Guest Crispy Chicken Posted January 25, 2007 Share Posted January 25, 2007 It all most seems like less work not to use the baddog rails at all. If your going to go threw all the trouble. Trying to make them better and stronger. I'd just go with pete's design and never think about it ever again. Considering they're probably 500% stronger square compared to the u shaped ones. Derek Quote Link to comment Share on other sites More sharing options...
Careless Posted January 25, 2007 Share Posted January 25, 2007 Crispy Chicken said: It all most seems like less work not to use the baddog rails at all. If your going to go threw all the trouble. Trying to make them better and stronger. I'd just go with pete's design and never think about it ever again. Considering they're probably 500% stronger square compared to the u shaped ones. Derek Thats what I've been trying to say! now post some of your setup so that they can see what we mean. LOL and some updates might be coolz0r Quote Link to comment Share on other sites More sharing options...
Guest Crispy Chicken Posted January 25, 2007 Share Posted January 25, 2007 The front rails are "2.5x2.5" rear "2x3" .120 wall 11 gauge 3mm thick front "63.5mm x 63.5mm" rear "50.8mm x 76.2mm" Oh the floor is all cut out now.. =) Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted January 25, 2007 Share Posted January 25, 2007 Crispy Chicken said: It all most seems like less work not to use the baddog rails at all. If your going to go threw all the trouble. Trying to make them better and stronger. I'd just go with pete's design and never think about it ever again. Considering they're probably 500% stronger square compared to the u shaped ones. Derek ^^^^^^Makes sense to me^^^^^^ Quote Link to comment Share on other sites More sharing options...
alexideways Posted January 25, 2007 Share Posted January 25, 2007 I don't want to sound stupid but, anybody has a link to pics of Pete's rails? I searched but, I can find many mentions of it in many posts but, no actual pics. Thanks. P.S.: let me know the key words you used for the search. Quote Link to comment Share on other sites More sharing options...
Bartman Posted January 25, 2007 Share Posted January 25, 2007 alexideways said: I don't want to sound stupid but, anybody has a link to pics of Pete's rails?I searched but, I can find many mentions of it in many posts but, no actual pics. Thanks. P.S.: let me know the key words you used for the search. Just go to Pete's web site:http://alteredz.com/structuralmods.htm Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted January 25, 2007 Share Posted January 25, 2007 the BD rails are 12ga cold rolled steel Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted January 26, 2007 Share Posted January 26, 2007 they are steel! cool... they look stainless from the pics! =) thanks roost Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted January 26, 2007 Share Posted January 26, 2007 they were run thru a timesaver and it leaves a shiny brushed finish. Quote Link to comment Share on other sites More sharing options...
z-ya Posted January 26, 2007 Share Posted January 26, 2007 I think for 99% of the applications, the BD rails and sub frame connectors will do the trick. Once welded to the floor pan, they become a box, so for almost all (except for the highest torque) applications, they will greatly increase the stiffness of the stock chassis beyond what would be required. Adding any more metal will just increase weight, unless that level of stiffness is require (that's what she said). Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 26, 2007 Share Posted January 26, 2007 Man Prefab Rails...what is the world coming to? I made mine using a bench edge, then welded them in with a torch...while under the car... Times change, huh? Sounds like they are a stout product. I made mine out of the same thickness steel as OEM. They are still there 20 years later. But I moved from Japan to SoCal, so longevity of repair parts left untreated on the backside should be good... Quote Link to comment Share on other sites More sharing options...
260DET Posted January 26, 2007 Share Posted January 26, 2007 Those Maddog rails look heaps strong enough. If you want more rigidity run RHS or similar under the sill/rocker panels. Weld to the OE pinch welds and bracket them across under the floor a few times. Tie the front ends into the tension rod pickups and the backs into the bottom mounting points of a half cage. Why? Believe it or not the OE rails were removed on my 260Z, completely, and it relied solely on the above described 'perimeter chassis'. That car effectively used up to 300lb springs and handled great on the race track, pics on my site below. A practical bonus is the sills can then be used as jacking points, anywhere, handy when you are changing over to the R tyre wheels. Quote Link to comment Share on other sites More sharing options...
