bobbyc Posted January 25, 2007 Share Posted January 25, 2007 i'm gonna put a hx35w on my z...the housing hits the exhaust manifold so it's gonna need a spacer...and i've come across these...looks ideal because of the external wastegate flange. but i'm wondering if anyone has used one...and could tell me the overall length of this spacer and how far out it is gonna put the turbo...i e-mailed the seller and all they could tell me was that all they knew was in the auction. here's a pic and the link to the auction http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=250075217440 thanks Quote Link to comment Share on other sites More sharing options...
73ZCAR Posted January 25, 2007 Share Posted January 25, 2007 Bobby, Looks like they are sayin that it is an SSautochrome part. Look for them on ebay. Mike. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted January 26, 2007 Share Posted January 26, 2007 I was thinking of making something like that. I thought of buying that item too, but I wish the wastegate flange was facing down instead of to the side. If you do end up using it, let us all know how it works out! Quote Link to comment Share on other sites More sharing options...
LineC Posted January 26, 2007 Share Posted January 26, 2007 Just do a crazy triple u-joint with a brace off your steering shaft for clearance. That should clear it up. Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 26, 2007 Share Posted January 26, 2007 Wow, 56$. Hell for that much why would I bother to weld my own... And they have more! Also T3-T4 straight adapter flanges as well. Hmmmm. http://www.auctionsniper.com, my snipes, item number..... LOL Quote Link to comment Share on other sites More sharing options...
blairjj Posted January 27, 2007 Share Posted January 27, 2007 Guys, I bought one of these. Here are some pictures against a ruler. Biggest issues are that the casting has the wrong bolt pattern for the L6 turbo flange and that there is not clearance to use a stud or bolt to attach it to the exhaust manifold (picture above is of the stock nut for the turbo exhaust manifold studs). My thought so far is to cut off the stock manifold studs and machine them flat, even with the flange on the manifold. Then drill and install some locating pins to hold the adapter fixed in 2 planes. I would then weld the adapter to the flange on the exhaust manifold (pins allow expansion out of plane to the flange. After that tap the opposite set of holes in the adapter and install new exhaust studs. Jay Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted January 27, 2007 Share Posted January 27, 2007 Jay - maybe this would work better for you...you can shave off the studs and drill and tap the manifold and the adapter flange for the size bolt that you would need to fit on the adapter nicely and just use some loc-tite to make it all good. Also, I'm assuming since the compressor housing hit the manifold, have you checked to make sure the turbo won't hit the wastegate flange on that adapter? You mentioned you wanted the wastegate on the bottom of the flange, well you could have it cut off and have the hole welded shut and then have a hole cut out for the new place you want it and weld it back on there. Not sure how much work you want to do to this lil adapter though. Quote Link to comment Share on other sites More sharing options...
TONY C Posted January 28, 2007 Share Posted January 28, 2007 i am running this same spacer /adaptor. ended up taking it to a welder and having it welded to the exhaust manifold. this is the only way I could make it work without reinventing the part. Works great! No steering clearance issues. I am running a garrett t3/t4. had to rotate the center slightly so the stock nissan drain pipe would clear the steering shaft. Sits a bit close to the brake proportion valve so I made a turbo shield from a ss pot to avoid brake fade. An extension pipe for clearance issues has to be made to attach the wastegate [TIAL] in my case. puts the waste gate in the perfect spot to plumb it into the exhaust. I will try to post a pic. tc. Quote Link to comment Share on other sites More sharing options...
bobbyc Posted January 28, 2007 Author Share Posted January 28, 2007 that really helps...i was also thinkin for the wastegate i could just flip the spacer around and run it that way...so it's facing the firewall. i might just get it welded...sounds like the best idea. or if it is a major pita to get this to fit i can make my own with 2 T3 flanges and some metal...might be easier...but this info definately helps...thanks again! Quote Link to comment Share on other sites More sharing options...
TONY C Posted January 28, 2007 Share Posted January 28, 2007 mine is towards the fire wall. pics to post. Quote Link to comment Share on other sites More sharing options...
510six Posted January 29, 2007 Share Posted January 29, 2007 Tony is that high temp paint or some sort of ceramic coating on the exhaust manifold? Quote Link to comment Share on other sites More sharing options...
TONY C Posted January 29, 2007 Share Posted January 29, 2007 yeah it's just high temp paint. now that i have ran it for a while it's white. but hey, looks good in the pic. tc. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted February 7, 2007 Share Posted February 7, 2007 Oh man.. you mean those things won't even bolt to the manifold? That would make me really mad. I guess for sure I'll be making one rather than buying one. Thanks for the info blairjj. Quote Link to comment Share on other sites More sharing options...
djbit Posted July 18, 2008 Share Posted July 18, 2008 Yeah, I just bought me an HX35w too. I thought the turbo just bolted right up but I guess not. The fun never ends. Quote Link to comment Share on other sites More sharing options...
djbit Posted July 28, 2008 Share Posted July 28, 2008 So Bobby, what did you end up doing? Post pics if you have any. Thanks! Quote Link to comment Share on other sites More sharing options...
boostin280zx Posted July 29, 2008 Share Posted July 29, 2008 I had a 1.5" spacer made for my hx35w, but it made the turbo to close to the frame rail. I got it machined down to about 3/4" (i'll post up the exact measument) and it gave about 1/4" between the compressor housing and exhaust manifold. This is on a '82 280zx. Quote Link to comment Share on other sites More sharing options...
boostin280zx Posted July 29, 2008 Share Posted July 29, 2008 The stock 280zx t3 oil drain flange lined right up with the oil pan Quote Link to comment Share on other sites More sharing options...
djbit Posted July 29, 2008 Share Posted July 29, 2008 Thanks Bobby! Yes, if you can get the exact measurement of the spacer that would be great. I may follow this route too. It also appears you welded your external waste gate to the manifold. It's looking really good! Quote Link to comment Share on other sites More sharing options...
