Fixed problem finally - Must See
hey guy's,
Finally found my problem with the engine. Bad MSD ignition box. Jerry and I took the car to a local track last night and it was awsome. Felt good to see it run like it is supposed too.
Posted alot of new video footage at www.jnjdragracing.com
Note: right click on thumbnail and save as.
Did some inside filming as well thanks to my brother Jerry who mounted his video camera inside the car. Awsome footage must see what it looks like inside the car with the wheels lifting up.
Jerry got the idea from ZGad's footage. Jerry driving and if you listen closely you can hear him yelling and having a good time. Like " This is what its all about " and " Rip where are you now " etc.
Any way come take a look.
However new issue arrised, have a bad bearing or something in the blower, have to take off and apart to see what is going on. Oh well at least the other issues are behind us.
60 foot imes were a 1.35, consistent. CV joints held up to some awsome abuse last night.
John
Had a few problems with some videos I posted. I am uploading the last messed up video now. If you get an error saying corrupt please try again in about 20 minutes. Never Mind, they are now all fixed. You can download now...... done reloading.
Here are the links if you do not want to go to my website. 56K beware.......
http://www.jnjdragracing.com/videos/test1st.avi
http://www.jnjdragracing.com/videos/testinside1st.avi Note: this is a big file 73 mb.
http://www.jnjdragracing.com/videos/test2nd.avi
http://www.jnjdragracing.com/videos/testinside2nd.avi
http://www.jnjdragracing.com/videos/test3rd.avi
http://www.jnjdragracing.com/videos/test4th.avi (NOS run)
http://www.jnjdragracing.com/videos/testinside4th.avi ( NOS run )
John
hey guy's,
John
You GO John...! Sure sounds like it's fixed! Glad you were able to suss it out. How did you come to the conclusion it was the box?
Just put my 4500 stall converter in today but will have to wait until friday to test it out on the track. hope to be well into the 6's in the 8th.
Wayne
Hello Wayne,
Well not long ago I installed an alternator. Since then problems occured, battery not lasting like it should. Took the alternator off when we rebiulded the engine. I think it overcharged my system and messed up the MSD unit. Just in case I did replace the dizzy, coil, plugs, even the rpm chips.
John
Hello Wayne,
John
After over 40 years in the computer world I have learned several things about electronics. A fuse never just "wears out", a good ground is not just a good idea but mandatory and an electrical device rarely dies alone. As far as diagnosis goes always ask "What was the last thing you did before the problem started?"
The real big one is the 1st inside view, I did not edit it. I thought some people would like to see the whole thing from start to return. I did try more compression on the inside videos but it distorted the sound and I wanted to keep it as real as possible.
I will try and do better next time.
John
hey guy's,
Finally found my problem with the engine. Bad MSD ignition box. John
Let me start by saying I've had an MSD box in my Z for 5 years now, no problems at all.
But in the past ~1 year I've had no less than 5 MSD box's be the cause of problems with cars coming through my shop and running on my dyno. I'd never, ever buy one again because of that. Best I can tell those that are 2+ years old seem to be much more reliable than the newer ones. Just FYI for anyone looking at an ignition box. The Mallory, Jacobs, Crane, etc. boxes all seem to be fine.
