuff myself. have access to materials and the welders and a few people with some skills. i was going a small turbo and run 4-6 psi..that way i wont have to do the aftermarket fuel stuff... Quote Link to comment Share on other sites More sharing options...
