Guest Mike Posted October 19, 2006 Share Posted October 19, 2006 boodlefoof said: Mike, there is just one MC for the front and one for the rear. The third one is for the clutch. Oh..... boodlefoof said: As for adjusting brake bias, I have seen a couple of guys with GT-40 kit cars that have set up a tunable adjustment dial on the center console. I think that reaching down there while moving might be a bad idea. Cockpit Adjustable Proportioning Valve here... http://www.arizonazcar.com/brake.html Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 19, 2006 Author Share Posted October 19, 2006 That's a different kind of prop valve. The one for the dual masters is the big red knob next to the gearshift. It doesn't attach to the brake line, it changes the bias at the master cylinder pushrod. Here's a description of how it works: http://www.wilwood.com/Products/005-PedalAssemblies/Pages/techtip/pedaltech.asp You can see that this guy has a prop valve plumbed into the brake line as well. You can super fine tune the brakes by using both types of valves. Quote Link to comment Share on other sites More sharing options...
johnc Posted October 19, 2006 Share Posted October 19, 2006 Is there really two adjustable prop valves in line in the picture above? Someone has really screwed up the balance between the calipers and MC if two adjustable prop valves are needed. Maybe one of those is a line lock used as a rear e-bake? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 19, 2006 Author Share Posted October 19, 2006 That is AZC's setup with a line lock ebrake and a prop valve. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted October 20, 2006 Share Posted October 20, 2006 Yup... one is a hydraulic line lock for e-brake. Quote Link to comment Share on other sites More sharing options...
preith Posted October 20, 2006 Share Posted October 20, 2006 tube80z said: No by pedal ratio I mean where you put the balance bar. On a car wtih a vacuum booster it needs to go a little higher up the arm. I looked at the tilton pedals and used there leverage ratio when I modded the stock arm (distance from pivot to balance bar and total length of pedal). I have driven a car with the balance bar in the stock location and it requires a lot higher pedal effort to get stopped. Cary At the risk of sounding like a complete idiot, I have to disagree. By lowering the master attachment point, the amount leverage is being decreased exponentially. Was the other car you drove a Z, with the same size masters, etc? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 20, 2006 Author Share Posted October 20, 2006 It's not exponentially decreased. The ratio is explained here. http://www.wilwood.com/Products/005-PedalAssemblies/Pages/techtip/pedaltech.asp What will matter is that the higher the ratio the less throw on the master for a given amount on the pedal. So I guess you have to keep in mind how long the throw on the cylinder is and how long the throw is where you plan to install the pivot. Quote Link to comment Share on other sites More sharing options...
tube80z Posted October 20, 2006 Share Posted October 20, 2006 preith said: At the risk of sounding like a complete idiot, I have to disagree. By lowering the master attachment point, the amount leverage is being decreased exponentially. Was the other car you drove a Z, with the same size masters, etc? I raised them about a half inch. I don't really know why they look so low in the photos. Cary Quote Link to comment Share on other sites More sharing options...
preith Posted October 20, 2006 Share Posted October 20, 2006 jmortensen said: It's not exponentially decreased. The ratio is explained here. http://www.wilwood.com/Products/005-PedalAssemblies/Pages/techtip/pedaltech.asp What will matter is that the higher the ratio the less throw on the master for a given amount on the pedal. So I guess you have to keep in mind how long the throw on the cylinder is and how long the throw is where you plan to install the pivot. Ok, exponentially wasn't the right word, but it certainly is multiplied. That link only reinforces my statement. Technically one would want the attachment point as high as the pedal throw will allow, and this will also decrease the amount of pressure needed. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted October 31, 2006 Share Posted October 31, 2006 What size masters did you guys use? I'm planning on having 4piston wilwoods in the front and 240sx brakes in the rear. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted November 16, 2006 Share Posted November 16, 2006 well i'm giving this one a shot guys. here's a couple pics of the progress Ive made so far. there's a couple reasons i did this. first being that i need more room for how i want to package my turbo/wastegate. second, is that this is going to cost me about the same as restoring the stock system.[new masters/booster, mine were junk] and i've got another pedal box so if i screw up, i'm not ...screwed. to be honest i dont totally understand yet how these are supposed to better for performance braking, so i'll let one of you guys tell me that. oh yeah, and i think they look cool. everything came today. balance bar, remote adjuster, [1] 5/8" master and [1] 3/4" master, all wilwood . here it all is, along with my partly notched pedal box. close up of the parts. the first thing i did was notch the pedal box, for clearance of the balance bar. i made sure before i cut, that the masters would have enough throw. i still have to do a bit on the inside wall. after notching the pedal box, was do some measuring as to where these things were going to go. here is what i came up with. an interesting thing i found out was that the wilwood masters lined up perfectly in the stock holes for the clutch master cylinder. [is this some kind of industry wide bolt pattern? or are we just lucky?] i guess i'll be picking up another one, just for continuity's sake. after that was cutting a hole in the pedal to fit the balance bar. this was by far the hardest part, it took about an hour. all i used was a drill and a round file. close up not welded yet. so next is cutting off the old front, and making a new one for the masters to go through. i should get to that within a few days... Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 16, 2006 Author Share Posted November 16, 2006 The benefit to this over a normal master with a proportioning valve is that this is ACTUALLY proportional and a valve really isn't, so you can get more rear braking (especially at high speeds) with this setup than you can with a traditional prop valve. I've decided that I'm going to do the same. Keep updating as it comes along. You'll probably save me some hassle... Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted November 19, 2006 Share Posted November 19, 2006 did some more work today. got the sleeve for the balance bar welded in, cut up the pedal box some more, and got the replacement face welded partway in. i'm takin a break right now. i'll update some more if i get anything else done tonight. the hole near the weld is for the return spring here you can see the clearance with the interior wall. it's fine if i keep the balance bar in the middle, but if i'm going to need to adjust it further that way i'll have to cut out a slot Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 19, 2006 Author Share Posted November 19, 2006 That looks pretty damn good! Keep it up! Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted November 19, 2006 Share Posted November 19, 2006 Just finished! Kinda. just a few more things to button up. the only issue now is that the holes in the plate are a little far apart, and they're a LITTLE crooked. not sure how to real with that yet. maybe spacers to push the arms further apart on the balance bar. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted November 22, 2006 Share Posted November 22, 2006 problem solved. i replaced the thin washer with 2 slightly thicker ones. OSH fender washers 3/8" x 1-1/2" SKU 9052598 before, the shafts were hitting on the inside of the lip there. I may put one more in there on each side so they're more in the center. Quote Link to comment Share on other sites More sharing options...
tube80z Posted November 22, 2006 Share Posted November 22, 2006 What are the washers supposed to do? From your pics it's not clear what you're trying to do here. You need to clearance the inside of the bolt above and I would recommend adding the lip back in around the firewall mount as it adds stiffness. Cary Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 22, 2006 Author Share Posted November 22, 2006 I think he mounted the masters too far apart, so the washers are spacing the black parts (don't know the name of those) so that the rod from them to the masters are straight. Quote Link to comment Share on other sites More sharing options...
tube80z Posted November 22, 2006 Share Posted November 22, 2006 If that's the case then they will interfere with how the system should work. Safety stops should only be on one side if you have them. Cary Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted November 22, 2006 Share Posted November 22, 2006 jmortensen said: I think he mounted the masters too far apart, so the washers are spacing the black parts (don't know the name of those) so that the rod from them to the masters are straight. Thats exactly right. The balance bar had 1 very thin washer on each side of the middle tube that welds into your pedal. i used some thicker ones to space the black blocks out more so they would line up again. if this ends up not giving me enough adjustment i'll try to replace the main threaded rod with a longer one. i should be able to because the monoball is just held in with jam nuts. i dont see how that would make them work any differently. Adding bracing is one of things i haven't gotten to yet. i was planning on adding the lip back, and triangulating it back to the main body...kinda hard to explain, you'll see. Quote Link to comment Share on other sites More sharing options...
