My Rb26 Z32 Project is finished for the year....
Booztd 3
My 1990 RB26 powered Nissan 300ZX
Modification List
Drivetrain
RB26DETT
RB25 Modified Oil Pan
Z32 Transmission Mated w/RB Trans
Modified Cross Member
Custom Motor Mounts
Full-Race Twin-Scroll Manifold
(2) Tial 44mm Wastegates
Tial 50mm BOV
Greddy Cam Gears
ARP Head Studs
Tomei Type-A Poncams
Greddy T-Belt
Tomei 5 Layer Gasket Kit
Garret GT4202-74mm
JGY Fuel Rail (Dual -8 Feed Setup, Single -6 Return)
TMS 1000CC Injectors
AeroMotive FPR
(2) Walbro 255 GSS-342 Fuel Pumps
Earls Fittings/Braided Lines For Fuel
Earls Fittings/Braided Lines For Oil
OS Giken Triple Plate Clutch
RB25 Slave Cylinder
Clutch Pivot Ball & Clutch Line
Z1 1piece Steel Driveshaft
Richmond 4.10 Ring & Pinion Set
XS Engineering 4" FMIC
Custom Aluminum IC Piping
4" Downpipe & Test Pipe Fab
Greddy SP Dual Exhaust for 300ZX
(2) 10" Permacool HD Electric Fans
Custom Double-Pass Radiator
245/45/17 Khumos in front
275/40/17 MT ET Street Radials in rear
Not Installed
N1 Water Pump
N1 Oil Pump
Crank Collar
Pauter Rods
CP Pistons
ACL Race Bearings
Suspension
Powertrix HICAS Eliminator Bar
Powertrix Adj. Tension Rods
Electronics
AEM 1621 RB26DETT EMS
AEM 3.5 Bar Map Sensor, Coolant Sensor, IAT Sensor
AEM UEGO
Defi Link 2
Defi BF Boost Guage
Relocated Battery to Rear - Optima Red Top
Alpine CDA-9857
Alpine Speakers
Safety
Full 8pt Roll Cage - Certified to 8.50's
Swing-Out Bars
RCI Platinum 5pt Harnesses
RJS Window Net
Flaming River Battery Kill Switch
Interior
Complete Maroon Red to Charcoal Black interior swap
Removed Tweed Inserts, Custom Vinyl application
Sparco Speed Seats w/custom sliders
Sparco Extreme2 Steering Wheel
Nismo Shift Knob (the rare one!)
Cosmetic
1999 Fairlady Z JDM Bumper w/smoked turn signals
1999 Fairlady Z JDM Tail Lights
Stillen Type 3 Sideskirts & Door Fillers
5-Zigen FN01R-C
Paint matched Brake Caliper to wheel colors
Powertrix Carbon Fiber Air Guides (under hood)
The car is currently making 485rwhp@14psi and I plan on going back to the dyno to give it a little more boost before rebuilding the motor. I would like ot achieve 600rwhp this season and get a few 10 second passes in. Once I regain my social life this summer/fall and get to enjoy my car for several months, it wil be going back under the knife this winter so I can add all the forged goodies and paint the engine bay. I will probably sell the N1 oil pump in favor of a better oil pump (JUN, Tomei, etc) and I'll also need to pick up an ATI Pulley.
Laterz
Very clean install I love it!! But one thing.... Having the AEM in the engine bay makes me cover my eyes!! In my opinion I would rather have it inside the car. Is there any reason preventing you from doing that?? Electronics and heat dont mix:cry:. Just my opinion tho, great job and I cant wait to see more videos!!!!!!
I mainly wanted it there for a showoff factor :)
Plus I shortened the RB wiring harness considerably, in order to do this, so i'd have to re-lenthen the harness to do it all over again!
I do not drive the car in extreme heat, nor in rain, so I havent had any issues yet, plus AEM is really good about warranting their stuff :)
I would still build a box for it atleast.... My ignitor failed because of heat and ended up frying my ECU. If you want to show it off you can just pull the cover off of it. But if you take it out and drive it for a good amount of time and pull it in the garage back home put your hand on the ECU if its cool then your fine. But if you have to take your hand off of it I would suggest building a box for it. Just my opinon and I hope to see your car sometime!!!
