280zcar's 78 280z LS1/T56
Finished up the passenger side and took a few more pics of the process...
Taped off...
rough mockup with sheet metal screws holding the flare in place...
flare marked off....
quarter panel and inner fender well cut away. nut-serts installed as well.
installed nut sert from the back side.
Lots of tack welds...
didn't take pics of seam sealer/prime and paint....
Done...
  • Replies 197
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • 2 months later...
So I'm going to a V8 swap on a budget (not too tight as its a project) but I was considered a carbed 350 for simplicities sake and how clean they look (especially the way yours did).
How was the performance of that particular engine? Ever do any racing or 0-60 runs? I'm not looking to be super fast but I would like a sub five second 0-60.
Welp. I spun a couple bearings back in January..... the car sat for a while. I gathered some parts and now its is mostly all back together
Picked up a new ls1. Its got a cam with supposedly only 35k miles on the motor. Installed it this past weekend
Long block
Ready to go in
in
Vroom.
Drove it around the block on sunday ..... lots of vibration through the trans.... crap... pilot bearing was f'ed
Got it home... yanked the motor on tuesday... replaced the pilot bearing... no shaft play on the trans...YAY.. put it back together... all is well again.
in other news... got a JSk kit for 5 lug hubs from member on here. Still gathering some parts, but this is the rotor and caliper mocked up.
  • 3 weeks later...
Wilwood setup completely installed.
Crappy pic, but shows new 1"  Wilwood master cylinder and All stainless braided lines coming off the master and just the top of my proportioning valve along the firewall. Bulkhead "tee" connector through fender wheel to front left wheel. Also a pic of temporary location for Oil pressure gauge. Mechanical gauge, need to get a bulkhead connector route it back into the dash.
Finally bought a new filter and mounted it out in front of the radiator. Also went and got the car inspected today. The guy who was inspecting it was a bit perplexed when he wen to check the mileage.... no speedometer or odometer... so he put that the car has 5 miles lol... I have a new speedometer coming tomorrow.
Couple Random pics of the car...
582003_10101902183750412_1231219186_n.jp
Edited by 280zcar
I hate your guts for not answering my question, but I love every update you do. I love seeing the transformation of this car and the awesome work you do to it.
Now if I could just save more money!
Thanks, sorry for not answering before.
I didn't do much with the old SBC in terms racing. I took it to the 1/8 mile one time and ran a 8.3 with a 2.1 60 ft. It had quite a bit left in it. Hopefully will be able to get a comparison pretty soon with the ls motor.
Installed autometer speedometer in the stock gauge pod just like the tach that I already had.
Haha I was just messing. Your LS1 should be quite an improvement over that.
  • 4 weeks later...
Haven't done much with the car other than drive it lately. Took it up to Oklahoma to visit a friend one weekend and it drove wonderfully. I've put 600 miles on the car since the speedo install.
Picked up some wheels. Not exactly sure what I am going to do with them, but the price was right.
15x10 -29 enkei 92s
The guy had these just sitting in storage for 17 years. One thing that was kind of neat is the valve stem caps even have Enkei on them. They were originally gold, but were painted over. I may just end up selling them, or throw something sticky on them.
Well, decided to stick with the wheels for a bit.
Got tires mounted.
235/50/r15 Toyo Proxes r888
They are quite a bit shorter in overall diameter than my regular street tires. If I wanted to go any lower I would need to redo the back section of my exhaust. Need to track down some wheels for the front now.
  • 3 weeks later...
That size may fit, the R888s run fairly wide. Wheel is maybe a little more than an inch from the strut tube
Had some spare time and some scrap metal.... So.... Made a front strut brace.
The mount still need some final trimming and welding but its mostly finished.
Still debating on whether to tie it back to the firewall, but I realize that is what will provide the most strength.
Were you able to cover those back pieces with a solid piece of material with the curvature of it? also what type of glue did you use and how is it holding up? I want to do some pieces in alcantara when I get to the interior.
I started trying to cover the plastic panels in the hatch. The quarter window piece has a little bit of exposed plastic but it was a first attempt and the underlying plastic is black so its less noticeable. I still need to work on the other side. It is black suede but the sunlight kind of throws the color off. It is the same material I used on the piece in front of the dash.
Here's another pic of the overhead plastic piece where the dome light mounts.Its covered with headliner material.You can see it a little bit in the picture above as well where it meets the quarter window piece. I'm contemplating covering it in the same suede material.
