dyno #'s thread
CantZme
Slow_Old_Car,
My setup is almost like yours f54, p90, 2mm headgasket but I do have some combustion chamber work as well. I am just running 93 octane. When I was tunning my car while back there was no hp difference between 11.4 - 11.8 but as soon as it got to about 12.0 there was good 12-15whp difference. I still try to run around 11.8:1
Ivo
  • Replies 47
L-24 Stock crank, rods, pistons +1mm OS
N-42 head with welded 36cc chambers, and mild porting, swirl polished valves, compression ratio 10.65:1, Pump Gas
MotorSport #3 cam
Electromotive Tec 3r, 320cc injectors, hogged out stock intake with 60mm throttle
209.9 HP 178.1 torque
  madkaw said:
Hey Monzter,
those numbers are from a p-30 block at the rear wheels? Your making me feel better about working my l-24 if that is true. Anymore info on what you've done with that motor?
Yes, That was at the rear wheels before being broken in, I think it feels even a little better now. the block is the original P-30 that came in the car. I autocross it and what is so great is the way it revs and pulls all the way to 7500 no problem. Many of my fellow z guys run 280 blocks and are surprised to see how well a 240 can pull. I had the car at the MSA autocross last weekend and I feel having the 2.4 aginst all of the other 2.8s and 3.1 was no problem. I guess it depends on what you want. Here is a pic of the engine and head. Let me know if you need any other specs, if you plan on doing your own, maybe I can help. Jeff
Damn, that dyno chart looks almost like JeffP's dyno chart from last Thursday---just lower on the scale.
I couldn't convince him to run a pull from 1500 in fourth gear for a true dispelling of the 'turbos have a non-linear response' myth, but the curve looks very much like yours, Jeff!
My kid loved the rides in your car at the Auto-X BTW. He now understands why Frank and all of us call the 260 'The Blue Turd, A.K.A. The Wallowing Pig'!
LOL
LOL
Neno is good luck, I always have a good run when he is in the pasenger seat. Thanks
  Tony D said:
Damn, that dyno chart looks almost like JeffP's dyno chart from last Thursday---just lower on the scale.LOL
Tony D, not to threadjack but now you gotta spill. What's JeffP's HP/TQ at nowadays?
