Running rich with Z32 ECU
Lewis Maudlin
OK, since I changed to the Z32, 740's and GT2871R, I have been having an issue. The car runs rich. I have checked everything except the MAF and the computer. The computer has an enthalpy ROM tune. Enthalpy has been good to deal with and has sent other chips. Even with an AFC maxed out, I can only get to 11:1 AFR. Anyone have a suggestion?
Changed the title. I thought you had problems crapping. That clearly isn't what this thread is about.
Nice move, only I don't have a Z32 ECU. That is what the MAF is from. Apparently, you decided to change the title without know what we are talking about?
Anyway, I will check to voltage. That could be an issue. Good suggestion on the voltage. The MAF has now been checked on a machine to check MAF's. It is within spec and working properly.
OK, here's the scoop. Anyone with an SR20DET may benefit from my experience. Apparently, the ECU board is bad or the connection to the daughterboard. This explains why from time to time my car has run great. I used to run a different Mine's tuned ECU. Word is that cars with bad ECU's run without a tuning map and run extremely rich. So if this happens to you, now you know.
  • 2 months later...
So what ECU do you have? ECUs tend to run on presets when its not getting a proper read from a sensor. Check the connection to the temp sensor and any other sensor that comes to mind.
