hawaiiz Posted May 17, 2007 Share Posted May 17, 2007 Update - Now looking the the 225/60r14s ALoha All - My New 280z z came with some pretty decent 14X7 rims. Always hard to decide on what tires and rims to get so I thought Id start out with the esiting rims and pickup some new rubber. The Big Island of Hawaii is a realy tough place to get stuff so aside from 195/70r14s I need to special order. Since we have a Costco I want to order the BFG Radial TA 215/60SR14. Im installing Iluminas, staying with stock springs, removing the huge bumpers and I d like to keep the stock height. So the Questions. What does my rim offset look like? http://picasaweb.google.com/cruzinit/ZRebuildWheels Id like my Z to look somthing like this one when done. PS Hope using your pic is OK. Will I have any problems with the wider 215s - "The 195s on it were way skinnny" - with these 14x7 rims. Thanks in advanced. HawaiiZ Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted May 17, 2007 Share Posted May 17, 2007 if they are indeed 7" wide, the biggest you could throw on there is a 225 realistically. I've got 225s on my 16x7s, they have 0 offset and I dont have rubbing issues. Quote Link to comment Share on other sites More sharing options...
hawaiiz Posted May 17, 2007 Author Share Posted May 17, 2007 Wel 225s would be great, Taking a look around the 225/50r14s would be good but not available on a street tire. I guess I could get some look into getting some rims. I like the Old school look - Im even going to put the white lettering on the outside. Im 39 and still skateboard - Old school skateboard tail only on one side, fat wheels, Yea Man. MORE I liik at the 225/60r14 the more im liking them. Now to see where I can get them from. Quote Link to comment Share on other sites More sharing options...
veritech-z Posted May 18, 2007 Share Posted May 18, 2007 Im 39 and still skateboard - Old school skateboard tail only on one side, fat wheels, Yea Man. That's so hard! I've still got a Powell & Peralta Mike McGill board that I break out every so often, with rail gaurds and extra wide Indies! I don't skate nearly as much or as hard as I did before I got the metal plate installed in my ankle, but I still enjoy it....27 years old now, and hope to be cruising on my board as long as you, man! Quote Link to comment Share on other sites More sharing options...
het976 Posted May 18, 2007 Share Posted May 18, 2007 Just FYI...I have a set of 14x7s with 245-50 BFG and they fit with 1/4 spacers in rear and 1/2 in front. I put on longer wheel studs in front. I have fender flares, so not sure about the body to tire fit...but the 245s worked on all 4 wheels with stock, lowered suspension. Not sure of the offset on the wheel...at the time I did them (1977) there were very few affordable wheels wider than 6 inches. The ones I have are Appliance cast wire. The tires are still good, but must be close to 20 years old... Quote Link to comment Share on other sites More sharing options...
Ledphoot Posted May 18, 2007 Share Posted May 18, 2007 Nuthin' wrong with ol' skool!! I'm 40. I love em low and lean or wedged with skinnies and fats, Its all good! Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted May 19, 2007 Share Posted May 19, 2007 I just put some Western Cyclone II 14 x7's on my '83ZXT, with 235/60 and 215/60 tires. They fill the wheel wells nicely. I got the Firestone Indy 500's. I believe there is at least one other person running this setup (tires) on a 71-78 Z. You want 0 offset, like we both have. Quote Link to comment Share on other sites More sharing options...
