Well the time has come... the L28 is coming out.
240hoke
LS2 aluminum blocks with stock sleeves are good for around 1000whp. They are much stronger then the ls1 blocks with stock sleeves. Beyond that you need to sleeve them, or go with a cast iron truck block which would be good to around 1400-1500whp. Beyond that there is the new LSX block which is reportedly good for 2000hp. :) LS1tech.com is a great forum if you didn't already start reading over there
Here's a great place to get all of the new components if you just want to piece something together instead of buying some unknown unit off of ebay.
http://www.sdparts.com/
You can get an LS2 block for $999:
http://www.sdparts.com/product/12568950/LS2400quotBoreAluminumCorvette60LBareBlockGenIV.aspx
You can easily build a 402 CI unit from this, or buy a complete ls2 shortblock setup for low compression.
http://www.sdparts.com/product/SDLS2402D/402LS2ShortBlockAssemblywDishPistons14cc.aspx
Regards,
Justin
I heard LSX was good for 2500? What does the LSX cost? LS is a nice setup for you Austin since your cars been reinforced. You wouldn't have to worry about your Z twisting in half :P.
Right now its looking like Im going to go with a ls1 or ls2 and single turbo it. Just gotta get my L stuff sold so i can get the ball rolling with a motor.
LS1 and a turbo? You may as well budget for 10 sets of tires per year then. I have 9K miles on mine and I'm on my 3rd set of rear tires. Or at least find some noisy tires - the Dunlops I have are too quiet. I was apparently smoking them almost always without really realizing it. A co-worker was commenting on my "burn-out" out of a parking lot - what burnout, I had no idea - except that my tires don't last for shibby.
You might just consider putting the motor in and running it NA for a little while...
Soft tires make a huge difference in traction. Those Dunlops are you have great for mileage but not traction. I would think his L28 T is making as much or more than an n/a LS6
Yup my l28 already had more power then a stock LS6. And I agree with clifton you gotta get some wider sticky tires. I could smoke my 245 Hankook's all day long but when I put my MT's on there mmmm mmm traction.
Im prolly going to end up getting a different set of wheels too so I can run a wider street R compound tire. I dont like the flex from DR's over 120 or so and the car just wobbles around all over the place and nobody makes wide street tires for 16" wheels.
V8 and turbo mmmmmm mmmm I cant wait... :)
