inline6 Posted April 24, 2016 Share Posted April 24, 2016 Thanks for the update. My engine builder recently completed making some mandrel adapter rings which, as I understand it, will be used to locate/hold the block while they bore it out.. We are going to bore both an L28 and an LD28. With the L28, we're going to go to something like 92 mm (I forget precisely the number). We are trying to remove all of the bore so we can examine the thickness of the deck and the bottom shelf of the bores. This is just to provide any information that may be helpful with regard to liner design. With the LD28, we'll try to go to 89 mm, but given others experiences that we know of here in the states, we aren't giving that a high percentage of success. This is why I find your information so intriguing. Anyway, if upon examination of the L28 bored out we see there is still promise with using a wet liner, then if we break through the LD28, we'll keep going until the bore is gone on that one also. Then we'll have to see if we can come up with a final design of the wet liners. Thanks again for the info. I wish I had your block. Quote Link to comment Share on other sites More sharing options...
Speedtripper Posted April 24, 2016 Share Posted April 24, 2016 It appears that my ability to upload pictures is severely retarded! I have uploaded a batch in my gallery section. If someone can give me a clue how to load a picture into this section it would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
inline6 Posted April 24, 2016 Share Posted April 24, 2016 (edited) Thanks for the pics. Your block is a V57 casting... which has external ribbing. You have a completely different animal there than the LD28 that came to the states. I found this image of a V07 block in another hybridz thread. Very different even just looking at the exterior, if I am seeing this right. Regarding uploading pics, look on the bottom right of the blank post area for the next post in the thread and you should see a button labeled "more reply options". If you click that, you will get more functionality exposed including the "choose files" to upload option. Maybe a group buy of V57 blocks from you is in order! Edited April 24, 2016 by inline6 Quote Link to comment Share on other sites More sharing options...
Speedtripper Posted April 25, 2016 Share Posted April 25, 2016 (edited) Thanks for the upload lesson. I have attached a picture to test. If it doesn't appear... I'm still retarded.Ok, it appears that it has worked. The caption for this picture, in case anyone hasn't read the kak previously is this. Testing the rod clearance in my 89mm x 92mm stroke LD28 block.Seriously considering stretching it to 93mm stroke. Would require further trimming of the piston crown. 94mm is totally possible but another piston with a compression height of around 31mm would be required. To take 3mm off the top of a KA24 would be pushing it. a 2.5mm trim and a 2mm gasket would get it there too. That will give a genuine 3.5l (3508.72cc)Bear in mind this is with the std 89mm piston. 89.5mm will bump to 3588cc and for those with nerves of steel (and deep pockets) a 90mm cut will deliver 3588cc. Edited April 25, 2016 by Speedtripper Quote Link to comment Share on other sites More sharing options...
Speedtripper Posted April 25, 2016 Share Posted April 25, 2016 @inline6... That block is definitely different. Mine has the external ribbing on both sides. Quote Link to comment Share on other sites More sharing options...
inline6 Posted April 26, 2016 Share Posted April 26, 2016 (edited) Ok, so you have a friend who can source these blocks? I am seriously interested in obtaining one. And I might be able to get others interested in a group buy. The V57 block never came the the US from what I can tell. Looks like it might be the version that was used for the factory supplied LD28T (turbo) as well as some industrial and marine applications. Garrett Edited April 26, 2016 by inline6 Quote Link to comment Share on other sites More sharing options...
Xnke Posted April 26, 2016 Share Posted April 26, 2016 I too, am very interested. I'd want two blocks, possibly three blocks. Quote Link to comment Share on other sites More sharing options...
inline6 Posted April 26, 2016 Share Posted April 26, 2016 On 4/26/2016 at 6:02 AM, Xnke said: I too, am very interested. I'd want two blocks, possibly three blocks. I think I would like two also. That is four or five already. Quote Link to comment Share on other sites More sharing options...
LanceVance Posted April 27, 2016 Share Posted April 27, 2016 On 4/26/2016 at 2:28 AM, inline6 said: ..Looks like it might be the version that was used for the factory supplied LD28T (turbo) as well as some industrial and marine applications... On 4/24/2016 at 5:42 PM, inline6 said: ...I found this image of a V07 block in another hybridz thread. Very different even just looking at the exterior, if I am seeing this right... Not my photo, but my Photobucket account (Rayaapp2's photo/vehicle/cat). If anybody does import any of these blocks, and just happens to get an oil pan like the one pictured (winged/rear sump) I would be interested in buying it. Assuming of course, you don't use it yourself... In to see the stroker progress too, so please excuse the shameless plug! Quote Link to comment Share on other sites More sharing options...
inline6 Posted April 27, 2016 Share Posted April 27, 2016 (edited) On 4/27/2016 at 12:58 AM, LanceVance said: Not my photo, but my Photobucket account (Rayaapp2's photo/vehicle/cat). If anybody does import any of these blocks, and just happens to get an oil pan like the one pictured (winged/rear sump) I would be interested in buying it. Assuming of course, you don't use it yourself... In to see the stroker progress too, so please excuse the shameless plug! I sold a pan like that when I parted out a V07 a while back. I would think it wouldn't be "too hard" to find. I'll keep an eye out. Sorry if anyone is annoyed with the digression. We can move the theads for getting the V57 blocks to another thread? Edited April 27, 2016 by inline6 Quote Link to comment Share on other sites More sharing options...
WhitleyTune Posted April 27, 2016 Share Posted April 27, 2016 Speedtripper, what are your plans in regards to running the larger LD28 head bolts? Just going to drill the head out to 12mm? Quote Link to comment Share on other sites More sharing options...
Speedtripper Posted April 28, 2016 Share Posted April 28, 2016 Update...It appears that I have been a really bad friend! My mate sold his farm a couple of years back and I just found out. He is over 700mls away so I can be excused for that. I spoke to the new owner, and all surplus "junk" was removed when they bought. They do have a Nissan patrol with a LD28 for sale, but cannot seriously consider that option to just part out a block and a crank. Apparently, the V57 was not an official import, but a number of these motors were brought in for conversions in Land Rovers. The net is littered with people talking about this conversion, but the posts are generally 5+ years old. I will post a couple of ads on some of the local 4x4 forums to see if I get any bites. @WhitleyTune, yes the idea is to drill out the head to accommodate the larger bolts. Ran it by an engineering shop and they weren't too concerned. Quote Link to comment Share on other sites More sharing options...
260DET Posted April 29, 2016 Share Posted April 29, 2016 On 2/9/2007 at 12:56 PM, naviathan said: That much overbore is going to make the cylinder walls too thin I think. Hell the 89mm required for a 3.1L stroker make the walls extremely thin. Yep, lots of core shifts with those blocks, checking wall thickness is essential if serious. Quote Link to comment Share on other sites More sharing options...
inline6 Posted April 30, 2016 Share Posted April 30, 2016 (edited) On 4/28/2016 at 1:19 PM, Speedtripper said: Apparently, the V57 was not an official import, but a number of these motors were brought in for conversions in Land Rovers. The net is littered with people talking about this conversion, but the posts are generally 5+ years old. I will post a couple of ads on some of the local 4x4 forums to see if I get any bites. I have some questions about your block. Can you tell if the front three and back three cylinders are siamesed? That is, are there no coolant passages between 1 or 2 or 3 and none between 4 and 5 and 6? Instead of separated/isolated castings for each cylinder, is each set of three connected/contiguous? And by contrast, there are cooling passages between cylinders 3 and 4? Could you post some more pictures of it when you get a chance? Front, back, and the two sides? The pistons you have mocked up are 89 mm diameter? Garrett Edited April 30, 2016 by inline6 Quote Link to comment Share on other sites More sharing options...
inline6 Posted July 12, 2016 Share Posted July 12, 2016 I just heard back from someone that a sonic test on a V57 block showed 3.7 mm of wall on a stock bore. That's bad news for using a V57 block. You seem to have the only block that has taken a 89 mm bore! Quote Link to comment Share on other sites More sharing options...
fraz Posted July 12, 2016 Share Posted July 12, 2016 On 7/12/2016 at 3:47 AM, inline6 said: I just heard back from someone that a sonic test on a V57 block showed 3.7 mm of wall on a stock bore. That's bad news for using a V57 block. You seem to have the only block that has taken a 89 mm bore! My brother in law just tested a v57 here in NZ and it was around 3.5-3.7mm wall. Bit disappointing as we were hoping to make 1 each. V57 motors are a bit more common in NZ. Quote Link to comment Share on other sites More sharing options...
inline6 Posted July 16, 2016 Share Posted July 16, 2016 Yes. NZ is where I have been looking to source them. Any chance your sonic tests aren't accurate? And just so we are on the same page, 85 mm is the stock bore, correct? 3.5 mm and the requirement to run no less than .120" inch wall thickness means you couldn't bore that block more than about .010" inches? Just seems to fly in the face of logic that it could take so little. Quote Link to comment Share on other sites More sharing options...
fraz Posted July 16, 2016 Share Posted July 16, 2016 On 7/16/2016 at 1:41 AM, inline6 said: Yes. NZ is where I have been looking to source them. Any chance your sonic tests aren't accurate? And just so we are on the same page, 85 mm is the stock bore, correct? 3.5 mm and the requirement to run no less than .120" inch wall thickness means you couldn't bore that block more than about .010" inches? Just seems to fly in the face of logic that it could take so little. I'll take some photos today. Quote Link to comment Share on other sites More sharing options...
fraz Posted July 17, 2016 Share Posted July 17, 2016 (edited) the block is a v57, crank still has v07 on it. maybe they just updated the block? My brother in law got it from a mat who had a bunch of them as spares for some LD converted vehicle he has/had. So no history on its origins. You can see from the photos that there is a large gap between the cylinders. there is a bit of wire between 1-2-3 and 4-5-6, must be from casting to keep the cores in line. Also some photos of the crank next to a modified rb30 crank.(modified for another engine, but using as a test fit here) now lots of photos cos every body loves photos - all photos have been halved in size. i can upload more detail if requested please excuse the amateur photos, im an amateur between 5-6 between 4-5 between 3-4 between 2-3 1-2 Crank photos and some measurements because everybody on the internet tells the truth! haha dont get upset by the modified rb30 crank. its back yard spec and it didnt fail Edited July 17, 2016 by fraz Quote Link to comment Share on other sites More sharing options...
inline6 Posted July 17, 2016 Share Posted July 17, 2016 Daylight between cylinders is proof positive that the block won't take an 89 mm bore. What is the engine number on the plate? Maybe we can get Speedtripper to tell us the number on his as well. Quote Link to comment Share on other sites More sharing options...
