80LS1T Posted March 14, 2007 Share Posted March 14, 2007 I primered the back half of my car last night and after it dried I noticed that there are 6-8 spots that are either too high or too low. I never noticed them before I primered(I obviously would have fixed the areas!) but now that the whole area is one color I noticed these spots that I apparently missed! Just when I thought I was almost done too! Is this pretty normal when doing body work or are my eyes just bad! LOL I hope the front end isn't like this! Guy Quote Link to comment Share on other sites More sharing options...
alexideways Posted March 15, 2007 Share Posted March 15, 2007 You just discovered the age old trick to a perfect bodywork... Put one layer of dark grey primer and then a second coat of a lighter grey primer. You then take your long block and block sand in a crisscross patern at about 45* angle, all your high spots will be dark grey, the low spots light grey and the straight panels will be a mix of both colors... Quote Link to comment Share on other sites More sharing options...
G.I.jonas Posted March 15, 2007 Share Posted March 15, 2007 Actually good body work is impossible by sight,anyone who is anything at body work goes by feel,learn to map every square inch with your hands and you will never miss a thing,highs and lows are easily found before you ever think of priming. Quote Link to comment Share on other sites More sharing options...
v8wannabe2 Posted March 15, 2007 Share Posted March 15, 2007 Alexideways has the right idea, it's called guidecoating. I lay down a couple coats of a high build primer and then mist it with a contrasting color. You will see the dents as the board won't remove the paint in the low sport. Get use to using your hand to assess the flatness too, rub it back and forth over the area in question and with a little practice you can get pretty good at finding the highs/lows. When you sand always use the longest sanding board possible, I use an assortment of different length boards along with wooden dowels, rubber hose, etc. When your sanding sand in an X pattern. Yep, you can expect to put a lot of hours in to it to get it straight. Remember, with body work you only see what you did wrong when it's finished Quote Link to comment Share on other sites More sharing options...
2003z Posted March 15, 2007 Share Posted March 15, 2007 in other words, its perfectly normal. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 15, 2007 Author Share Posted March 15, 2007 Well atleast it's not just me! Most of the spots that are uneven look like they'll be pretty easy to fix. Speaking of which, how do I fix those low spots? Sand it down to metal and apply a skim coat of filler and smooth it out with a sanding board? Guy Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 15, 2007 Share Posted March 15, 2007 I shadowed at a body shop and the part would look perfect then theyd prime it and it would look horrible. Theyd go through this a bunch of times and sooner or later it would be perfect. What did everbody use to get theyre headlight buckets smooth and strait(inside of buckets/edges)? Quote Link to comment Share on other sites More sharing options...
G.I.jonas Posted March 15, 2007 Share Posted March 15, 2007 Yea, you usually dont have it right first time...prime it,check it,sand it,remud it,sand it, prime it,check it,sand it,remud it,sand it,prime it,check it ect. ect. something like that will become your life in body work. Quote Link to comment Share on other sites More sharing options...
rdsk8ter Posted March 15, 2007 Share Posted March 15, 2007 i learned my fiance can find small imperfections ask a girl to run there hands over it they will tell you where it is high and where it is low because they often do not have callused hands like us guys do lol. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted March 15, 2007 Share Posted March 15, 2007 I would not go back to bare metal to fix the low spots. Just rough up the area with 80 grit, and apply a thin layer of filler centered on but larger than the low spot. After it cures, blend and reprime. You will probably have to repeat several times before all of the low spots are gone. Quote Link to comment Share on other sites More sharing options...
Two40MuscleZ Posted March 17, 2007 Share Posted March 17, 2007 Darker colors especially black shows everything! To achieve that pristine perfect finish, you may wind up guide coating and blocking out the entire primered car, 3-5 times. Each time changing up to a higher grit of sand paper. Then again after the car is base coated/clear coated you get to wet block it several more times until the refraction properties in the clear are a perfect 45 degree angle in and out. You'd have to be into painting to fully understand the principle behind that statement. Then buff out the clear to eliminate sanding scratches and wheel polishing/buffing marks. Then you get to wax it a few times. It's a long and argeous task. But done correctly, its a whole different dimension to look at. Quote Link to comment Share on other sites More sharing options...
