2003z Posted February 7, 2007 Share Posted February 7, 2007 getting ready to put my engine back together. Its in the oven right now, curing the powdercoat. Not sure which brand/spec of lube I need for the assembly. If anyone saw my other threads, it turned out I got the wrong sized rings originally. That problem is taken care of and now I am only waiting on the harmonic balancer I bought off of ebay (and the seller won't respond with a status :< ) Quote Link to comment Share on other sites More sharing options...
veritech-z Posted February 7, 2007 Share Posted February 7, 2007 I like to use this stuff... http://cgi.ebay.com/Anal-Eaze-Desensitization-Cream-1-5-oz-lube-NIB_W0QQitemZ270029004761QQihZ017QQcategoryZ36436QQcmdZViewItem?refid=store&gclid=CKT7kOKVm4oCFSCzgAodoUWhhg Sorry man, with a thread title like that, you had to know it was coming...I've got some assembly lube made by permatex that I didn't really like, it was too syrupy, and got my hands all sticky. I used it when I was changing my head since the one I was using had been sitting for a long time. It worked fine, I just didn't like the side effects. Quote Link to comment Share on other sites More sharing options...
Cruez Posted February 7, 2007 Share Posted February 7, 2007 lol... maybe the title was asking for it... Quote Link to comment Share on other sites More sharing options...
JIM73240Z Posted February 7, 2007 Share Posted February 7, 2007 I like to use this stuff...http://cgi.ebay.com/Anal-Eaze-Desensitization-Cream-1-5-oz-lube-NIB_W0QQitemZ270029004761QQihZ017QQcategoryZ36436QQcmdZViewItem?refid=store&gclid=CKT7kOKVm4oCFSCzgAodoUWhhg Sorry man, with a thread title like that, you had to know it was coming...I've got some assembly lube made by permatex that I didn't really like, it was too syrupy, and got my hands all sticky. I used it when I was changing my head since the one I was using had been sitting for a long time. It worked fine, I just didn't like the side effects. sounds like a personal problem. ha ha jimbo Quote Link to comment Share on other sites More sharing options...
katman Posted February 7, 2007 Share Posted February 7, 2007 Nissan assembly lube when building Nissan engines. Quote Link to comment Share on other sites More sharing options...
2003z Posted February 7, 2007 Author Share Posted February 7, 2007 Normally I don't get many replies at all to my questions, so I thought it would help! Quote Link to comment Share on other sites More sharing options...
HizAndHerz Posted February 7, 2007 Share Posted February 7, 2007 ... now I am only waiting on the harmonic balancer I bought off of ebay (and the seller won't respond with a status :< ) Yeah, I'm in the same boat. The ebay ad does say it takes up to 4 weeks since it is a custom item that they order from the manufacturer. I won't be buying anything through a seller like that again. Quote Link to comment Share on other sites More sharing options...
er34gtt2000jp Posted February 7, 2007 Share Posted February 7, 2007 I prefer Astroglide for assembling my crankshaft into tight spots. But if your talking engine assembly lube, I used RedLine. Worked good but at over $6.00 a container is a bit steep. AutoZone sells a cheap molly lube that works well too. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted February 7, 2007 Share Posted February 7, 2007 lmao oh man... that's the funniest title i have ever scene in a forum lol. Quote Link to comment Share on other sites More sharing options...
z-ya Posted February 7, 2007 Share Posted February 7, 2007 Any brand from your local auto parts store will work just fine. Only use it on bearing journals, including the cam bearing journals. Only use cam break in compound on new cam lobes. If the cam is used, coat it with motor oil. I typically fill the engine with oil with the cam cover off, so I can pour it all over the cam and valve-train. Only use motor oil to lube the cylinder walls and pistons. If you haven't done so, make a engine primer with an old disty shaft for attachment to a drill. This way you can see that you have oil everywhere, including the cam. I'm sure someone has posted details on how to make one a bunch of times on this site. Pete Quote Link to comment Share on other sites More sharing options...
2003z Posted February 7, 2007 Author Share Posted February 7, 2007 Thanks for the detailed info Pete! Quote Link to comment Share on other sites More sharing options...
tcufrogz76 Posted February 7, 2007 Share Posted February 7, 2007 ass. lube... "huh huh huh, yeah cool, you said 'ass. lube" huh huh huh Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted February 8, 2007 Share Posted February 8, 2007 Sealed Power makes a decent one, should be available at your auto parts store. Doug. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted February 10, 2007 Share Posted February 10, 2007 aha...another person has powdercoated their engine block! J/k... Did you coat it your favorite color Mike? I used the red tube (astroglide?) of stuff from autozone and I really liked it while putting my block back together. It's fairly easy to clean off of your hands too. Good luck with getting your motor back together! Dan Quote Link to comment Share on other sites More sharing options...
2003z Posted February 11, 2007 Author Share Posted February 11, 2007 I was going to do candy lime green, but Teresa convinced me not too, in case I ever change the color of the car. Next was candy black, but all the texture of the block didn't work and it looked like silver dots all over, so I went with mirror black. Its mostly assembled now. Quote Link to comment Share on other sites More sharing options...
defrag010 Posted February 12, 2007 Share Posted February 12, 2007 lubriplate with oil is my fav, and fyi.. never Ever use moly lube on any bearing surface Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted February 13, 2007 Share Posted February 13, 2007 Yeah the L6 block has a LOT of texture...I spent a couple hours with the grinder/flap disc smoothing the big areas of mine... And then another hour cleaning out all the dust and metal particles out of the block... It was still dirty after that!!! Mirror black should look great! Quote Link to comment Share on other sites More sharing options...
